Maybe upstream is a better place to post, but i love you all, so i’m trying here. I’ve already done what’s in AUR wiki and some posts here:
Connecting to my computer via VPN / xrdp doesn’t work, i’m getting some connection issues thrown. When i switch from Xorg session to Xvnc, the desktop loads (YAY!). I’m wondering if there is a way i can avoid having to wait for the connection to fail before specifying Xvnc? I’m remoting from a 2014 Macbook Pro on Big Sur 11.6.8. Nothing in the mac rdp client seems to be labeled in a way that makes me think it will specify that.
journalctl -fu xrdp
Aug 16 14:01:43 dragonfruit xrdp[1450208]: [INFO ] connecting to sesman on 127.0.0.1:3350
Aug 16 14:01:43 dragonfruit xrdp[1450208]: [INFO ] xrdp_wm_log_msg: sesman connect ok
Aug 16 14:01:43 dragonfruit xrdp[1450208]: [INFO ] sesman connect ok
Aug 16 14:01:43 dragonfruit xrdp[1450208]: [INFO ] sending login info to session manager. Please wait...
Aug 16 14:01:43 dragonfruit xrdp[1450208]: [INFO ] xrdp_wm_log_msg: login successful for user meredith on display 10
Aug 16 14:01:43 dragonfruit xrdp[1450208]: [INFO ] login successful for user meredith on display 10
Aug 16 14:01:43 dragonfruit xrdp[1450208]: [INFO ] loaded module 'libxup.so' ok, interface size 10296, version 4
Aug 16 14:01:43 dragonfruit xrdp[1450208]: [INFO ] started connecting
Aug 16 14:01:43 dragonfruit xrdp[1450208]: [INFO ] lib_mod_connect: connecting via UNIX socket
Aug 16 14:04:54 dragonfruit xrdp[1446754]: [INFO ] connection problem, giving up
Aug 16 14:04:54 dragonfruit xrdp[1446754]: [INFO ] some problem
Aug 16 14:04:54 dragonfruit xrdp[1446754]: [ERROR] xrdp_wm_log_msg: Error connecting to user session
Aug 16 14:04:54 dragonfruit xrdp[1446754]: [INFO ] Error connecting to user session
Aug 16 14:04:54 dragonfruit xrdp[1446754]: [ERROR] xrdp_sec_recv: xrdp_mcs_recv failed
Aug 16 14:04:54 dragonfruit xrdp[1446754]: [ERROR] xrdp_rdp_recv: xrdp_sec_recv failed
Aug 16 14:04:54 dragonfruit xrdp[1446754]: [ERROR] libxrdp_process_data: xrdp_rdp_recv failed
Aug 16 14:04:54 dragonfruit xrdp[1446754]: [ERROR] xrdp_process_data_in: xrdp_process_loop failed
Aug 16 14:04:54 dragonfruit xrdp[1446754]: [ERROR] SSL_shutdown: I/O error
Aug 16 14:05:14 dragonfruit xrdp[1450208]: [INFO ] connection problem, giving up
Aug 16 14:05:14 dragonfruit xrdp[1450208]: [INFO ] some problem
Aug 16 14:05:14 dragonfruit xrdp[1450208]: [ERROR] xrdp_wm_log_msg: Error connecting to user session
Aug 16 14:05:14 dragonfruit xrdp[1450208]: [INFO ] Error connecting to user session
Waiting for this connection to fail, then switching the session to Xvnc loads graphics settings.
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f6cccf9c-8580-435e-8f33-927e3e31bb2d
resume=UUID=2e9cba84-8fd3-4884-995e-6ac1c54716ad loglevel=3 ibt=off
Console: pty pts/1 DM: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF serial: <superuser required>
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <superuser required> UEFI: American
Megatrends LLC. v: F34 date: 06/10/2021
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 3 built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache: L1: 1024 KiB desc: d-16x32
KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3633 high: 4580 min/max: 2200/4761 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 4580 2: 3587 3: 3587 4: 3594 5: 3598
6: 3590 7: 3586 8: 3578 9: 3672 10: 3907 11: 3593 12: 3589 13: 3592 14: 3592 15: 3590
16: 3592 17: 3592 18: 3594 19: 3594 20: 3593 21: 3592 22: 3584 23: 3589 24: 3592 25: 3591
26: 3591 27: 3591 28: 3589 29: 3590 30: 3593 31: 3592 32: 3588 bogomips: 223580
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP: always-on, RSB filling
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of 2022-07)
arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 0a:00.0 chip-ID: 10de:1e84 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-3.4.3:7 chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-3: Focusrite-Novation Scarlett 2i2 Camera type: USB driver: snd-usb-audio
bus-ID: 7-2:2 chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia tty: 128x32
Message: GL data unavailable in console. Try -G --display
Device-1: YUAN High-Tech Development vendor: Corsair Memory driver: N/A bus-ID: 1-3.4.3:7 pcie:
gen: 1 chip-ID: 046d:085c speed: 2.5 GT/s class-ID: 0102 serial: <filter> lanes: 1
bus-ID: 06:00.0 chip-ID: 12ab:0380 class-ID: 0480
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 0a:00.1
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Logitech C922 Pro Stream Webcam type: USB driver: snd-usb-audio,uvcvideo
Device-5: Texas Instruments ATH-G1WL type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-3.4.4:8 chip-ID: 0451:16ba class-ID: 0300 serial: <filter>
Device-6: Focusrite-Novation Scarlett 2i2 Camera type: USB driver: snd-usb-audio
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.56 running: no
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
Local Storage: total: 4.57 TiB used: 840.05 GiB (18.0%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SanDisk model: ADATA SX6000PNP size: 953.87 GiB
rev: V9002s85 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: WDS100T1XHE-00AFY0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 614600WD temp: 36.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EARX-00ZUDB0 size: 1.82 TiB
serial: <filter> rev: 0A80 scheme: GPT
ID-1: / raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 363.38 GiB (40.5%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 363.38 GiB (40.5%)
ID-4: /var/log raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 363.38 GiB (40.5%)
ID-5: /var/tmp raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 363.38 GiB (40.5%)
ID-1: swap-1 type: zram size: 31.29 GiB used: 1.8 MiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 34.49 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
System Temperatures: cpu: 34.4 C mobo: 29.0 C gpu: nvidia temp: 28 C
Processes: 477 Uptime: 2h 39m wakeups: 0 Memory: 31.29 GiB used: 4.99 GiB (16.0%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.1.1 alt: 11 clang: 14.0.6
Packages: pacman: 2214 lib: 555 Shell: Bash v: 5.1.16 running-in: pty pts/1 (SSH) inxi: 3.3.20
Garuda (2.6.5-1):
System install date: 2022-01-22
Last full system update: 2022-08-16
