sudo snap install hello-world
error: cannot perform the following tasks:
Mount snap "core" (9993) ([start snap-core-9993.mount] failed with exit status 1: Job failed. See "journalctl -xe" for details.
Am trying to install snap so that I can in turn install "typeapp-email".
Is available in Arch. Is showing installed in bauh but am unable to use it due to the above example. "mount snap failed"
Any clues please.
same issue....
Output of journalctl -xe ---->
Oct 02 20:33:37 study-travelmatep243 dbus-daemon[773]: [session uid=1001 pid=77>
Oct 02 20:33:37 study-travelmatep243 systemd[706]: Started GNOME Terminal Serve>
ββ Subject: A start job for unit UNIT has finished successfully
ββ Defined-By: systemd
ββ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
ββ
ββ A start job for unit UNIT has finished successfully.
ββ
ββ The job identifier is 424.
Oct 02 20:33:37 study-travelmatep243 systemd[706]: Started VTE child process 35>
ββ
ββ
ββ The job identifier is 442.
Oct 02 20:33:37 study-travelmatep243 systemd[706]: gnome-launched-org.gnome.Ter>
ββ Subject: Unit succeeded
ββ
ββ The unit UNIT has successfully entered the 'dead' state.
None of that output mentions snapd?
I asked same question on snap.....
jonathan see the link I given
OK, try running journalctl -fx
in a terminal and then doing whatever you were trying with snap. You should get journal output as it happens.
It's also probably worth trying the standard linux
kernel to make sure this isn't something related to -zen
journalctl -fx
-- Logs begin at Mon 2020-09-28 06:12:57 IST. --
Oct 02 20:40:28 study-travelmatep243 ananicy[476]: renice: chromium[43319/55948] 0 -> -3
Oct 02 20:40:39 study-travelmatep243 systemd[706]: vte-spawn-b5db60c2-e14d-44f2-b560-ed3a6dce99f8.scope: Succeeded.
ββ
Oct 02 20:40:39 study-travelmatep243 systemd[706]: gnome-terminal-server.service: Succeeded.
ββ
Oct 02 20:40:41 study-travelmatep243 systemd[706]: Started Application launched by gnome-shell.
ββ
ββ
ββ The job identifier is 466.
Oct 02 20:40:41 study-travelmatep243 dbus-daemon[773]: [session uid=1001 pid=773] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.125' (uid=1001 pid=56689 comm="gnome-terminal --window ")
Oct 02 20:40:41 study-travelmatep243 systemd[706]: Starting GNOME Terminal Server...
ββ Subject: A start job for unit UNIT has begun execution
ββ
ββ A start job for unit UNIT has begun execution.
ββ
ββ The job identifier is 469.
Oct 02 20:40:41 study-travelmatep243 dbus-daemon[773]: [session uid=1001 pid=773] Successfully activated service 'org.gnome.Terminal'
Oct 02 20:40:41 study-travelmatep243 systemd[706]: Started GNOME Terminal Server.
ββ
ββ
Oct 02 20:40:41 study-travelmatep243 systemd[706]: Started VTE child process 56702 launched by gnome-terminal-server process 56693.
ββ
ββ
ββ The job identifier is 487.
Oct 02 20:40:41 study-travelmatep243 systemd[706]: gnome-launched-org.gnome.Terminal.desktop-56689.scope: Succeeded.
ββ
Oct 02 20:40:45 study-travelmatep243 tracker-store[55898]: OK
Oct 02 20:40:45 study-travelmatep243 systemd[706]: tracker-store.service: Succeeded.
ββ Defined-By: systemd`Preformatted text`
ββ
Oct 02 20:41:09 study-travelmatep243 ananicy[476]: renice: chromium[44527/57569] 0 -> -3
β― sudo snap install hello-world
[sudo] password for study:
Mount snap βcoreβ (9993) ([start snap-core-9993.mount] failed with exit status 1: Job failed. See βjournalctl -xeβ for details.
harbhim:
sudo snap
If youβre running something with sudo
then youβll have to check the journal using sudo
β― sudo journalctl -fx
Oct 02 20:46:27 study-travelmatep243 ananicy[476]: renice: chromium[43319/69758] 0 -> -3
Oct 02 20:47:29 study-travelmatep243 ananicy[476]: renice: chromium[43319/72071] 0 -> -3
Oct 02 20:48:05 study-travelmatep243 audit[73590]: USER_AUTH pid=73590 uid=1001 auid=1001 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="study" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 20:48:05 study-travelmatep243 kernel: kauditd_printk_skb: 24 callbacks suppressed
Oct 02 20:48:05 study-travelmatep243 kernel: audit: type=1100 audit(1601651885.561:236): pid=73590 uid=1001 auid=1001 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="study" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 20:48:05 study-travelmatep243 dbus-daemon[378]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.329' (uid=0 pid=73590 comm="sudo journalctl -fx ")
Oct 02 20:48:05 study-travelmatep243 audit[73590]: USER_ACCT pid=73590 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="study" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 20:48:05 study-travelmatep243 kernel: audit: type=1101 audit(1601651885.562:237): pid=73590 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="study" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 20:48:05 study-travelmatep243 dbus-daemon[378]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 02 20:48:05 study-travelmatep243 audit[73590]: CRED_REFR pid=73590 uid=0 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 20:48:05 study-travelmatep243 sudo[73590]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 02 20:48:05 study-travelmatep243 kernel: audit: type=1110 audit(1601651885.563:238): pid=73590 uid=0 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 20:48:05 study-travelmatep243 kernel: audit: type=1105 audit(1601651885.566:239): pid=73590 uid=0 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 20:48:05 study-travelmatep243 audit[73590]: USER_START pid=73590 uid=0 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 20:48:05 study-travelmatep243 sudo[73590]: study : TTY=pts/0 ; PWD=/home/study ; USER=root ; COMMAND=/usr/bin/journalctl -fx
Oct 02 20:48:05 study-travelmatep243 sudo[73590]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Still canβt see anything in the logs which has anything to do with snap?
You ran this journalctl
command but not the snap command.
Then plzzz suggest me what I need to do....
- Mount snap "core" (9993) ([start snap-core-9993.mount] failed with exit status 1: Job failed. See "journalctl -xe" for details.
β― sudo journalctl -xe
Oct 02 20:57:09 study-travelmatep243 audit: BPF prog-id=76 op=LOAD
Oct 02 20:57:09 study-travelmatep243 audit: BPF prog-id=77 op=LOAD
Oct 02 20:57:09 study-travelmatep243 audit: BPF prog-id=78 op=LOAD
Oct 02 20:57:09 study-travelmatep243 audit: BPF prog-id=79 op=LOAD
Oct 02 20:57:09 study-travelmatep243 audit: BPF prog-id=80 op=LOAD
Oct 02 20:57:09 study-travelmatep243 audit: BPF prog-id=81 op=LOAD
Oct 02 20:57:09 study-travelmatep243 snapd[92866]: taskrunner.go:271: [change 1>
Oct 02 20:57:09 study-travelmatep243 snapd[92866]: handlers.go:495: Reported in>
Oct 02 20:57:09 study-travelmatep243 sudo[92836]: pam_unix(sudo:session): sessi>
Oct 02 20:57:09 study-travelmatep243 audit[92836]: USER_END pid=92836 uid=0 aui>
Oct 02 20:57:09 study-travelmatep243 audit[92836]: CRED_DISP pid=92836 uid=0 au>
Oct 02 20:57:16 study-travelmatep243 dbus-daemon[378]: [system] Activating via >
Oct 02 20:57:16 study-travelmatep243 dbus-daemon[378]: [system] Activation via >
Oct 02 20:57:16 study-travelmatep243 sudo[93616]: pam_systemd_home(sudo:account>
Oct 02 20:57:16 study-travelmatep243 audit[93616]: USER_ACCT pid=93616 uid=1001>
Oct 02 20:57:16 study-travelmatep243 kernel: kauditd_printk_skb: 24 callbacks s>
Oct 02 20:57:16 study-travelmatep243 kernel: audit: type=1101 audit(1601652436.>
Oct 02 20:57:16 study-travelmatep243 kernel: audit: type=1110 audit(1601652436.>
Oct 02 20:57:16 study-travelmatep243 audit[93616]: CRED_REFR pid=93616 uid=0 au>
Oct 02 20:57:16 study-travelmatep243 sudo[93616]: study : TTY=pts/0 ; PWD=/h>
Oct 02 20:57:16 study-travelmatep243 sudo[93616]: pam_unix(sudo:session): sessi>
Oct 02 20:57:16 study-travelmatep243 kernel: audit: type=1105 audit(1601652436.>
Oct 02 20:57:16 study-travelmatep243 audit[93616]: USER_START pid=93616 uid=0 a>
lines 1590-1612/1612 (END)
OK, now we're getting somewhere. However, the journal output is truncated so most of the line is missing.
Please try again and post with the full lines. There is a journalctl
argument which disables the pager, have a look at journalctl --help
to find it.
is it ok?
Oct 02 21:02:28 study-travelmatep243 sudo[105232]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 02 21:02:28 study-travelmatep243 audit[105232]: USER_ACCT pid=105232 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="study" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 21:02:28 study-travelmatep243 kernel: kauditd_printk_skb: 24 callbacks suppressed
Oct 02 21:02:28 study-travelmatep243 kernel: audit: type=1101 audit(1601652748.855:386): pid=105232 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="study" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 21:02:28 study-travelmatep243 kernel: audit: type=1110 audit(1601652748.855:387): pid=105232 uid=0 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 21:02:28 study-travelmatep243 audit[105232]: CRED_REFR pid=105232 uid=0 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 21:02:28 study-travelmatep243 sudo[105232]: study : TTY=pts/0 ; PWD=/home/study ; USER=root ; COMMAND=/usr/bin/journalctl -fx
Oct 02 21:02:28 study-travelmatep243 sudo[105232]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Oct 02 21:02:28 study-travelmatep243 kernel: audit: type=1105 audit(1601652748.858:388): pid=105232 uid=0 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 21:02:28 study-travelmatep243 audit[105232]: USER_START pid=105232 uid=0 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Getting there. Remember that journalctl -f
will follow the output as it happens rather than show you what happened in the past.
Is it ok?
Oct 02 21:09:10 study-travelmatep243 audit[119990]: USER_ACCT pid=119990 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="study" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 21:09:10 study-travelmatep243 kernel: kauditd_printk_skb: 24 callbacks suppressed
Oct 02 21:09:10 study-travelmatep243 kernel: audit: type=1101 audit(1601653150.320:474): pid=119990 uid=1001 auid=1001 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="study" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 21:09:10 study-travelmatep243 kernel: audit: type=1110 audit(1601653150.321:475): pid=119990 uid=0 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 21:09:10 study-travelmatep243 audit[119990]: CRED_REFR pid=119990 uid=0 auid=1001 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 21:09:10 study-travelmatep243 sudo[119990]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 02 21:09:10 study-travelmatep243 sudo[119990]: study : TTY=pts/0 ; PWD=/home/study ; USER=root ; COMMAND=/usr/bin/journalctl -f
Oct 02 21:09:10 study-travelmatep243 sudo[119990]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Oct 02 21:09:10 study-travelmatep243 audit[119990]: USER_START pid=119990 uid=0 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 02 21:09:10 study-travelmatep243 kernel: audit: type=1105 audit(1601653150.324:476): pid=119990 uid=0 auid=1001 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
OK, so for now just use sudo journalctl -xe
after you run the snap install
command. I might be trying to teach you a step too far.
Oct 02 21:12:42 study-travelmatep243 audit: BPF prog-id=156 op=LOAD
Oct 02 21:12:42 study-travelmatep243 audit: BPF prog-id=157 op=LOAD
Oct 02 21:12:42 study-travelmatep243 audit: BPF prog-id=158 op=LOAD
Oct 02 21:12:42 study-travelmatep243 audit: BPF prog-id=159 op=LOAD
Oct 02 21:12:42 study-travelmatep243 audit: BPF prog-id=160 op=LOAD
Oct 02 21:12:42 study-travelmatep243 audit: BPF prog-id=161 op=LOAD
Oct 02 21:12:42 study-travelmatep243 snapd[119249]: taskrunner.go:271: [change >
Oct 02 21:12:43 study-travelmatep243 snapd[119249]: handlers.go:495: Reported i>
Oct 02 21:12:43 study-travelmatep243 sudo[127385]: pam_unix(sudo:session): sess>
Oct 02 21:12:43 study-travelmatep243 audit[127385]: USER_END pid=127385 uid=0 a>
Oct 02 21:12:43 study-travelmatep243 audit[127385]: CRED_DISP pid=127385 uid=0 >
Oct 02 21:13:15 study-travelmatep243 dbus-daemon[378]: [system] Activating via >
Oct 02 21:13:15 study-travelmatep243 dbus-daemon[378]: [system] Activation via >
Oct 02 21:13:15 study-travelmatep243 sudo[129571]: pam_systemd_home(sudo:accoun>
Oct 02 21:13:15 study-travelmatep243 kernel: kauditd_printk_skb: 24 callbacks s>
Oct 02 21:13:15 study-travelmatep243 kernel: audit: type=1101 audit(1601653395.>
Oct 02 21:13:15 study-travelmatep243 kernel: audit: type=1110 audit(1601653395.>
Oct 02 21:13:15 study-travelmatep243 audit[129571]: USER_ACCT pid=129571 uid=10>
Oct 02 21:13:15 study-travelmatep243 audit[129571]: CRED_REFR pid=129571 uid=0 >
Oct 02 21:13:15 study-travelmatep243 sudo[129571]: study : TTY=pts/0 ; PWD=/>
Oct 02 21:13:15 study-travelmatep243 sudo[129571]: pam_unix(sudo:session): sess>
Oct 02 21:13:15 study-travelmatep243 kernel: audit: type=1105 audit(1601653395.>
Oct 02 21:13:15 study-travelmatep243 audit[129571]: USER_START pid=129571 uid=0>
lines 1723-1745/1745 (END)
Oct 02 21:12:42 study-travelmatep243 snapd[119249]: taskrunner.go:271: [change>
Oct 02 21:12:43 study-travelmatep243 snapd[119249]: handlers.go:495: Reported >
Oct 02 21:12:43 study-travelmatep243 sudo[127385]: pam_unix(sudo:session): ses>
Oct 02 21:12:43 study-travelmatep243 audit[127385]: USER_END pid=127385 uid=0 >
Oct 02 21:12:43 study-travelmatep243 audit[127385]: CRED_DISP pid=127385 uid=0>
Oct 02 21:13:15 study-travelmatep243 dbus-daemon[378]: [system] Activating via>
Oct 02 21:13:15 study-travelmatep243 dbus-daemon[378]: [system] Activation via>
Oct 02 21:13:15 study-travelmatep243 sudo[129571]: pam_systemd_home(sudo:accou>
Oct 02 21:13:15 study-travelmatep243 kernel: kauditd_printk_skb: 24 callbacks >
Oct 02 21:13:15 study-travelmatep243 kernel: audit: type=1101 audit(1601653395>
Oct 02 21:13:15 study-travelmatep243 kernel: audit: type=1110 audit(1601653395>
Oct 02 21:13:15 study-travelmatep243 audit[129571]: USER_ACCT pid=129571 uid=1>
Oct 02 21:13:15 study-travelmatep243 audit[129571]: CRED_REFR pid=129571 uid=0>
Oct 02 21:13:15 study-travelmatep243 sudo[129571]: study : TTY=pts/0 ; PWD=>
Oct 02 21:13:15 study-travelmatep243 sudo[129571]: pam_unix(sudo:session): ses>
Oct 02 21:13:15 study-travelmatep243 kernel: audit: type=1105 audit(1601653395>
Oct 02 21:13:15 study-travelmatep243 audit[129571]: USER_START pid=129571 uid=>
