hej guys, i am using garuda for few months and now i have an issue i cant solve by my own… my sound card settings are not right by default and i want to change standard configuration. sadly i cant find any solution for my problem, so i am politely asking you guys:
How can i change order of devices of a soundcard?!
first device is Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP and i want to change (second device) Advanced Micro Devices [AMD] Family 17h/19h HD Audio to main device.
here my garuda-inxi:
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=5e705751-c037-4ef3-b238-ec9e95e6a02d rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DY_FX505DY v: 1.0
Mobo: ASUSTeK model: FX505DY v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: FX505DY.315
date: 03/09/2020
ID-1: BAT0 charge: 14.4 Wh (45.1%) condition: 31.9/48.0 Wh (66.5%)
power: 18.1 W volts: 11.7 min: 11.7 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: discharging
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
stepping: 1 microcode: 0x8108102
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2100 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 33537
Device-1: Advanced Micro Devices [AMD/ATI] Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.0 chip-ID: 1002:67ef class-ID: 0380 temp: 37.0 C
Device-2: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 37.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 13d3:56a2
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven LLVM 18.1.8 DRM 3.57 6.10.10-zen1-1-zen)
device-ID: 1002:15d8 memory: 250 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 24.2.3-arch1.1
device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: AMD Radeon RX 560 Series (RADV POLARIS11)
driver: mesa radv v: 24.2.3-arch1.1 device-ID: 1002:67ef
18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.3-arch1.1 (LLVM 18.1.8)
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pw-jack type: plugin
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 13d3:3530
Local Storage: total: 476.94 GiB used: 371.08 GiB (77.8%)
model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size: physical: 512 B
fw-rev: P1MA0V4 temp: 38.9 C scheme: GPT
used: 371.08 GiB (77.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.31 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.2 C mobo: N/A
Fan Speeds (rpm): cpu: 2300
GPU: device: amdgpu temp: 38.0 C watts: 7.25 device: amdgpu temp: 37.0 C
Memory: total: 16 GiB note: est. available: 15.31 GiB used: 4.47 GiB (29.2%)
Processes: 282 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1667 libs: 552 tools: gnome-software, octopi,
pamac, paru Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date: 2024-06-23
Last full system update: 2024-10-01
looking forward for some helpful advices, thank you guys in advance <3
if further information is needed i will post them as soon as possible.
