SIGSEGV on Discord
Hello.
After downloading Discord/Webcord from AUR (or from Garuda Gamer), and launching it, I’m getting a SIGSEGV (segmentation fault) error after the checking for updates screen:
Discord 0.0.68
[3443:0918/170221.091821:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.InvalidArgs: La interfaz «org.freedesktop.portal.FileChooser» no existe
[3443:0918/170221.091860:ERROR:select_file_dialog_linux_portal.cc(290)] Failed to read portal version property
Starting app.
Starting updater.
2024-09-18T15:02:21.124Z [Modules] Modules initializing
2024-09-18T15:02:21.124Z [Modules] Distribution: remote
2024-09-18T15:02:21.124Z [Modules] Host updates: enabled
2024-09-18T15:02:21.125Z [Modules] Module updates: enabled
2024-09-18T15:02:21.125Z [Modules] Module install path: /home/focab0r/.config/discord/0.0.68/modules
2024-09-18T15:02:21.125Z [Modules] Module installed file path: /home/focab0r/.config/discord/0.0.68/modules/installed.json
2024-09-18T15:02:21.125Z [Modules] Module download path: /home/focab0r/.config/discord/0.0.68/modules/pending
splashScreen.initSplash(false)
CDM component API found
blackbox: 2024-09-18T15:02:21.213Z 0
<SNIP>
splashScreen.updateSplashState checking-for-updates checking-for-updates {}
splashScreen.webContentsSend: SPLASH_UPDATE_STATE SPLASH_UPDATE_STATE [ { status: 'checking-for-updates' } ]
blackbox: 2024-09-18T15:02:21.433Z 4 ✅ webContents.did-finish-load web1
2024-09-18T15:02:21.854Z [Modules] Host is up to date.
2024-09-18T15:02:21.854Z [Modules] Checking for module updates at https://discord.com/api/modules/stable/versions.json
2024-09-18T15:02:21.896Z [Modules] No module updates available.
splashScreen: update-check-finished true 0 false
splashScreen.launchMainWindow: false
Optional module ./ElectronTestRpc was not included.
splashScreen.updateSplashState launching launching {}
splashScreen.webContentsSend: SPLASH_UPDATE_STATE SPLASH_UPDATE_STATE [ { status: 'launching' } ]
blackbox: 2024-09-18T15:02:21.949Z 5 ✅ webContents.created web2 ""
blackbox: 2024-09-18T15:02:21.953Z 6 ✅ window.created win2 "Discord"
fish: Job 1, 'discord' terminated by signal SIGSEGV (Address boundary error)
I’m using AMD Ryzen + Garuda + Hyprland, i’ve just download it. Has someone had the same problem? Thanks for your help!
