Recently I installed OBS in my system but when i started recording the screen it started flickering .
I have tried this stack overflow solution..
but after doing this and restarting it stucks in booting and doesn't boots up.
Any help?
p.s. - I have tried nearly each solution present in the forums.
Naman
1 August 2021 10:16
2
Did you see
I am on my Garuda Linux Dragonized edition.When screen recording ,the screen starts flickering in preview and output too.Screen Recording in Windows is fine but i need it in garuda.
I tried OBS and Simple screen recorder, both have same issue.
inxi -Fxxxa
System: Host: Psychopath-PC Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d4e49bb0-97a0-4269-809c-48abb5283fb2
rw rootflags=subvol=@ quiet splas…
Also, try using Xfce or Gnome. KDE sometimes have screen recording issue with particular hardware, especially laptop.
DRECOTHEA:
Any help?
We cannot help without system info.
Restore a working snapshot.
Screen flickering does not exist on an unbootable system
We should know what to not suggest, so explain what you have tried already.
inxi -Fxxxa
System: Host: kakarott Kernel: 5.13.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e0eff0c4-fa95-4d7b-a8b8-bc0f9d94c151
systemd.unified_cgroup_hierarchy=1 resume=UUID=54c1d7f7-09f7-44de-8426-10b97f93916b loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: VivoBook 15_ASUS Laptop X507UAR v: 1.0
Mobo: ASUSTeK model: X507UAR v: 1.0 serial: <superuser required> UEFI: American Megatrends
v: X507UAR.304 date: 07/17/2019
Battery: ID-1: BAT0 charge: N/A condition: N/A volts: N/A model: N/A type: Unknown serial: N/A
status: Unknown
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: A (10) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 3401 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3401 2: 3400 3: 3400 4: 3400
5: 3400 6: 3400 7: 3400 8: 3400
Graphics: Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus-ID: 1-6:2
chip-ID: 13d3:5a11 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel display-ID: :0
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.13.7-zen1-1-zen running: yes
Network: Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel port: f040 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
IF: wlp2s0 state: up mac: 00:f4:8d:12:9d:84
Bluetooth: Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-8:4 chip-ID: 04ca:3018
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: 00:F4:8D:12:CC:64
Drives: Local Storage: total: 931.51 GiB used: 22.39 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
serial: ZDEC7MTX rev: SDM4 scheme: GPT
Partition: ID-1: / raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 22.39 GiB (7.6%) fs: btrfs
dev: /dev/sda12 maj-min: 8:12
ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 576 KiB (0.0%) fs: vfat
dev: /dev/sda13 maj-min: 8:13
ID-3: /home raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 22.39 GiB (7.6%) fs: btrfs
ID-4: /var/log raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 22.39 GiB (7.6%) fs: btrfs
ID-5: /var/tmp raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 22.39 GiB (7.6%) fs: btrfs
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 15.62 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda7
maj-min: 8:7
Sensors: System Temperatures: cpu: 57.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2900
Info: Processes: 265 Uptime: 9m wakeups: 2 Memory: 7.65 GiB used: 2.96 GiB (38.8%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1247 lib: 299
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
tbg
10 August 2021 15:07
5
There was more information requested. You can’t be bothered to provide this, then why should people bother to provide suggestions if you’ve already attempted them before.
system
Closed
24 August 2021 15:07
6
