I've Garuda KDE Ultimate dualboot with Windows, (the following issue was also in KDE Dr46onized)
After booting both OS alternatively after installation and connecting bluetooth in windows, I couldn't connect my bluetooth devices, after some research i got the solution and i did it too, i.e., replaced the bluetooth pairing key in garuda and restarted (Did every possible ways i saw on official arch page and also others).
But the solution was executed correctly with each process/step.
But I couldn't get successful result and still I can't connect to any bluetooth device (just fails everytime, but when i go to "add" even there it will show as wizard failed, restart wizard. But it will get paired as i saw in other device's)
I've even tried the below solution. But didn't work. [Solved] KDE Dr460nized Bluetooth protocol not available
I suspect windows is interfering with bluetooth
Also please provide output of
inxi -Fxxxza
and
Kernel: 5.9.11-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=cd643c84-188a-4364-be5c-8013b5571f91 rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_wayland
dm: SDDM Distro: Garuda Linux
Type: Laptop System: LENOVO product: 80YL v: Lenovo ideapad 520-15IKB
serial: <filter> Chassis: type: 10 v: Lenovo ideapad 520-15IKB
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
UEFI: LENOVO v: 4WCN46WW date: 12/30/2019
ID-1: BAT0 charge: 15.8 Wh condition: 25.1/35.3 Wh (71%) volts: 8.3/7.6
model: CPT-COS L16C2PB1 type: Li-poly serial: <filter> status: Charging
Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: DE
L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 23199
Speed: 3150 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 1452
2: 2455 3: 1916 4: 3500
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
SMT vulnerable
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5916
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Lenovo driver: nvidia
v: 455.38 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:134d
Device-3: Syntek EasyCamera type: USB driver: uvcvideo bus ID: 1-8:5
chip ID: 174f:241a
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: modesetting display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2)
v: 4.6 Mesa 20.2.2 direct render: Yes
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.8-zen1-1-zen
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 02:00.0
chip ID: 10ec:8168
vendor: Lenovo driver: ath10k_pci v: kernel port: 3000 bus ID: 03:00.0
chip ID: 168c:003e
Device-3: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB
driver: btusb bus ID: 1-7:4 chip ID: 0cf3:e300
Local Storage: total: 945.83 GiB used: 624.8 MiB (0.1%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-08Z10
size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A05
ID-2: /dev/sdb type: USB vendor: SanDisk model: Cruzer Blade
size: 14.32 GiB block size: physical: 512 B logical: 512 B
v: 3.0 port: 5060 bus ID: 00:17.0 chip ID: 8086.282a rev: 21
ID-1: / raw size: 100.10 GiB size: 100.10 GiB (100.00%) used: 25.83 GiB (25.8%)
fs: btrfs dev: /dev/sda8
ID-2: /home raw size: 100.10 GiB size: 100.10 GiB (100.00%)
used: 25.83 GiB (25.8%) fs: btrfs dev: /dev/sda8
ID-3: /var/log raw size: 100.10 GiB size: 100.10 GiB (100.00%)
ID-4: /var/tmp raw size: 100.10 GiB size: 100.10 GiB (100.00%)
ID-1: swap-1 type: zram size: 2.89 GiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 2.89 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 2.89 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 2.89 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 231 Uptime: 38m Memory: 7.56 GiB used: 2.09 GiB (27.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1943
lib: 554 flatpak: 0 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.06
Thank you
As I never got response in telegram community, I hope issues get solved here sooner.
Nice to be here.
Me too ![]()
I fixed you post for better reading/place.
Use three ~ in first and last line.
sorry, I didn't get you.
(three ~ )
well, lemme see wts the difference, n delete
oh, so there is no option for deleting immediately.
Anyways I got that about using "~ x3 " for code, this was just a test message
thanks, I'll use now on if needed
I am sorry that your thread got burried under other issues and you had to ping us on telegram.
Tbh, I am usually in hurry and when you said
I thought the issue was solved
And please ping on forums to revive the issue instead of telegram
So coming on topic, did you try bluedevil, the default software on KDE?
This was my first steps.
I have did everything that i can, and only after this I raised this issue here.
After all these i got to know that dual boot arch based systems have bluetooth issue.
Did you also try
sudo pacman -S pulseaudio-bluetooth
And reboot?
Are you dual booting with windows? Windows always try to block the resources for other os.
yes it is installed
yes, and i have tried replacing the pairing key, i changed some config files of bluetooth that was given in other issue. But still i cant connect, (but yes it won’t give error for pairing)
@Naman @librewish Pinging again after some days expecting to get any solution to use this GarudaLinux (arch-based) soon with my bluetooth working properly.
In the latest iso, it was fixed , imo
That probably just needed a rebuild for Pulseaudio 14.
If packages don’t get rebuilt then using ChaoticAUR packages by default is going to create issues. ![]()
the last time i updated was may be <10days ago, and i have installed each and everything related to bluetooth
and yes i have installed pulseaudio-bluetooth
I’ve even tried this and mentioned in 1st post
