Strange notification in Discover in KDE Plasma 6.2
Hello everyone, after today updating KDE Plasma 6 to version 6.2, Discover started showing this notification. It confuses me a little, maybe someone knows more about it, for example, what is it connected with, or why is it shown now?
image:
https://i.imgur.com/kNY3KW0.png
text:
Support for managing packages from Garuda Linux is incomplete; you may experience any number of problems. Do not report bugs to KDE. It is highly recommended to uninstall the “packagekit-qt6” package and use Discover only to manage Flatpaks, Snaps, and Add-Ons.
Garuda Linux maintainers recommended instead using the pacman command-line tool to manage packages.
garuda-inxi:
Kernel: 6.11.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cdf6ad32-4178-4885-b457-92a9df9f184f rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.0 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop Mobo: ASUSTeK model: PRIME H310-PLUS v: Rev X.0x
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 0401 date: 02/28/2018
Info: model: Intel Core i5-9500 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF8
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 4400 min/max: 800/4400 scaling: driver: intel_pstate
governor: powersave cores: 1: 4400 2: 4400 3: 4400 4: 4400 5: 4400 6: 4400
bogomips: 36000
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: HDMI-A-2 empty: DP-2 bus-ID: 00:02.0 chip-ID: 8086:3e92
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none
empty: DP-1,DVI-D-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c82
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
s-diag: 414mm (16.31")
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: Acer K202HQLA serial: <filter>
built: 2016 res: 1366x768 hz: 60 dpi: 80 gamma: 1.2
size: 434x236mm (17.09x9.29") diag: 494mm (19.4") ratio: 16:9 modes:
max: 1366x768 min: 720x400
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.1
GT2) device-ID: 8086:3e92 memory: 11.38 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 14 device: 0 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel v: 24.2.4-arch1.1
device-ID: 8086:3e92 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1050 Ti driver: nvidia v: 560.35.03
device-ID: 10de:1c82 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.4-arch1.1 (LLVM
v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl
Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
API: ALSA v: k6.11.3-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.05 TiB used: 238.47 GiB (11.3%)
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM2 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 model: UDore 256GB size: 238.47 GiB
serial: <filter> fw-rev: 1A0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA100
tech: HDD rpm: 7200 serial: <filter> fw-rev: A8A0 scheme: GPT
ID-1: / raw-size: 237.5 GiB size: 237.5 GiB (100.00%)
used: 36.58 GiB (15.4%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 1001 MiB size: 999 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 201.89 GiB (22.0%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
ID-4: /var/log raw-size: 237.5 GiB size: 237.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 237.5 GiB size: 237.5 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.31 GiB used: 13.5 MiB (0.1%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6
System Temperatures: cpu: 44.0 C mobo: N/A
Memory: total: 24 GiB available: 23.31 GiB used: 4.64 GiB (19.9%)
Processes: 251 Power: uptime: 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.28 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2011 libs: 569
tools: octopi,paru,yay pm: flatpak pkgs: 0 Compilers: clang: 18.1.8
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: yakuake
inxi: 3.3.36
System install date:     2024-09-08
Last full system update: 2024-10-11
Failed units:            systemd-userdbd.service systemd-userdbd.socket
The answer is in
Discovery is warning you to NOT use it for managing system packages , and use it ONLY to manage flatpaks and snaps. Unseeing this warning may cause you to have problems.
Best course of action is to use Bauh or Octopi.
Personally I find Bauh to be a very good and simple GUI package manager frontend, better than Octopi IMO.
For updating you can use garuda-update as recommended by @dr460nf1r3
We explicitly chose to not pre install package kit as we do not want people to use Discover for updating their systems. It is still good for updating KDE add-ons like plasmoids that were installed in the user context via KDE however.
Or, even better: garuda-update in case of updating the system :smiley: both tools might be good, but will run pacman, so our fixes won’t be applied.
It can be used to install apps as well ? My context was in the sense of installing software and apps.
Oh well, let me correct my statement, it was referring to system upgrades only.
