Hi everyone ,
I just keep have problem with Qt , i already try googling , and search same problem but not found any result . Application like telegram-desktop
unable to start / running .
Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
Failed to create wl_display (No such file or directory)
qt.qpa.plugin: Could not load the Qt platform plugin "wayland" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Is there any clue or link to fix this issue I'll be appreciate ,
Regards
@dr460nf1r3
How did you setup gdm wayland
@r4lly99 try deleting QT_QPA_PLATFORM=wayland from /etc/profile.d/gdm-wayland-toggled.sh
First my DE is Gnome and I only checked from garuda-welcome
settings , because I have problem with GDM (not showing in login).
And now after tried install qt5-styleplugin
it become normally , but my view is too big ,
Do I have need reinstall all qt5
package ?
SGS
18 September 2020 00:24
#5
Check if in Garuda Welcome HiDPI is unchecked but for more Info (display, GPU) post
inxi -Fxxxza
Something in settings?
(Seems like I should check out GNOME too. )
Okay , I will check again
> ❯ inxi -Fxxxza 100% 144.4 Mbps ─╯
Kernel: 5.8.9-zen2-1-zen x86_64 bits: 64 compiler: N/A
root=UUID=eafa3a81-663d-4a6b-8b7f-1493615e7e67 rw [email protected] quiet
splash loglevel=3
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell
dm: GDM 3.36.3, LightDM 1.30.0 Distro: Garuda Linux
Type: Laptop System: HP product: HP ENVY Laptop 13-ah1xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10
Mobo: HP model: 850B v: 69.72 serial: <filter> UEFI: Insyde v: F.18
date: 05/02/2019
ID-1: BAT0 charge: 49.9 Wh condition: 49.9/49.9 Wh (100%) volts: 17.5/15.4
model: 333-2B-49-A KC04053XL type: Li-ion serial: <filter>
status: Charging
Info: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: B (11)
microcode: D6 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 31999
Speed: 4168 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 2516 2: 3025
3: 4088 4: 516 5: 4379 6: 2743 7: 4338 8: 4176
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
Device-2: NVIDIA GP108M [GeForce MX150] driver: nvidia v: 450.66
alternate: nouveau,nvidia_drm bus ID: 02:00.0 chip ID: 10de:1d12
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 1-4:3 chip ID: 04f2:b655
Display: x11 server: X.Org 1.20.9 compositor: gnome-shell
driver: modesetting display ID: :1 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5")
s-diag: 1165mm (45.9")
Monitor-1: eDP-1 res: 3840x2160 dpi: 333 size: 293x165mm (11.5x6.5")
diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.8.9-zen2-1-zen
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
v: kernel port: 4000 bus ID: 00:14.3 chip ID: 8086:9df0
Local Storage: total: 476.94 GiB used: 32.38 GiB (6.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital
model: PC SN520 SDAPNUW-512G-1006 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter>
rev: 20110006 scheme: GPT
ID-1: / raw size: 476.64 GiB size: 476.64 GiB (100.00%)
used: 32.38 GiB (6.8%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /home raw size: 476.64 GiB size: 476.64 GiB (100.00%)
Kernel: swappiness: 5 (default 60) cache pressure: 50 (default 100)
ID-1: swap-1 type: zram size: 491.9 MiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 491.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 491.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 491.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 491.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 491.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 491.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 491.9 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
System Temperatures: cpu: 61.0 C mobo: 53.0 C
Processes: 356 Uptime: 1m Memory: 15.37 GiB used: 2.11 GiB (13.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1854 lib: 563 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.06
Please use preformatted Text.
