I'm surprised, how the startx
only working for root and guest user
I think sddm configs are correct and something wrong with KDE configs
I try to provide the startx
log [using script]
startx output : attempt 1
Script started on 2022-05-15 15:27:52+05:30 [TERM="linux" TTY="/dev/tty2" COLUMNS="136" LINES="38"]
calculus_learner@Computer
.%;888:8898898: -------------------------
x;XxXB%89b8:b8%b88: OS: Garuda Linux
.8Xxd 8X:. Host: ASUSTeK COMPUTER INC. H61M-CS
.8Xx; 8x:. Kernel: 5.16.11-zen1-1-zen
.tt8x .d x88; Uptime: 41 mins
.@8x8; .db: xx@; Packages: 1821 (pacman)
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Shell: fish
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Terminal: script
,888S pd! CPU: Intel Pentium G2030 (2) @ 3.0GHz
8X88/ q GPU: Intel HD Graphics
GBB. Memory: 1.64GiB / 3.71GiB
x%88 d888@8@X@X@X88X@@XX@@X@8@X.
dxXd dB8b8b8B8B08bB88b998888b88x.
dxx8o .@@;.
dx88 .t@x.
d:SS@8ba89aa67a853Sxxad.
.d988999889889899dd.
â•─calculus_learner@Computer in ~
╰─λ startplasma-wayland
kdeinit5: preparing to launch '/usr/lib/kf5/klauncher'
kdeinit5: Launched KLauncher, pid = 9347, result = 0
qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
The Wayland connection broke. Did the Wayland compositor die?
kdeinit5: Communication error with launcher. Exiting!
Could not fully finish the process "/usr/bin/plasma_session"
Error: could not determine $DISPLAY.
Error: Can not contact kdeinit5!
"kdeinit5_shutdown" () exited with code 255
startplasma-wayland: Shutting down...
startplasmacompositor: Shutting down...
startplasmacompositor: Done.
âŽ
â•─calculus_learner@Computer in ~ took 2s
╰─λ startx
/usr/lib/Xorg.wrap: Only console users are allowed to run the X server
^Cxinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: unexpected signal 2
Couldn't get a file descriptor referring to the console.
âŽ
â•─calculus_learner@Computer in ~ took 12s
[🔴] × startx
I Cancled here it toxinit: giving up
xinit: server error
âŽ
â•─calculus_learner@Computer in ~ took 15s
[🔴] × exit
Script done on 2022-05-15 15:29:20+05:30 [COMMAND_EXIT_CODE="1"]
startx output : attempt 2
Script started on 2022-05-15 15:15:06+05:30 [TERM="linux" TTY="/dev/tty2" COLUMNS="136" LINES="38"]
â•─root@Computer in ~ took 10ms
╰─λ su - calculus_learner
.tt8x .d x88; Uptime: 28 mins
GBB. Memory: 1.06GiB / 3.71GiB
dxx8o .@@;.
dx88 .t@x.
╰─λ startx
^Cxinit: giving up
âŽ
â•─calculus_learner@Computer in ~ took 5s
[🔴] × startplasma-wayland
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-calculus_learner'
startplasmacompositor: Could not start D-Bus. Can you call qdbus?
âŽ
â•─calculus_learner@Computer in ~ took 124ms
[🔴] × qdbus --literal
Could not connect to D-Bus server: org.freedesktop.DBus.Error.NotSupported: Using X11 for dbus-daemon autolaunch was disabled at compile time, set your DBUS_SESSION_BUS_ADDRESS instead
âŽ
â•─calculus_learner@Computer in ~ took 8ms
[🔴] × exit
â•─root@Computer in ~ took 1m1s
[🔴] × exit
exit
Script done on 2022-05-15 15:16:25+05:30 [COMMAND_EXIT_CODE="1"]
