Audio output went mono (right only) from stereo after kernel updating; it might be an imagined coincidence but the result was perceived to occur after a bunch of Haskell pkgs came into the usual Garuda Assistant System Update batch stream.
I use Analog Surround 4.0 Output + Analog Stereo Input to keep mic available.
In the past I have had success solving audio issues by turning Pulse Audio off and keeping Pipewire, but it has not helped in this case.
I tried to apply a solution from the forum from May using the jamesDSP audio settings but package manager is failing to download from both AUR and ChaoticAur returning fail message "Error: Failed to prepare transaction invalid or corrupted database."
Any suggestions are appreciated, thx!
╰─λ garuda-inxi
Kernel: 6.4.10-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc available: hpet,acpi_pm parameters: pti=on
root=UUID=321c5cef-bd09-4999-9d16-79b9c9e0a513 rw rootflags=subvol=@
resume=UUID=54cfc0b3-0cca-4092-99bd-537dea8573e1 loglevel=3 quiet ibt=off
Type: Laptop System: LENOVO product: 20CMS06V00 v: ThinkPad X250
Mobo: LENOVO model: 20CMS06V00 v: SDK0E50510 WIN
serial: <superuser required> UEFI: LENOVO v: N10ET54W (1.33 )
date: 09/18/2018
ID-1: BAT0 charge: 16.0 Wh (94.7%) condition: 16.9/23.2 Wh (72.9%)
volts: 11.9 min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
status: not charging
ID-2: BAT1 charge: 16.7 Wh (94.9%) condition: 17.6/23.2 Wh (75.9%)
volts: 11.5 min: 11.1 model: SANYO 45N1775 type: Li-ion serial: <filter>
Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1548 high: 2900 min/max: 500/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2900 2: 500 3: 500
4: 2295 bogomips: 18367
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-8:5 chip-ID: 5986:0366
class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: LG Display 0x03ed built: 2012 res: 1366x768 hz: 60
dpi: 125 gamma: 1.2 size: 277x156mm (10.91x6.14") diag: 318mm (12.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
API: ALSA v: k6.4.10-hardened1-1-hardened status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pw-jack type: plugin
Device-1: Intel Ethernet I218-LM vendor: Lenovo driver: e1000e v: kernel
port: 3080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095b class-ID: 0280
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-4: wwp0s20u4 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 42.32 GiB (8.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apacer model: AS350 512GB
tech: SSD serial: <filter> fw-rev: 3PE0 scheme: GPT
used: 42.32 GiB (9.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 47.0 C pch: 45.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 3059
Processes: 207 Uptime: 1h 46m wakeups: 1 Memory: total: 8 GiB
available: 7.65 GiB used: 3.21 GiB (42.0%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1615 libs: 363 tools: octopi,pamac,paru
inxi: 3.3.29
error: blackarch: signature from "Levon 'noptrix' Kayan (BlackArch Developer) <noptrix@nullsecurity.net>" is invalid
System install date: 2023-02-17
Last full system update: 2023-08-19
Edit:
Please wrap your future terminal output texts like this
Terminal text here
Makes it easier to read. I did it for you for now.
