As you will see, I am a real newby. I tried the following with no success, am I doing it wrong? :
╭─kenb@ken in ~ took 21s
╰─λ garuda-inxi
garuda-inxi may be found in the following packages:
chaotic-aur/garuda-common-settings 2.5.4-2 /usr/bin/garuda-inxi
chaotic-aur/garuda-common-settings-git 2.5.4.r2.g8a209d0-1 /usr/bin/garuda-inxi
╭─kenb@ken in ~ took 1s
[🔍] × sudo garuda-inxi
sudo: garuda-inxi: command not found
Mmm, your kernel is updated but you don't have garuda-inxi.
This probably means that your pacman.conf does not include the Chaotic AUR.
To include chaotic-aur in your /etc/pacman.conf add at the end
[chaotic-aur]
Include = /etc/pacman.d/chaotic-mirrorlist
╭─kenb@ken in ~
[🚫] × update
[sudo] password for kenb:
--> Refreshing mirrorlists using reflector, please be patient..
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2022-02-23 15:34:57 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2022-02-23 15:34:43 UTC
# Last Check: 2022-02-23 15:20:07 UTC
Server = https://mirror.lty.me/archlinux/$repo/os/$arch
Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
Server = https://mirror.luzea.de/archlinux/$repo/os/$arch
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
warning: config file /etc/pacman.conf, line 34: directive 'TotalDownload' in section 'options' not recognized.
core 132.9 KiB 22.9 KiB/s 00:06 [------------------------------------] 100%
extra 1538.4 KiB 3.26 MiB/s 00:00 [------------------------------------] 100%
community 6.1 MiB 5.40 MiB/s 00:01 [------------------------------------] 100%
multilib 149.2 KiB 1166 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur 1504.7 KiB 136 KiB/s 00:11 [------------------------------------] 100%
--> Applying keyring updates before starting full system update..
warning: archlinux-keyring-20220125-1 is up to date -- skipping
warning: chaotic-keyring-20220220-1 is up to date -- skipping
warning: garuda-hotfixes-1.1.1-1 is up to date -- skipping
there is nothing to do
spawn pacman -Su
Parsing man pages and writing completions to /home/kenb/.local/share/fish/generated_completions/
4409 / 4409 : zramctl.8.gz
Checking for plugin updates
Nothing to install / update
System updated! 🐧
To be honest, this surprises me a bit.
Adding chaotic-mirrorlist I expeceted a whole lot of updates...
Hold on, I hope someone can jump in and check what might be going on.
The update was not necessarily supposed to solve your issues though, but I'd start fixing that...
When I open the Konsole, the following info is given and I don't know if this could have anything to do with the issue. Just thinking if the system doesn't like it that perhaps it should be exorcised:
[WARN] - (starship::configs::starship_root): Unknown config key 'docker'
[WARN] - (starship::configs::starship_root): Did you mean 'docker_context'?
[WARN] - (starship::configs::starship_root): Unknown config key 'haskell'
[WARN] - (starship::configs::starship_root): Did you mean 'shell'?
[WARN] - (starship::configs::character): Unknown config key 'use_symbol_for_status'
No, that's not a big problem (no exorcist needed ), and can be fixed resetting starship to the default config from the Garuda Assistant, flagging it and pushing the reset button.
Or from terminal with:
Again thanks for your help so far. Do I need to do anything to encourage any other guru's to have a look at this issue, or is is more a case of waiting till someone has the time to spare?
Sorry for the delay. Was away from the computer for a bit. Here is the requested info:
╭─kenb@ken in ~
╰─λ sudo btrfs subvolume list /
ID 257 gen 55487 top level 5 path @home
ID 258 gen 55473 top level 5 path @root
ID 259 gen 36112 top level 5 path @srv
ID 260 gen 55487 top level 5 path @cache
ID 261 gen 55487 top level 5 path @log
ID 262 gen 55485 top level 5 path @tmp
ID 391 gen 55350 top level 5 path timeshift-btrfs/snapshots/2022-02-19_19-28-42/@
ID 502 gen 55350 top level 5 path timeshift-btrfs/snapshots/2022-02-18_09-33-16/@
ID 505 gen 53423 top level 5 path timeshift-btrfs/snapshots/2022-02-22_17-00-51/@
ID 508 gen 55350 top level 5 path timeshift-btrfs/snapshots/2022-02-20_19-08-29/@
ID 509 gen 55350 top level 5 path timeshift-btrfs/snapshots/2022-02-20_19-09-50/@
ID 510 gen 53423 top level 5 path timeshift-btrfs/snapshots/2022-02-22_12-00-01/@
ID 511 gen 53423 top level 5 path timeshift-btrfs/snapshots/2022-02-22_12-13-08/@
ID 513 gen 53423 top level 5 path timeshift-btrfs/snapshots/2022-02-22_15-13-03/@
ID 514 gen 55487 top level 5 path @
ID 515 gen 53423 top level 5 path timeshift-btrfs/snapshots/2022-02-22_17-15-56/@
ID 516 gen 53224 top level 5 path timeshift-btrfs/snapshots/2022-02-22_17-15-56/@home
ID 517 gen 55285 top level 5 path timeshift-btrfs/snapshots/2022-02-22_18-57-07/@
ID 518 gen 54994 top level 5 path timeshift-btrfs/snapshots/2022-02-23_09-22-17/@
ID 519 gen 55016 top level 5 path timeshift-btrfs/snapshots/2022-02-23_09-31-43/@
ID 520 gen 55190 top level 5 path timeshift-btrfs/snapshots/2022-02-23_10-42-48/@
ID 521 gen 55216 top level 5 path timeshift-btrfs/snapshots/2022-02-23_10-55-11/@
ID 522 gen 55350 top level 5 path timeshift-btrfs/snapshots/2022-02-23_12-00-01/@
ID 523 gen 55459 top level 5 path timeshift-btrfs/snapshots/2022-02-23_12-54-14/@
ID 524 gen 55479 top level 5 path timeshift-btrfs/snapshots/2022-02-23_12-57-02/@
╭─kenb@ken in ~ as 🧙 took 6s
╰─λ
All issues except this crazy boot issue seem resolved. When I try using any one of the possible listed boot choices, it just jumps right back to that single choice and will not even try to boot on it. I then hit return, let it just boot Garuda after the 5 second delay, and it usually will just get into the Kde portion where there is the three little dots with a > sign, seem to be trying run, then the little spinning gear symbol fades away and that is the end of that. The drive light will stay on, and so I assume it is still trying to read something, but even after 2 hours nothing has happened.
