I tryed out some Equalizers a few days ago. In the progress of finding the one which works the best for me I installed and deinstalled pipewire for pulse and the other way around.
When I found the best equalizer, for me it was EasyEffects, everything worked perfectly fine.
But the next day I started my Computer and I cant find the sound settings as well as the sound miniprogramm in the Top Panel anymore. So I cant change the output device how I used to. Im still able to change it with EasyEffects but thats quite annoying.
I already tryed going in to a snapshot but I tryed so many different things that the auto creating adn deleting of snapshots deleted the working one.
I also tryed deleating all sound things like pipewire, pulse and alsa. But the Systemsettings are not coming back. Also deleting EasyEffects does not help. Already tryed to find someone with the same issue but there only where people who didnt have sounds or there sound is bugging but thats not true for me.
Here are some pics of what I see now:
Before my problem accured there where Settings to change the Volume of the different Audiooutputs and also of programs.
Thanks for your help guys
Kernel: 6.11.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=ee782abc-5ff0-4f18-b2b2-6eb783f0a236 rw rootflags=subvol=@
quiet resume=UUID=86a90f43-5b8a-439e-978b-637d131b46a4 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop System: Gigabyte product: B550I AORUS PRO AX v: N/A
Mobo: Gigabyte model: B550I AORUS PRO AX v: x.x
Megatrends LLC. v: F15 date: 01/04/2022
Device-1: ps-controller-battery-a4:53:85:80:bf:d6 model: N/A serial: N/A
charge: N/A status: full
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3592 min/max: 550/4651 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3592 2: 3592 3: 3592
4: 3592 5: 3592 6: 3592 7: 3592 8: 3592 9: 3592 10: 3592 11: 3592 12: 3592
bogomips: 88632
Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: nvidia
v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-1 empty: DP-2, DVI-D-1, HDMI-A-1, HDMI-A-2
bus-ID: 0b:00.0 chip-ID: 10de:1b83 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-1 mapped: DP-0 note: disabled model: Gigabyte G27QC A
serial: <filter> built: 2023 res: 2560x1440 hz: 165 dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 memory: 5.86 GiB
API: Vulkan v: 1.3.295 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 6GB driver: nvidia v: 560.35.03 device-ID: 10de:1b83
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256
bits) driver: mesa llvmpipe v: 24.2.3-arch1.1 (LLVM 18.1.8)
Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
bus-ID: 0b:00.1 chip-ID: 10de:10f0 class-ID: 0403
lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis Nova Pro Wireless
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 1038:12e0 class-ID: 0300
Device-4: Sony DualShock 4 [CUH-ZCT2x]
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-4:4 chip-ID: 054c:09cc class-ID: 0300
API: ALSA v: k6.11.1-zen1-1-zen status: kernel-api with: 1: aoss
type: oss-emulator 2: apulse type: pulse-emulator
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 14c3:0608
IF: wlp10s0 state: up mac: <filter>
Device-3: ASUSTek ROG GIII WIRELESS AIMPOINT driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3
chip-ID: 0b05:1a72 class-ID: 0300 serial: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 0e8d:0608
Local Storage: total: 3.64 TiB used: 886.89 GiB (23.8%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 43.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 45.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: GPT
ID-1: / raw-size: 78.12 GiB size: 78.12 GiB (100.00%)
used: 48.87 GiB (62.5%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:8
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:7
ID-3: /home raw-size: 292.97 GiB size: 292.97 GiB (100.00%)
used: 53.11 GiB (18.1%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:10
ID-4: /var/log raw-size: 78.12 GiB size: 78.12 GiB (100.00%)
ID-5: /var/tmp raw-size: 78.12 GiB size: 78.12 GiB (100.00%)
ID-2: swap-2 type: partition size: 46.87 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:9
System Temperatures: cpu: 50.2 C mobo: 42.0 C gpu: nvidia temp: 47 C
Memory: total: 32 GiB available: 31.25 GiB used: 4.82 GiB (15.4%)
Processes: 431 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1932 libs: 582 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-06-08
Last full system update: 2024-10-02
Failed units: run-media-GamingSSD.mount
