Hello Garuda users.
My garuda-inxi:
Kernel: 6.3.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=c1ba9331-3cea-44cf-a194-04cb29defb6c rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 82L5 v: IdeaPad 5 Pro 16ACH6
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 Pro 16ACH6
Mobo: LENOVO model: LNVNB161216 v: WIN serial: <superuser required>
UEFI: LENOVO v: GSCN27WW date: 08/23/2021
ID-1: BAT0 charge: 25.4 Wh (36.9%) condition: 68.9/75.0 Wh (91.9%)
volts: 14.9 min: 15.4 model: Celxpert L20C4PE1 type: Li-ion serial: <filter>
status: discharging cycles: 41
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1520 high: 2559 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1396 2: 1200
3: 2421 4: 1200 5: 1197 6: 1200 7: 1197 8: 1197 9: 1198 10: 2559 11: 2085
12: 1653 13: 1198 14: 1200 15: 2224 16: 1197 bogomips: 102206
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a2 class-ID: 0302
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 44.0 C
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 13d3:56fb
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x317mm (19.96x12.48")
s-diag: 598mm (23.54")
Monitor-1: eDP-1 mapped: eDP model-id: CSO 0x1601 built: 2020
res: 1920x1200 hz: 120 dpi: 141 gamma: 1.2 size: 345x215mm (13.58x8.46")
diag: 407mm (16") ratio: 16:10 modes: max: 2560x1600 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.1-zen2-1-zen) direct-render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.3.1-zen2-1-zen status: kernel-api tools: N/A
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3
chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Local Storage: total: 2.75 TiB used: 1.4 TiB (51.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TDE9X084N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41010C22 temp: 40.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Micron model: CT2000X8SSD9
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD serial: <filter>
fw-rev: PMAP scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 20.29 GiB (20.3%)
used: 876 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 20.29 GiB (20.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 46.0 C
Processes: 435 Uptime: 1h 49m wakeups: 2993 Memory: available: 13.5 GiB
used: 5.58 GiB (41.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1494
libs: 401 tools: octopi,paru,yay Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2023-05-09
Last full system update: 2023-05-11 ↻
Failed units: nmb.service
I was wondering if someone may be able to help me fix the strange fonts I'm getting when using Octopi installing packages. This is the kind of output I'm seeing with a string of squares shown after the asterisks:
Installing selected packages...
********[STRING OF SQUARES DISPLAYED HERE]
resolving dependencies...
Am I missing a font package? I've search for solutions to this with no luck. If someone could please help.
Many thanks.
Have you rebooted after you updated?
Thanks for the reply.
Yes, rebooted. It's a clean installation and fully updated with the latest packages. It displays this every time I install an app/software.
Any other thoughts?
Thank you.
Since you say you have now rebooted, please share a new garuda-inxi with us. And bracket it as well, please.
Apologies c00ter, I'm new to the forum. When you say bracket, how do I do that please. Is it the quote icon I need to click on and then paste the contents of garuda inxi?
There is all sorts of information available in the forum if you Search for it. The information on how to display your garuda-inxi was part of what you removed when you made your first post here.
Here are some basic posting rules. The part you want is: How to write a nicely formatted post in Discourse/Forum Please pay attention to the back ticks.
Aah OK, apologies for that, yes I should have searched before posting.
Hope this is correct now...
garuda-inxi after update and reboot:
loglevel=3 ibt=off
ID-1: BAT0 charge: 51.6 Wh (75.0%) condition: 68.8/75.0 Wh (91.8%)
volts: 17.3 min: 15.4 model: Celxpert L20C4PE1 type: Li-ion serial: <filter>
status: charging cycles: 41
Speed (MHz): avg: 1581 high: 3200 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3200 2: 1200
3: 1200 4: 3200 5: 1200 6: 1200 7: 1200 8: 3200 9: 1198 10: 1200 11: 1313
12: 1200 13: 1200 14: 1200 15: 1200 16: 1200 bogomips: 102216
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 49.0 C
Local Storage: total: 2.75 TiB used: 1.4 TiB (51.0%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 41010C22 temp: 45.9 C
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 19.29 GiB (19.3%)
used: 19.29 GiB (19.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 50.0 C
Processes: 407 Uptime: 39m wakeups: 2616 Memory: available: 13.5 GiB
used: 3.66 GiB (27.1%) Init: systemd v: 253 default: graphical
'From File conflict on update - #5 by SGS '
Search for apps with what you want (
pacseek, octopi, pamac, discover)
but use only pacman in terminal for update or installation.
First, use
garuda-update
or
update
Summary
or
upd
alias | grep upd
alias upd='update -a' in ~/.config/fish/config.fish
than
sudo pacman -Syu app-name
in terminal. If you get "errors", please post full log from terminal as text like the garuda-inxi.
This person resolved a similar issue by installing a font package (technically I guess it sounds like uninstalling the conflicting package may have been what fixed it):
opened 07:02PM - 21 Nov 19 UTC
closed 09:29AM - 24 Nov 19 UTC
@lxqt-team and supporters
I'm running **octopi**-git, a pacman frontend from th… e AUR on Arch linux/ KDE Plasma.
Octopi-git is using **qterminal** in **qtermwidget** as embedded terminal.
But its output looks like this: https://imgur.com/vn9OROj
It seems that all areas of potentially input of the embedded terminal= qtermwidget are '**squared**'. All other areas particular of pure output are fine.
Strange that **qterminal** used as standalone works flawlessly?!
I tried quite a few things: https://github.com/aarnt/octopi/issues/401
Is this familiar to someone here? Any ideas would be appreciated... 'cause this is a tough one.
KDE Plasma Version: 5.17.3
KDE Frameworks Version: 5.64.0
Qt Version: 5.13.2
Kernel Version: 5.3.12-arch1-1
Qtermwidget-git version: 0.14.1.47.gd4896ed-1
Qterminal-git version: 0.14.1.75.g1ce29eb-1
Just a stab in the dark here, but my dim recollection of similar past errors were solved by installing a specific terminal font. Which font(s), I do not recall. And I mean way dim.
Thank you for your reply and other above guys. Yes, I have looked into the above potential solution from @BluishHumility but it's not really giving me any real pointers. I'm also thinking I'm missing a font package but no idea which.
Anyone else any thoughts please?
I use Noto Sans in KDE Settings and Monospace (for fixed width). Konsole is Monospace also. I'm assuming the Output tab in Octopi uses the system font (Noto Sans)?
Try Hack font in KDE Settings, please. Use whatever the default is in Konsole (it should use system setting's). Don't forget to reboot.
Thanks for the suggestion @Bro but I have done this and still the same result when using Octopi. Any other suggestions please?
Try downloading the Nerd Font version of the fonts you use. They have tons of symbols and glyphs built in. It is possible Octopi is asking for a symbol that your font package does not provide.
Tried downloading various Nerd Fonts and rebooted. Still the same result :-(. No issues with Manjaro or Arch previously or any other distro come to think of it. I want to stick with Garuda. Just one of those little annoyances but not a deal breaker but baffled.
Have you at least tried this?
