[Solved] KDE Dr460nized Bluetooth protocol not available
As the pic is saying.
Can some one help me?
You might want to install garuda-bluetooth :slightly_smiling_face:
is says "warning: garuda-bluetooth-20201126-1 is up to date -- reinstalling" so I have it.
and I have also all the bluetooth enable in the Garuda Assistant
sound
Alright. Please specify the adapter used :thinking:
Is it this you mean?
╰─λ sudo lsmod | grep blue
bluetooth 774144 41 btrtl,btintel,btbcm,bnep,btusb,rfcomm
ecdh_generic 16384 2 bluetooth
crc16 16384 2 bluetooth,ext4
rfkill 32768 10 bluetooth,cfg80211
Also try
pulseaudio -k
Now it is working.
I addet this
load-module module-bluetooth-policy
load-module module-bluetooth-discover
to /etc/pulse/system.pa
and change AutoEnable=False to true and removed #
in /etc/bluetooth/main.conf
and install pulseaudio-bluetooth and removed the installet git-version
after a reboot now my headset is working..
Thanks for you help @dr460nf1r3
How did you remove the installed git version?
I suspect that this bit was unnecessary:
and the actual solution was this:
I have no idea why you have a -git version installed unless you’re a developer of the software.
Not his fault in this case, it was preinstalled somehow, got replaced shortly after last release though :slight_smile:
