Simple monitor, SysMon and Thermal Monitor no longer show sensors or read them. However, System Monitor Sensor works fine.
inxi output
System: Kernel: 5.12.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=085d2ede-6f7a-43f2-af2c-9be58cac2afc rw
rootflags=subvol=@ resume=UUID=beaf6b19-e7e6-4274-97d2-60ae6d4c482d loglevel=3 amdgpu.dc=1
amdgpu.ppfeaturemask=0xffffffff mitigations=off
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: PRIME Z390-A v: Rev 1.xx serial: <filter> UEFI: American Megatrends v: 1802
date: 12/01/2020
CPU: Info: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 88796
Speed: 4300 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 4300 2: 4300 3: 4300 4: 4304 5: 4396 6: 4403
7: 4309 8: 4358 9: 4399 10: 4400 11: 4402 12: 4401
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
status: Vulnerable: __user pointer sanitization and usercopy barriers only; no swapgs barriers
Type: srbds status: Vulnerable
Type: tsx_async_abort status: Vulnerable
Graphics: Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0380
Device-2: Advanced Micro Devices [AMD/ATI] Vega 10 XL/XT [Radeon RX Vega 56/64] vendor: Micro-Star MSI
driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:687f class-ID: 0300
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: amdgpu,ati,intel
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2") s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-1 res: 1920x1080 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
Monitor-2: DisplayPort-3 res: 1920x1080 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL: renderer: Radeon RX Vega (VEGA10 DRM 3.40.0 5.12.15-zen1-1-zen LLVM 12.0.0) v: 4.6 Mesa 21.1.4
direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel
v: kernel bus-ID: 03:00.1 chip-ID: 1002:aaf8 class-ID: 0403
Device-3: C-Media Audio Adapter (Unitek Y-247A) type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-6.2:6 chip-ID: 0d8c:0014 class-ID: 0300
Sound Server-1: ALSA v: k5.12.15-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Network: Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: efa0 bus-ID: 00:1f.6
chip-ID: 8086:15bc class-ID: 0200
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-3:4 chip-ID: 0bda:8771
Drives: Local Storage: total: 1.59 TiB used: 276.22 GiB (16.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP500 size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: E7FM04.C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Sabrent model: N/A size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: RKT303.3 scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A02 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU650 size: 111.79 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 1C0 scheme: GPT
Partition: ID-1: / raw-size: 35 GiB size: 35 GiB (100.00%) used: 14.1 GiB (40.3%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 976 MiB size: 974.1 MiB (99.80%) used: 568 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 466.94 GiB size: 466.94 GiB (100.00%) used: 116.11 GiB (24.9%) fs: btrfs
dev: /dev/nvme1n1p1 maj-min: 259:5
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb1 maj-min: 8:17
Sensors: System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 39.0 C mem: 38.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1633
Info: Processes: 398 Uptime: 19m wakeups: 0 Memory: 15.47 GiB used: 3.41 GiB (22.0%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1722 pacman: 1711 lib: 484 flatpak: 11
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.05
note in the inxi output the lack of sensors listed. lmsesnors is installed and works:
sensors output
nvme-pci-0700
Adapter: PCI adapter
Composite: +31.9°C (low = -0.1°C, high = +74.8°C)
(crit = +79.8°C)
acpitz-acpi-0
Adapter: ACPI interface
temp1: +27.8°C (crit = +119.0°C)
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +37.0°C (high = +82.0°C, crit = +100.0°C)
Core 0: +34.0°C (high = +82.0°C, crit = +100.0°C)
Core 1: +35.0°C (high = +82.0°C, crit = +100.0°C)
Core 2: +33.0°C (high = +82.0°C, crit = +100.0°C)
Core 3: +35.0°C (high = +82.0°C, crit = +100.0°C)
Core 4: +34.0°C (high = +82.0°C, crit = +100.0°C)
Core 5: +33.0°C (high = +82.0°C, crit = +100.0°C)
amdgpu-pci-0300
vddgfx: 950.00 mV
fan1: 1632 RPM (min = 400 RPM, max = 4900 RPM)
edge: +37.0°C (crit = +85.0°C, hyst = -273.1°C)
(emerg = +90.0°C)
junction: +40.0°C (crit = +105.0°C, hyst = -273.1°C)
(emerg = +110.0°C)
mem: +38.0°C (crit = +95.0°C, hyst = -273.1°C)
(emerg = +100.0°C)
power1: 9.00 W (cap = 165.00 W)
nvme-pci-0500
Composite: +56.9°C (low = -273.1°C, high = +109.8°C)
(crit = +129.8°C)
Sensor 2: +90.8°C (low = -273.1°C, high = -273.1°C)
I'm fairly certain this has everything to do with having removed orphan packages, at least one of which wasn't an orphan after all. Problem is I don't know which one.
Por favor, ayuda?
(but my have to. alas.)
