Sound Quality with JamesDSP for Sound Blaster AE5 Plus
Hi, I have been trying to get my sound card to sound better, I have a Sound Blaster AE5 Plus and it sounds muffled. I have searched and found this thread:
I have downloaded the .irs files but when I paste them in the location indicated the JamesDSP application does not recognise them:
I’ve seen on other sites that you have to rename the files to .wav, but it still can’t recognise them even though they show up in the Convolvert tab:
I know absolutely nothing about sound, do I have to convert the .irs files with some kind of tool, have I missed a step in between?
Thank you very much in advance, any information that enlightens me is appreciated.
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1b079d8b-58a3-4533-8245-22b97207f1e1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Desktop System: Gigabyte product: Z390 AORUS PRO v: N/A
Mobo: Gigabyte model: Z390 AORUS PRO-CF serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F13 date: 12/21/2023
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0x100
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
bogomips: 115200
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Gigabyte
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none off: DP-2,DP-3
empty: DP-1,HDMI-A-1,Unknown-2 bus-ID: 01:00.0 chip-ID: 10de:1e81
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 3414x1920
display-ID: 0
Monitor-1: DP-2 pos: top-right res: 2048x1152 size: N/A modes: N/A
Monitor-2: DP-3 pos: bottom-l res: 1366x768 size: N/A modes: N/A
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080
SUPER/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2080 SUPER driver: nvidia v: 560.35.03 device-ID: 10de:1e81
Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
Device-2: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 1102:0012 class-ID: 0403
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 3.18 TiB used: 1.35 TiB (42.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P4CR313 temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1CH164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: MBR
used: 287.48 GiB (61.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 596 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 35.0 C pch: 49.0 C mobo: N/A
Memory: total: 32 GiB available: 31.27 GiB used: 5.45 GiB (17.4%)
Processes: 384 Power: uptime: 1h 34m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1979 libs: 576 tools: octopi,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date:     2024-08-17
Last full system update: 2024-10-29
What means Habilitar convolver?
Activate? :slight_smile:
Sorry, my English is not very good and I am using a translator.
I mean Convolver does not recognise .irs files.
If you’re asking me that ‘habilitar’ is to activate Convolver, yes, if you mean read those files.
I do not use it since it doesnt work together with my ear buds.
.rw-r--r-- 7,7M sgs 10 Jul 23:10  Church.wav
.rw-r--r-- 9,1k sgs 10 Jul 23:10  CorredHRTF_Crossfeed.wav
.rw-r--r--  10k sgs 10 Jul 23:10  CorredHRTF_Surround1.wav
.rw-r--r--  11k sgs 10 Jul 23:10  CorredHRTF_Surround2.wav
.rw-r--r-- 3,1k sgs 20 Sep  2023  game.wav
.rw-r--r-- 2,8k sgs 20 Sep  2023  movie.wav
.rw-r--r-- 3,0k sgs 20 Sep  2023  music-balanced.wav
.rw-r--r-- 4,9k sgs 10 Jul 23:10  SwapChannels.wav
.rw-r--r-- 1,0k sgs 20 Sep  2023  voice.wav
I cant download the irs files, above it show my old install on other DE.
I downloaded them two days ago, but it seems that they are not the same files, this are my files:
.rw-r--r-- 7,7M hudson  1 nov 13:12  Church.wav
.rw-r--r-- 9,1k hudson  1 nov 13:12  CorredHRTF_Crossfeed.wav
.rw-r--r--  10k hudson  1 nov 13:12  CorredHRTF_Surround1.wav
.rw-r--r--  11k hudson  1 nov 13:12  CorredHRTF_Surround2.wav
.rwxrwxrwx 6,4k hudson  1 ene  1980  game.wav
.rwxrwxrwx 6,4k hudson  1 ene  1980  movie.wav
.rwxrwxrwx 6,4k hudson  1 ene  1980  music-balanced.wav
.rw-r--r-- 4,9k hudson  1 nov 13:12  SwapChannels.wav
.rwxrwxrwx 6,4k hudson  1 ene  1980  voice.wav
I just tried to download them and I couldn’t download them either.
Any chance you can upload them again?
Hope it works :slight_smile:
It works!!! Thank you very much!
Edit.- I have tried it, but it seems to me that for my sound card, it works better with EQ on and Movie selected.
Anyway, I am very grateful to you. :+1:t3: :blush:
As I indicated before I have no sound knowledge to be able to edit these schemes, but trying the equalizer defaults sounds better than before.
