Hello, always me
After setting up the whole system I still have open an issue that I can't figure out how to solve. It is about the scaling factor of the applications (telegram, qBitTorrent) that are based on QT.
The only 'similiar' thread I have found is this: Qt error block application running
My goal is to get those application follow the GTK rules, theme and scaling factor. Do you have any tip?!
Is there something I am missing? Or could the QT setting's theme broken? In the case, how could I reset it?
/etc/environment :
# This file is parsed by pam_env module
# Syntax: simple "KEY=VAL" pairs on separate lines
_JAVA_AWT_WM_NONREPARENTING=1
MOZ_ENABLE_WAYLAND=1
XDG_SESSION_TYPE=wayland
EDITOR=/usr/bin/micro
BROWSER=firefox
TERM=alacritty
MAIL=thunderbird
QT_QPA_PLATFORM=wayland
QT_QPA_PLATFORMTHEME=qt6ct
QT_WAYLAND_FORCE_DPI=96
QT_SCALE_FACTOR=1
QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
inxi :
Kernel: 5.16.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=14d91570-f762-4106-889d-9a851d6dc02c rw rootflags=subvol=@
resume=UUID=f1d4967a-02c4-4be4-be76-96ec8d6adaf1 loglevel=3
Desktop: GNOME 41.4 tk: GTK 3.24.33 wm: gnome-shell dm: GDM 41.3
Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1003
date: 01/19/2022
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
status: Discharging
Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x18
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 4497 high: 4994 min/max: 800/5200:3900 scaling:
driver: intel_pstate governor: performance cores: 1: 4951 2: 4994 3: 4791
4: 4917 5: 4900 6: 4900 7: 4866 8: 4900 9: 4900 10: 4911 11: 4892
12: 4916 13: 4832 14: 4914 15: 4902 16: 4900 17: 3697 18: 3704 19: 3700
20: 3705 21: 3698 22: 3689 23: 3666 24: 3698 bogomips: 152985
Device-1: AMD Navi 24 [Radeon RX 6400 / 6500 XT] vendor: Sapphire PULSE
driver: amdgpu v: kernel ports: active: DP-1 empty: HDMI-A-1
bus-ID: 0000:03:00.0 chip-ID: 1002:743f class-ID: 0300
Device-2: Generalplus GENERAL WEBCAM type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2.2:4 chip-ID: 1b3f:2247
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: MSI MAG272CQR serial: <filter> built: 2020
res: 2560x1440 dpi: 109 gamma: 1.2 size: 598x336mm (23.5x13.2")
diag: 686mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
OpenGL:
renderer: AMD BEIGE_GOBY (DRM 3.44.0 5.16.13-zen1-1-zen LLVM 13.0.1)
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
Device-2: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 0000:03:00.1 chip-ID: 1002:ab28
Device-3: Generalplus GENERAL WEBCAM type: USB
Device-4: Sennheiser USB-ED 01 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-7:5 chip-ID: 1395:003c
Sound Server-1: ALSA v: k5.16.13-zen1-1-zen running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 0000:07:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: veth46f37f3 state: up speed: 10000 Mbps duplex: full
mac: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev:
class-ID: 0104
Local Storage: total: 4.55 TiB used: 2.87 TiB (63.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P3CR013
temp: 31.9 C scheme: GPT
model: WD40EFAX-68JH4N0 size: 3.64 TiB block-size: physical: 4096 B
rev: 0A82 scheme: GPT
ID-1: / raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
used: 214.67 GiB (23.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-4: /var/log raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.1 GiB used: 2.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 41.0 C
mem: 38.0 C
Processes: 482 Uptime: 12m wakeups: 2 Memory: 31.1 GiB
used: 3.3 GiB (10.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1433 lib: 455 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2021-11-03
Last full system update: 2022-03-11
EDIT: Found a tricky solution on Manjaro forum
Editing the /etc/environment with those lines everything is back to normal
QT_AUTO_SCREEN_SCALE_FACTOR=1
# This line should make Qt apps use Wayland, according to Arch Wiki.
# Apparently this should be gnome according to Yochanan.
QT_QPA_PLATFORM=xcb
# For use with Kvantum themes
# QT_QPA_PLATFORMTHEME=qt5ct
# Pamac told me to add these:
QT_QPA_PLATFORMTHEME=gnome
QT_STYLE_OVERRIDE=kvantum
Admins, you can close. I hope this post will help other people
