Hi Everyone,
Sadly when i started up Garuda today the sound was completely gone,
when i changed the sound settings from Pro Audio to Analog Stereo Duplex
the sound was back but i think Pro Audio sounds better.
How can i fix the Problem ?
Thanks for your Help in Advance
Oh and i just today learned how to put the Garuda-inix-output.txt here, so here it is
`` Kernel: 6.17.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=6e8735d8-1e93-4551-9fd5-ed882145d94c rw rootflags=subvol=@
quiet resume=UUID=ce075bb5-91be-4872-8c26-780ad4d5fb6b loglevel=3
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
Megatrends LLC. v: 2.60 date: 01/14/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1731 min/max: 567/4955 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1731 2: 1731 3: 1731
4: 1731 5: 1731 6: 1731 7: 1731 8: 1731 9: 1731 10: 1731 11: 1731 12: 1731
13: 1731 14: 1731 15: 1731 16: 1731 17: 1731 18: 1731 19: 1731 20: 1731
21: 1731 22: 1731 23: 1731 24: 1731 bogomips: 177610
Device-1: NVIDIA GA102 [GeForce RTX 3090] vendor: ASUSTeK driver: nvidia
v: 580.95.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-2
empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 2b:00.0 chip-ID: 10de:2204
Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-2 model: Acer S242HL serial: <filter> built: 2017 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2
memory: 23.44 GiB display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3090 driver: nvidia v: 580.95.05
device-ID: 10de:2204 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.4 256 bits) driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM
21.1.4) device-ID: 10005:0000 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: corectrl,nvidia-smi wl: wayland-info
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
bus-ID: 2b:00.1 chip-ID: 10de:1aef class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.17.6-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:9 chip-ID: 8087:0aa7
Local Storage: total: 4.55 TiB used: 47.52 GiB (1.0%)
fw-rev: 2B2QEXM7 temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD240 size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 0A scheme: GPT
ID-1: / raw-size: 200 GiB size: 200 GiB (100.00%) used: 21.76 GiB (10.9%)
used: 664 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 714.51 GiB size: 714.51 GiB (100.00%)
used: 25.76 GiB (3.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 200 GiB size: 200 GiB (100.00%)
used: 21.76 GiB (10.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 200 GiB size: 200 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.71 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 45.0 C mobo: N/A
Memory: total: 64 GiB note: est. available: 62.71 GiB used: 5.51 GiB (8.8%)
Processes: 547 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.02 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1978 libs: 533
tools: gnome-software,octopi,paru Compilers: clang: 21.1.4 gcc: 15.2.1
Shell: Bash v: 5.3.3 default: fish v: 4.1.2 running-in: konsole
inxi: 3.3.39
Garuda (2.11.1-1):
System install date: 2025-11-02
Garuda release: 251002
Last full system update: 2025-11-02
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
24/25 checks run in 0.98 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
