[SOLVED] Btfrs and baloo_file_extractor issue
You may want to forgive me.
It was rightly pointed out to me offline (thanks @TNE :blush:) that this can create problems.
Please remove it commenting both lines and then
sudo pacman -Syyuu
Did the suggested changes to /etc/pacman.
garuda-inxi:
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6cafe1ae-53e0-4003-8e56-0566259c4051 rw rootflags=subvol=@
loglevel=3 quiet
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop System: ASUS product: All Series v: N/A
serial:
Mobo: ASUSTeK model: H97M-E v: Rev X.0x serial:
UEFI: American Megatrends v: 2702 date: 03/28/2016
Info: model: Intel Core i5-4690 bits: 64 type: MCP arch: Haswell family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: cache: L1: 256 KiB
desc: 1x6 MiB
Speed (MHz): avg: 3517 high: 3707 min/max: 800/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3707 2: 3375 3: 3494
4: 3492 bogomips: 27935
Type: l1tf
IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
Device-2: Logitech HD Webcam C615 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-3:2 chip-ID: 046d:082c
class-ID: 0e02 serial:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 422x237mm (16.6x9.3")
s-diag: 484mm (19.1")
Monitor-1: HDMI2 res: 1600x900 hz: 60 dpi: 58
size: 700x390mm (27.6x15.4") diag: 801mm (31.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.3.5 compat-v: 3.0 direct render: Yes
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 9 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-3: Logitech HD Webcam C615 type: USB
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.45 running: no
vendor: ASUSTeK AM1I-A driver: r8169 v: kernel port: e000 bus-ID: 03:00.0
IF: enp3s0 state: down mac:
Device-2: Ralink RT5572 Wireless Adapter type: USB driver: rt2800usb
bus-ID: 3-10:5 chip-ID: 148f:5572 class-ID: 0000 serial:
IF: wlp0s20u10 state: up mac:
Local Storage: total: 4.55 TiB used: 1.82 TiB (40.0%)
model: WD5000AACS-00ZUB0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: rev: 1B01
model: WD40EFRX-68WT0N0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial:
rev: 0A82 scheme: GPT
model: WD5000LPVX-80V0TT0 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 465.5 GiB size: 4.09 TiB (900.43%) used: 1.82 TiB (44.5%)
used: 546 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 465.5 GiB size: 4.09 TiB (900.43%)
used: 1.82 TiB (44.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 465.5 GiB size: 4.09 TiB (900.43%)
ID-5: /var/tmp raw-size: 465.5 GiB size: 4.09 TiB (900.43%)
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 218 Uptime: 10m wakeups: 0 Memory: 15.32 GiB
used: 1.82 GiB (11.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1758 lib: 410 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2021-03-08
Last full system update: 2022-02-11
Snapshots: Timeshift
Still experiencing problems with baloo. I see it running even though I have disabled it. My hard drive is again working constantly. Top shows it running 1.7% of cpu and 7.2% ram...and rising. The balooctl commands seem to have no effect. Baloo causes long delays in my desktop and applications. Had to kill the process. I'm going to try a reboot and just let it run awhile and see if it doesn't settle down.
btrfs and baloo are currently alternately taking up to 100% of my cpu and 23% of ram. I think I may have an issue with how I imported and set up a huge load of data a couple weeks ago. Doesn't look to me like it's a Garuda issue. I've got everything set correctly as far as I can see, but btfrs is really struggling with my data and making my computer unusable. Luckily, I have a backup, so not risking losing data while I figure this out.
Thanks for all your help. It has gotten me on the right track anyway.
As always whenever you are experiencing serious issues with your system it is best to test alternate kernels. I would suggest you test at least the LTS, mainline, and cacule kernels.
There have been many threads regarding high resource usage in the past on the forum. I would suggest reading these:
Personally I think disabling btrfs quotas and disabling scheduled snapshots might be the most likely fix. After that, deleting all your snapshots and then performing a full btrfs balance is often helpful.
Well, after a good 15 minutes or so, btfrs-cleaner and baloo_file_extractor finished and my hdds are quiet. I am very pleased and relieved. Again, thanks for the help.
