This is new to me, everything been working fine and then all the sudden when I use ssh, this happens.
emacs: Terminal type alacritty is not defined.
If that is not the actual type of terminal you have,
use the Bourne shell command `TERM=... export TERM' (C-shell:
`setenv TERM ...') to specify the correct type. It may be necessary
to do `unset TERMINFO' (C-shell: `unsetenv TERMINFO') as well.
Should $TERM be xterm-256color since default /home/X/.config/alacritty/alacritty.yml states
env:
# TERM variable
# This value is used to set the `$TERM` environment variable for
# each instance of Alacritty. If it is not present, alacritty will
# check the local terminfo database and use `alacritty` if it is
# available, otherwise `xterm-256color` is used.
TERM: xterm-256color
