Clion, IntelliJ, pycharm take a long time to open
when opening it via terminal ./clion.sh there is a error with gtk
WM: bspwm.
(java:242637): Gtk-WARNING **: 03:17:40.160: Theme parsing error: gtk.css:14786:20: Not a valid image
(java:242637): Gtk-WARNING **: 03:17:40.160: Theme parsing error: gtk.css:14792:20: Not a valid image
(java:242637): Gdk-WARNING **: 03:17:40.197: Cannot transform xsetting gtk-xft-dpi of type gchararray to type gint
(java:242637): Gdk-WARNING **: 03:17:40.197: Cannot transform xsetting gtk-enable-input-feedback-sounds of type gchararray to type gboolean
(java:242637): Gdk-WARNING **: 03:17:40.197: Cannot transform xsetting gtk-enable-event-sounds of type gchararray to type gboolean
(java:242637): Gdk-WARNING **: 03:17:40.200: Cannot transform xsetting gtk-enable-input-feedback-sounds of type gchararray to type gboolean
I guess your system specs are enough to run Clion / pycharm etc. smoothly, provided that you set it up right. This depends on how you installed Clion and JRE. Post output of the following command as text ( along with updated garuda-inxi )
