I'm abandoning Windows 11 on my daily driver due to no boot issues after system updates that would occur once every 3-4 months it seems. I've been running Manjaro for a longtime on my workshop computer. The no boot issue is easily fixable, I'm just tired of windows.
My network speeds are stuck in the Bs to KiBs and never reach MiBs. These slow speeds occurs on both Ethernet and WiFi. I've ran a couple other Arch flavors on here and didn't have an issue with the network speeds. I'm able to browse most web pages from FireDragon right now, as a matter of fact, I'm writing this post from the same machine.
I'm guessing I need a different network driver being that my system is somewhat new. I just have no clue how I should look up the proper driver.
I've pasted the garuda-inxi output below in a collapsible box.
I need to learn to cross reference the network info from below and figure out where to look to find the correct drivers.
If anyone has the time to teach someone how to fish, I would be thankful.
Device-1: Realtek vendor: Rivet Networks driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:2600 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:0042 class-ID: 0280
.%;888:8898898: mdoverl@mdoverl-xps8940
x;XxXB%89b8:b8%b88: -----------------------
.8Xxd 8X:. OS: Garuda Linux x86_64
.8Xx; 8x:. Host: XPS 8940
.tt8x .d x88; Kernel: 6.0.10-zen2-1-zen
.@8x8; .db: xx@; Uptime: 18 hours, 52 mins
,tSXXΒ° .bbbbbbbbbbbbbbbbbbbB8x@; Packages: 2105 (pacman)[stable]
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Shell: fish 3.5.1
,888S pd! Resolution: 1920x1080
8X88/ q DE: KDE Plasma 5.26.4
8X88/ WM: KWin (X11)
GBB. WM Theme: Sweet-Dark
x%88 d888@8@X@X@X88X@@XX@@X@8@X. Theme: kvantum-dark Sweetified [Plasma], Sweet-Dark [GTK2/3]
dxXd dB8b8b8B8B08bB88b998888b88x. Icons: BeautyLine [QT], BeautyLine [GTK2/3/4]
dxx8o .@@;. Terminal: konsole
dx88 .t@x. Terminal Font: FiraCode Nerd Font Mono 12
d:SS@8ba89aa67a853Sxxad. CPU: Intel Core i5-10400 (12) @ 4.3 GHz
.d988999889889899dd. GPU: Intel UHD Graphics 630
GPU: NVIDIA GeForce GTX 1660 SUPER
Memory: 3.94 GiB / 23.21 GiB
ββββββββββββββββββββββββ
mdoverl@mdoverl i
β°βΞ» garuda-inxi
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=35b1927f-308f-40c8-8e49-adf1b6d5ab3c rw rootflags=subvol=@
quiet
cryptdevice=UUID=2d2f6df3-908a-471a-bab8-ca7384cd7e1c:luks-2d2f6df3-908a-471a-bab8-ca7384cd7e1c
root=/dev/mapper/luks-2d2f6df3-908a-471a-bab8-ca7384cd7e1c quiet splash
resume=/dev/mapper/luks-e0141a34-b4b2-493b-88b1-893f9cda231a loglevel=3
Type: Desktop System: Dell product: XPS 8940 v: N/A
Mobo: Dell model: 0KV3RP v: A00 serial: <superuser required> UEFI: Dell
v: 2.9.0 date: 07/13/2022
Info: model: Intel Core i5-10400 bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 3 microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3016 high: 4298 min/max: 800/4300 scaling:
driver: intel_pstate governor: performance cores: 1: 2900 2: 2900 3: 2900
4: 2900 5: 4298 6: 2900 7: 2900 8: 2900 9: 2900 10: 2900 11: 2900 12: 2900
bogomips: 69597
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Dell driver: i915
active: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc8 class-ID: 0300
Device-2: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Dell
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:21c4
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: LG (GoldStar) 32 FHD
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2
size: 698x392mm (27.48x15.43") diag: 801mm (31.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel UHD Graphics 630 (CML
GT2) direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA TU116 High Definition Audio vendor: Dell
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
chip-ID: 0cf3:e009 class-ID: e001
Local Storage: total: 11.37 TiB used: 29.04 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR013 temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST8000AS0002-1NA17Z
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5980 serial: <filter> rev: AR15 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000LM024-2AN17V
type: HDD rpm: 5526 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 439.93 GiB size: 439.93 GiB (100.00%)
used: 29.04 GiB (6.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-2d2f6df3-908a-471a-bab8-ca7384cd7e1c
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 439.93 GiB size: 439.93 GiB (100.00%)
ID-4: /var/log raw-size: 439.93 GiB size: 439.93 GiB (100.00%)
ID-5: /var/tmp raw-size: 439.93 GiB size: 439.93 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.21 GiB used: 1.8 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 25.53 GiB used: 0 KiB (0.0%)
mapped: luks-e0141a34-b4b2-493b-88b1-893f9cda231a
System Temperatures: cpu: 43.0 C pch: 42.0 C mobo: 38.0 C
Fan Speeds (RPM): cpu: 991 fan-1: 809
Processes: 341 Uptime: 18h 52m wakeups: 0 Memory: 23.21 GiB
used: 4.3 GiB (18.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 2105
libs: 573 tools: octopi,pamac,paru pm: appimage pkgs: 0 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-11-30
Last full system update: 2022-11-30
ββmdoverl@mdoverl in ~ took 2s
β°βΞ»
