I don't know. I may have done so, but if so it was not intentional. At any rate, I got back to the desired desktop with the standard system settings.
Here are the requested subvolume lists:
╭─kenb@ken in ~
╰─λ sudo btrfs subvolume list /
[sudo] password for kenb:
ID 257 gen 55670 top level 5 path @home
ID 258 gen 55602 top level 5 path @root
ID 259 gen 36112 top level 5 path @srv
ID 260 gen 55670 top level 5 path @cache
ID 261 gen 55670 top level 5 path @log
ID 262 gen 55611 top level 5 path @tmp
ID 514 gen 55603 top level 5 path timeshift-btrfs/snapshots/2022-02-23_14-59-40/@
ID 517 gen 55285 top level 5 path timeshift-btrfs/snapshots/2022-02-22_18-57-07/@
ID 518 gen 54994 top level 5 path timeshift-btrfs/snapshots/2022-02-23_09-22-17/@
ID 519 gen 55016 top level 5 path timeshift-btrfs/snapshots/2022-02-23_09-31-43/@
ID 520 gen 55190 top level 5 path timeshift-btrfs/snapshots/2022-02-23_10-42-48/@
ID 521 gen 55216 top level 5 path timeshift-btrfs/snapshots/2022-02-23_10-55-11/@
ID 522 gen 55350 top level 5 path timeshift-btrfs/snapshots/2022-02-23_12-00-01/@
ID 523 gen 55459 top level 5 path timeshift-btrfs/snapshots/2022-02-23_12-54-14/@
ID 524 gen 55479 top level 5 path timeshift-btrfs/snapshots/2022-02-23_12-57-02/@
ID 525 gen 55600 top level 5 path timeshift-btrfs/snapshots/2022-02-23_14-36-54/@
ID 526 gen 55668 top level 5 path @
╭─kenb@ken in ~ as 🧙 took 5s
╰─λ
I don't know if it is of any value, but one phenomenon that i have noted is that if I do a restart (or shutdown and restart) and then -- rather than let the system just do its 5 second countdown and then boot, -- I go down and select a snapshot -- it will simply not do it. It will show the snapshot and some info lines below that, but if I then select the snapshot (top line) it will briefly look like it is going to load then just jump right back to the same page -- i.e. will not load
You posted twice the subvolume list. Please post
sudo timeshift --check
I'm just willing to check JSON file errore, since I remember from the past some timeshift issues due corrupted JSON files.
Here is what you asked, sorry for last wrong post:
╭─kenb@ken in ~
╰─λ sudo timeshift --check
Using system disk as snapshot device for creating snapshots in BTRFS mode
/dev/sda1 is mounted at: /run/timeshift/backup, options: rw,relatime,compress=zstd:3,ssd,space_cache,autodefrag,subvolid=5,subvol=/
Daily snapshots are enabled
Last daily snapshot is 4 hours old
╭─kenb@ken in ~ as 🧙 took 7s
╰─λ
This probably won't help, but I've just received an update for grub-btrfs
, the package that creates the snapshots sub-menu.
Try to update
, just in case...
Thanks for suggestion. Made some improvement in this sense:
(A) Still will only sporadically get past Kde freeze if i simply allow the countdown timeout/autoboot, but
(B) If I arrow down and choose a snapshot and then on the popup click on either of the lines below the top (both almost the same but one one includes word "fallback), then the system will boot OK.
Whenever it does finally boot, everything works perfectly, and I love it, so I would dearly love to get past this little startup irritation. I sure do appreciate the efforts you all have made.
