Hello everyone. I'm getting some strange blinkings in my recordings on my "new" laptop and just wondering if anyone has seen it before, knows a fix, or can tell me a decent open source alternative. Thanks.
╭─[email protected] in ~
╰─λ garuda-inxi
Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=6d00cdea-07f2-4376-822a-554629a103bf rw [email protected]
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Laptop System: LENOVO product: 688528U v: ThinkPad Edge E531
Mobo: LENOVO model: 688528U v: 0B98401 PRO serial: <superuser required>
UEFI: LENOVO v: HEET52WW (1.33 ) date: 06/21/2018
ID-1: BAT0 charge: 3.6 Wh (12.7%) condition: 28.3/40.4 Wh (70.0%)
volts: 10.2 min: 10.8 model: LGC 45N1049 type: Li-ion serial: <filter>
status: Discharging
Info: model: Intel Core i7-3632QM bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1942 high: 2243 min/max: 1200/3200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2066 2: 1226 3: 2122
4: 1893 5: 2243 6: 1872 7: 2078 8: 2040 bogomips: 35119
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-1.6:5 chip-ID: 5986:0397 class-ID: 0e02
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.3.5 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel
bus-ID: 04:00.0 chip-ID: 8086:0888 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 05:00.0
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 1-1.3:3 chip-ID: 8087:07da class-ID: e001
Local Storage: total: 931.52 GiB used: 148.08 GiB (15.9%)
model: WD5000LPCX-75VHAT1 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A05 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi)
model: HTS725050A7E630 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: B550 scheme: GPT
ID-1: / raw-size: 64 GiB size: 64 GiB (100.00%) used: 8.14 GiB (12.7%)
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.42%)
used: 562 KiB (0.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 401.66 GiB size: 401.66 GiB (100.00%)
used: 139.94 GiB (34.8%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 64 GiB size: 64 GiB (100.00%)
used: 8.14 GiB (12.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 64 GiB size: 64 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 269 Uptime: 9m wakeups: 1 Memory: 7.59 GiB
used: 2.32 GiB (30.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1247 lib: 311 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-02-14
Last full system update: 2022-02-17
