SDDM infinite loop, How to correct sddm?
Hello,
I'm unable to login from SDDM. I don't how it's happening I can't figure out what I should do I'm confused now :disappointed:
Garuda INXI (from tty)
  Kernel: 5.16.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=28b9bda0-b454-461f-9c95-d6e1a406bed4
  Console: tty 2 DM: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: H61M-CS v: Rev X.0x serial: <superuser required>
    BIOS: American Megatrends v: 0402 date: 02/28/2014
  Info: model: Intel Pentium G2030 bits: 64 type: MCP arch: Ivy Bridge family: 6
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2333 high: 2994 min/max: 1600/3000 scaling: driver: intel_cpufreq
    governor: performance cores: 1: 1673 2: 2994 bogomips: 11972
  Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
    mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics vendor: ASUSTeK driver: i915
    v: kernel ports: active: VGA-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0152
  Display: server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0 driver: X: loaded: intel
    unloaded: modesetting alternate: fbdev,vesa gpu: i915 tty: 170x48
  Monitor-1: VGA-1 model: LG (GoldStar) 16M35 serial: <filter> built: 2014 res: 1366x768
    dpi: 101 gamma: 1.2 size: 344x194mm (13.5x7.6") diag: 395mm (15.5") ratio: 16:9 modes:
    max: 1366x768 min: 640x480
  Message: GL data unavailable in console. Try -G --display
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
  Sound Server-1: ALSA v: k5.16.11-zen1-1-zen running: yes
  Sound Server-4: PipeWire v: 0.3.47 running: no
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK P8 series
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
  Local Storage: total: 465.76 GiB used: 182.17 GiB (39.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD5000AZRX-00L4HB0
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD
    rpm: 5400 serial: <filter> rev: 1A01 scheme: MBR
  ID-1: / raw-size: 128 GiB size: 128 GiB (100.00%) used: 31.88 GiB (24.9%) fs: btrfs
    dev: /dev/sda5 maj-min: 8:5
  ID-2: /home raw-size: 128 GiB size: 128 GiB (100.00%) used: 31.88 GiB (24.9%) fs: btrfs
  ID-3: /var/log raw-size: 128 GiB size: 128 GiB (100.00%) used: 31.88 GiB (24.9%) fs: btrfs
  ID-4: /var/tmp raw-size: 128 GiB size: 128 GiB (100.00%) used: 31.88 GiB (24.9%) fs: btrfs
  ID-1: swap-1 type: zram size: 3.71 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Processes: 151 Uptime: 16m wakeups: 0 Memory: 3.71 GiB used: 1.07 GiB (28.8%) Init: systemd
  v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1821 lib: 377
  Shell: fish v: 3.3.1 running-in: tty 2 inxi: 3.3.13
e[1;34mGaruda (2.5.5-1):e[0m
e[1;34m  System install date:e[0m     2022-05-10
e[1;34m  Last full system update:e[0m 2022-03-11
e[1;34m  Is partially upgraded:  e[0m Yes
e[1;34m  Relevant software:      e[0m NetworkManager
e[1;34m  Windows dual boot:      e[0m <superuser required>
e[1;34m  Snapshots:              e[0m Snapper
e[1;34m  Failed units:           e[0m preload.service systemd-guest-user.service
However I'm able to login from guest I try to provide ~/.xinitrc (from tty)
~/.xinitrc
#!/bin/sh
# ~/.xinitrc
# Executed by startx (run your window manager from here)
userresources=$HOME/.Xresources
usermodmap=$HOME/.Xmodmap
sysresources=/etc/X11/xinit/.Xresources
sysmodmap=/etc/X11/xinit/.Xmodmap
if [ -d /etc/X11/xinit/xinitrc.d ] ; then
    for f in /etc/X11/xinit/xinitrc.d/?*.sh ; do
        [ -x "$f" ] && . "$f"
    done
    unset f
fi
export DESKTOP_SESSION=plasma
exec startplasma-x11
I also read guide from Arch Linux, I don't understand it and I don't want to break my system again
https://wiki.archlinux.org/title/Xinit#Configuration
Can you describe what happens when you try to log in? Do you see any error messages? Is this from a suspended state or a fresh boot?
No, fresh boot I tested by rebooting several times
SDDM loop infinitely even if type password to user account, but let me enter guest account
The problem is something wrong in config files, I guess
Also resetting from Garuda-Assistat is not working
It is still unclear what you are experiencing. Can you describe with a little more detail what is happening?
  • What screens are you looking at?
  • What inputs are you providing?
  • What is the feedback from the computer?
Sorry, I just can't login and enter gui of main account
SDDM shows again and again for main user account
I just can't get plain information from guest user bcz it don't have access to main user home folder that's why I'm stuck in tty and guest_gui, I have root access though
Maybe you could try booting to a tty (also to check that your account is ok) and reinstall sddm...
And if this is a sddm problem, you should be able to startx when in tty.
startx not working !
I mean it's not loading just a black screen.
Once I have tried it before when sddm was working correctly, it just keep on loading the splash screen then crashes after some time with errors. I will try to provide it's details through terminal
Probably I already asked you in a different thread: why is your system so outdated and partially upgraded? You should garuda-update, first of all.
Then I will try upgrading tomorrow, I dont have good internet connection but I will provide the details what's exactly happening
Did you try this yet? SDDM - ArchWiki
rm ~/.Xauthority
No success, I reinstalled sddm and removed ~/.Xauthority then logout, in second attempt rebooted after doing so.
I just want to know how the sddm is starting by itself, atleast plz provide details about that like .xinitrc
I don't know how sddm is started by daemons or not, If so then I should check all the configs that contain or related to sddm
May be I should reinstall whole OS, it's better less prone to errors and offline install/upgrade packages.
I'm not ready to wipe drive because of windows office lifetime, just I want to access the partition in which grub installed [MBR Record] , I want to correct more things there.
I accept arch as my daily driver even with problems. I understand the philosophy of arch and respect that.
What about Garuda barebones are they okay or has more bugs and fix accordingly
I wonder if it's run perfect without upgrading bearing some limitations.
Now I can't do much because IDK most of the things and I break my PC. I will try to dualboot more distroes including arch.
BTW thank you for helping me for this long.
Only the problem I have i.e Microsoft allow the product key to work on new hardware and grant 365 service along with that, I'm ready to wipe and install linux.
This is a general technical philosophy:
Don’t touch a well working system
You should find something more productive to do with your PC(s) apart from changing system configuration and settings.
When you are in a mood to tinker your system to improve your knowledge,
Make backups
System don’t (usually) break all of a sudden.
Peace!
The problem is
SDDM only allow me to boot into guest and root users
Sorry, I can't paste my main user inputs
So a workaround could be to log as root and create a new user with sudo privileges.
Those images could have been provided as text... !!!
Why you post pictures from terminal outputs?
This is not desirable in technical help forums.
Besides, it looks like you haven't rebooted in a while (93 days?).
This could be your main problem.
Oh, god that’s bios issue my bios not works properly I use system everyday
I use system everyday, before this problem occurred
I’m sure my bios only reset time and system specs only. I always just see bios screen when I boot first [If boot done in 30 minutes later shutdown bios still works fine, only breaks after the system being shutdown for an hour]
From where I should create plasma settings or Garuda settings else from terminal
Garuda settings not works for root user
I didn't say to change plasma or Garuda settings.
To create the new user you can do it from command line in the old good way, either booting to tty or chrooting from live USB. In the latter case it is easier to copy text and past it here (from tty you have to pass through termbin).
Using the system every day has nothing to do with rebooting after a kernel update.
I think your memory battery is empty or very weak.
Have you replaced it?
This coin cell CR 2032?
