Spectacle "record" doesn't work
When I manually run “Record Screen - Spectacle”.
The little “recording, click to stop” icon appears in the taskpane. But when I click it. Nothing gets saved to the output folder.
If i run spectale from the terminal and do the same thing.
I get this
spectacle
kpipewire_vaapi_logging: VAAPI: Intel iHD driver for Intel(R) Gen Graphics - 25.2.1 () in use for device "/dev/dri/renderD130"
qt.multimedia.ffmpeg: Using Qt multimedia with FFmpeg version n7.1.1 GPL version 3 or later
fish: Job 1, 'spectacle' terminated by signal SIGSEGV (Address boundary error)
My system below
λ sudo garuda-inxi
[sudo] password for stephen:
  Kernel: 6.14.6-1-cachyos-bore arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos-bore
    root=UUID=a840e5a0-d1a3-432e-a9a3-27dcb3be0edb rw rootflags=subvol=@
    quiet rd.luks.uuid=2ced48d8-31af-4dc4-b649-ea7c98869a87
    rd.luks.uuid=686e7718-1e79-4df8-bc43-86b3f9f5f883
    resume=/dev/mapper/luks-686e7718-1e79-4df8-bc43-86b3f9f5f883 loglevel=3
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Desktop System: Alienware product: Alienware Aurora R9 v: 1.0.26
    serial: <filter> Chassis: type: 3 serial: <filter>
  Mobo: Alienware model: 0T76PD v: A01 serial: <filter> part-nu: 0961
    uuid: 4c4c4544-0036-3010-8035-c4c04f483033 UEFI: Alienware v: 1.0.26
    date: 11/22/2023
  ID-1: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
    model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
    serial: <filter> status: full
  Info: model: Intel Core i9-9900KS socket: LGA1151 (U3E1) note: check
    bits: 64 type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
    stepping: 0xD (13) microcode: 0x104
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
    desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 4698 min/max: 800/5200 base/boost: 4000/8300 scaling:
    driver: intel_pstate governor: powersave volts: 1.2 V ext-clock: 100 MHz
    cores: 1: 4698 2: 4698 3: 4698 4: 4698 5: 4698 6: 4698 7: 4698 8: 4698
    9: 4698 10: 4698 11: 4698 12: 4698 13: 4698 14: 4698 15: 4698 16: 4698
    bogomips: 127999
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
    ports: active: none empty: DP-7,HDMI-A-3 bus-ID: 0000:00:02.0
    chip-ID: 8086:3e98 class-ID: 0380
  Device-2: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Dell
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 ports:
    active: none off: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 0000:01:00.0
    chip-ID: 10de:1e81 class-ID: 0300
  Device-3: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Dell
    active: none empty: DP-4, DP-5, DP-6, HDMI-A-2 bus-ID: 0000:02:00.0
  Device-4: Realtek NexiGo N660P FHD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-14.4.1:10
    chip-ID: 0bda:0567 class-ID: 0102 serial: <filter>
  Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
    gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1355x381mm (53.35x15.00")
    s-diag: 1408mm (55.42")
  Monitor-1: DP-2 note: disabled model: Samsung LC49G95T serial: <filter>
    built: 2245 res: mode: 5120x1440 hz: 120 scale: 100% (1) dpi: 109 gamma: 1.2
    size: 1193x336mm (46.97x13.23") diag: 1239mm (48.8") modes: max: 3840x1080
    min: 640x480
    platforms: device: 0 drv: nvidia device: 1 drv: nvidia device: 2 drv: iris
    device: 3 drv: nouveau device: 4 drv: nouveau device: 5 drv: swrast gbm:
    drv: iris surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080
    SUPER/PCIe/SSE2 memory: 7.81 GiB
  API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 2080 SUPER driver: nvidia v: 570.144 device-ID: 10de:1e81
    surfaces: N/A device: 1 type: discrete-gpu name: NVIDIA GeForce RTX 2080
    SUPER driver: nvidia v: 570.144 device-ID: 10de:1e81 surfaces: N/A
    device: 2 type: integrated-gpu name: Intel UHD Graphics 630 (CFL GT2)
    driver: mesa intel v: 25.1.0-cachyos1.4 device-ID: 8086:3e98 surfaces: N/A
    device: 3 type: cpu name: llvmpipe (LLVM 19.1.7 256 bits)
    driver: mesa llvmpipe v: 25.1.0-cachyos1.4 (LLVM 19.1.7)
  Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 0000:00:1f.3 chip-ID: 8086:a2f0
  Device-2: NVIDIA TU104 HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:10f8 class-ID: 0403
  Device-3: NVIDIA TU104 HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 0000:02:00.1 chip-ID: 10de:10f8 class-ID: 0403
  API: ALSA v: k6.14.6-1-cachyos-bore status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.2 status: n/a (root, process) with:
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:04:00.0
    chip-ID: 168c:003e class-ID: 0280
  Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Dell
    driver: alx v: kernel port: c000 bus-ID: 0000:05:00.0 chip-ID: 1969:e0b1
  IF-ID-1: br-294d6380f102 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-2: br-545481fcdcff state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-3: br-eab677a55dcb state: down mac: <filter>
  IF-ID-4: docker0 state: down mac: <filter>
  IF-ID-5: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  IF-ID-6: veth431a0e9 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-7: vethc07d5df state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 0cf3:e007
    rfk-block: hardware: no software: no address: <filter> bt-v: 5.0 lmp-v: 9
  Hardware-1: Intel SATA Controller [RAID mode] driver: intel_nvme_remap
    v: kernel port: f060 bus-ID: 0000:00:17.0 chip-ID: 8086:2822 rev:
    class-ID: 0104
  Supported mdraid levels: raid0
  Device-1: md127 maj-min: 9:127 type: mdraid level: raid-0 status: active
    state: clean size: 1.82 TiB
  Info: report: N/A blocks: 1953260544 chunk-size: 512k super-blocks: 1.2
  Components: Online:
  0: sdc maj-min: 8:32 size: 931.51 GiB state: active sync
  1: sdb maj-min: 8:16 size: 931.51 GiB state: active sync
  Local Storage: total: raw: 11.37 TiB usable: 11.37 TiB used: 1.4 TiB (12.3%)
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B tech: SSD
    serial: <filter> fw-rev: 4B2QJXD7 temp: 38.9 C scheme: GPT
  SMART: yes health: PASSED on: 138d 10h cycles: 426
    read-units: 4,962,137 [2.54 TB] written-units: 14,836,455 [7.59 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
    family: Micron Client SSDs size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 023 temp: 36 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 230d 6h cycles: 2600
    written: 4.14 TiB
  ID-3: /dev/sdb maj-min: 8:16 vendor: Smart Modular Tech.
    model: SHGS31-1000GS-2 family: SATA SSDs size: 931.51 GiB block-size:
    physical: 4096 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 0Q00 temp: 34 C
  SMART: yes state: enabled health: PASSED on: 135d 12h cycles: 2063
    Old-Age: threshold: 1
  ID-4: /dev/sdc maj-min: 8:32 vendor: Smart Modular Tech.
    serial: <filter> fw-rev: 0Q00 temp: 29 C
  SMART: yes state: enabled health: PASSED on: 1y 269d 17h cycles: 2063
  ID-5: /dev/sdd maj-min: 8:48 vendor: HGST (Hitachi) model: HUS728T8TALE6L4
    family: Ultrastar HC310/320 size: 7.28 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    sata: 3.2 speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 5006 drive-rev: V8GNW980 temp: 24 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 135d 8h cycles: 5248
  ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 193.53 GiB (10.8%)
    fs: btrfs block-size: 4096 B dev: /dev/dm-1 maj-min: 253:1
    mapped: luks-2ced48d8-31af-4dc4-b649-ea7c98869a87
    used: 780 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
    used: 193.53 GiB (10.8%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
    maj-min: 253:1 mapped: luks-2ced48d8-31af-4dc4-b649-ea7c98869a87
  ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
  ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
  ID-1: swap-1 type: partition size: 68.88 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-686e7718-1e79-4df8-bc43-86b3f9f5f883
  ID-2: swap-2 type: zram size: 62.62 GiB used: 1.3 MiB (0.0%) priority: 100
  System Temperatures: cpu: 45.0 C mobo: N/A
  Memory: total: 64 GiB available: 62.62 GiB used: 7.1 GiB (11.3%)
  Processes: 414 Power: uptime: 3h 41m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1735 libs: 461 tools: octopi,paru Compilers:
    clang: b536128bd29a83a26c0aafda19942995b30fc5fd alt: 19 gcc: 15.1.1
    Shell: garuda-inxi (sudo) default: Bash v: 5.2.37 running-in: ghostty
    inxi: 3.3.38
  System install date:     2024-10-08
  Last full system update: 2025-05-22 ↻
  Windows dual boot:       Yes
hi redragonx,
please update and try again. There is a waiting reboot too. :wink:
No need for sudo, we just ask about garuda-inxi :slight_smile:
There are no secret data now in your log, I hope :slight_smile:
lol, updates don’t fix this. Been an issue for a few months now over many updates.
im sorry to hear that isnt working did you search here in the Forum for some tipps? i dont have intel and nvidia .
i found this Topic may it helps you out .
This is caused by the libva-vdpau-driver package on Arch. Removing that should fix it.
Hey,
I saw this post but I’m not sure which part applies to me. Here are the packages i can remove. 3 in total. Thx for your help.
Im not a Nvidia User. this looks not to bad here leave it first..
please wait for more nvidia users i just can read and gues . I can mess up my system for any stuff but not recommended for normal user :wink:
Did you try to install the open driver?
For your graphics card, it is recommended to use nvidia-open-dkms
you have a touring card tu if i see correctly.
grafik
in terminal:
sudo pacman -S nvidia-open-dkms
Please do not post any pictures of the terminal. Please always use a code block for terminal output. Thanks. :slight_smile:
Please leave everything as it is and post the output of:
pacman -Qs vdpau
so that we can see which relevant packages are installed.
If the package libva-vdpau-driver is displayed in the list, simply remove it with :
sudo pacman -R libva-vdpau-driver
and then reboot.
No, the packiage is not installed.
local/lib32-mesa 1:25.1.1-2
    Open-source OpenGL drivers - 32-bit
local/libvdpau 1.5-3.1
    Nvidia VDPAU library
local/libvdpau-va-gl 0.4.2-4.1
    VDPAU driver with OpenGL/VAAPI backend
local/mesa 1:25.1.1-2
local/vdpauinfo 1.5-2.1
    Command line utility for querying the capabilities of a VDPAU device
