Hi,
The desktop don't start properly when a second monitor is plugged in at boot.
If I unplug the second monitor, restart, enter my login, the desktop display succesfully and then I can plug my second monitor. But I can't restart the computer with the second monitor plugged in without messing my desktop, the icons don't show up the bottom bar neither and the Garuda welcome app is really messy (duplicate icons, fonts not showing properly,etc)
If i open a terminal with alt+f2 and type plasmashell
I get:
qt.qpa.xcb: could not connect to display
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
thanks for a futur response
Read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yo…
please
and post terminal in- and output from
inxi -Fza
as text!
Even if you personally think it is unnecessary.
and
Oh sorry, I'll be better next time master
jokes aside, thanks for the documentation
inxi -Fza
System: Kernel: 5.13.1-179-tkg-bmq x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=524ce926-71b2-4391-a0da-38e495b65a37 rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 resume=UUID=7d2aa10c-e398-4cf1-99e5-12b680e6af65
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: LENOVO product: 20CLA27BFR v: ThinkPad X250 serial: <filter> Chassis: type: 10
Mobo: LENOVO model: 20CLA27BFR v: SDK0E50510 WIN serial: <filter> UEFI-[Legacy]: LENOVO v: N10ET36W (1.15 )
date: 06/19/2015
Battery: ID-1: BAT0 charge: 17.3 Wh (99.4%) condition: 17.4/23.2 Wh (74.8%) volts: 12.3 min: 11.1 model: SANYO 45N1773
type: Li-ion serial: <filter> status: Unknown
ID-2: BAT1 charge: 17.2 Wh (97.7%) condition: 17.6/23.2 Wh (75.6%) volts: 12.3 min: 11.1 model: SANYO 45N1775
CPU: Info: Dual Core model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell family: 6 model-id: 3D (61)
stepping: 4 microcode: 2F cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 18378
Speed: 2450 MHz min/max: 500/2900 MHz Core speeds (MHz): 1: 2450 2: 2471 3: 2718 4: 2295
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 2-8:5 chip-ID: 5986:0366 class-ID: 0e02
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: DP2 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.1.4 direct render: Yes
Audio: Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.13.1-179-tkg-bmq running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Network: Device-1: Intel Ethernet I218-LM vendor: Lenovo driver: e1000e v: kernel port: 3080 bus-ID: 00:19.0
chip-ID: 8086:15a2 class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: efa0 bus-ID: 03:00.0 chip-ID: 8086:095b
IF-ID-1: wwp0s20u4i6 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 2-7:4 chip-ID: 8087:0a2a
Drives: Local Storage: total: 238.47 GiB used: 56.02 GiB (23.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7LN256HCHP-000H1 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 2H0Q scheme: MBR
Partition: ID-1: / raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 56.02 GiB (24.4%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 56.02 GiB (24.4%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 56.02 GiB (24.4%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-4: /var/tmp raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 56.02 GiB (24.4%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
Swap: Kernel: swappiness: 133 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2 maj-min: 8:2
ID-2: swap-2 type: zram size: 7.47 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 4133
Info: Processes: 200 Uptime: 1h 46m wakeups: 1 Memory: 7.47 GiB used: 4.3 GiB (57.6%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1538 lib: 344 Shell: fish v: 3.3.1
running-in: konsole inxi: 3.3.05
I'm still learning English but if my first message wasn't clear enough, I'm sorry.
My problem in a nutshell: I can't use Garuda if I plug in a second monitor before the login page.
filo
13 July 2021 12:04
4
Hi. I don't think I'll be able to help much, but I was just wondering if this problem occurred recently, e.g. with the latestet update (in that case you could try to rollback to the most recent working snapshot and maybe repeat the update, and/or start troubleshooting what was updated) and especially if you had the chance to check if it occurs also with other kernels.
@filo hello,
this problem has been around for a long time since the first time I installed garuda
Or: you could just use Windows 10 because it detects multiple monitors automatically and saves you a lot of time. It also has reliable updates. You can, of course, stick with Linux;
However, Microsoft has expressed renewed interest in Linux development and they are partnering up. In the end, it's your choice to make:
or
arco
13 July 2021 13:50
7
booblet:
reliable updates
Do you mean Garuda and Arch and Linux distributions don’t have reliable updates?
filo
13 July 2021 13:51
8
It could be also a KDE bug (I'm always astonished by how many bugs are in their list).
E.g. look at this one, maybe you can better search there.
https://bugs.kde.org/show_bug.cgi?id=429266
(look especially at Comment 1)
Thanks, now I know I’m not the only one with this problem.
I tried 3 different kernel, the bug was still there
My other laptop is under Windows 10, but on this one I prefer to stay under linux
When starting with an external monitor attached, BIOS switches the Primary monitor to the external and messes up SDDM and KDE’s default display configuration.
There are startup scripts to use with SDDM to make it do what you want.
Try this , or check Archwiki for other options.
Read more on Multihead .
Thanks you sir !
for /etc/X11/xorg.conf.d/dm-multimonitor.sh for a laptop ,I used this config:
#!/bin/sh
mon1=eDP1
mon2=DP2
# wait 3
if xrandr | grep "$mon2 disconnected"; then
xrandr --output "$mon2" --off --output "$mon1" --auto
else
xrandr --output "$mon1" --off --output "$mon2" --auto
fi
system
Closed
18 July 2021 16:21
14
