I am on my Garuda Linux Dragonized edition.When screen recording ,the screen starts flickering in preview and output too.Screen Recording in Windows is fine but i need it in garuda.
I tried OBS and Simple screen recorder, both have same issue.
inxi -Fxxxa
System: Host: Psychopath-PC Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d4e49bb0-97a0-4269-809c-48abb5283fb2
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
dm: LightDM 1.30.0, SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 81VD v: Lenovo IdeaPad S145-15IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad S145-15IKB
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN serial: <superuser required> UEFI: LENOVO
v: CSCN14WW date: 07/03/2020
Battery: ID-1: BAT0 charge: 31.1 Wh (100.0%) condition: 31.1/35.0 Wh (88.9%) volts: 8.6 min: 7.5
model: SMP L16M2PB2 type: Li-poly serial: 3110 status: Full cycles: 148
CPU: Info: Dual Core model: Intel Core i3-8130U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: A (10) microcode: E0 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17599
Speed: 3400 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3400 2: 3400 3: 3400 4: 3401
Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 13d3:5a08 class-ID: 0e02 serial: 0x0001
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.3 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network: Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo
driver: ath10k_pci v: kernel port: 3040 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp2s0 state: up mac: 80:30:49:57:1c:af
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:2 chip-ID: 0cf3:e500
Report: bt-adapter ID: hci0 rfk-id: 4 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: 80:30:49:57:1C:B0
Drives: Local Storage: total: 931.51 GiB used: 28.62 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm
serial: WD-WXE1AA92J69T rev: 1A05 scheme: GPT
Partition: ID-1: / raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 28.59 GiB (9.8%) fs: btrfs
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 28.7 MiB (11.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 28.59 GiB (9.8%) fs: btrfs
ID-4: /var/log raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 28.59 GiB (9.8%) fs: btrfs
ID-5: /var/tmp raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 28.59 GiB (9.8%) fs: btrfs
ID-1: swap-1 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A
Info: Processes: 241 Uptime: 3h 46m wakeups: 2912 Memory: 7.67 GiB used: 2.57 GiB (33.5%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages:
pacman: 1709 lib: 504 Shell: fish v: 3.2.1 running-in: konsole inxi: 3.3.04
Sample of flickering
https://tg2extbot.herokuapp.com/f/861197207052770.html
Its Really Important to me.Hope you guys find me a solution.
Try the solution wrote here
Ok, I you may please tell me what I missed because I removed only the lines with serial numbers and
Battery information and Machine information with serial number and other confidential information.
Thanks again.
I have only intel integrated graphics.
Changing compositor settings didn't made any difference .
That StackOverFlow method fixed the flickering, but the screen record quality is very poor
Go through preferences of intel drivers and screen recorder . There might be something wrong .
Use Bitrate for quality instead of others . Use vbr .
Go through woogle
Issue isn't fixed..
As a quick fix, i am now using ffmpeg to screen record.Its working fine.
Open issue on git -hub or -lab.
If ffmpeg work its software related .
ffmpeg, obs and simple screen recorder flicker at the beginning.
But when I removed package xf86-video-intel ,
ffmpeg works fine
Obs and Simple screen recorder flickering issue solved but very poor video quality.
You can select FFMPEG recording method in OBS Advanced settings for Output .
system
closed
10 May 2021 13:59
#12
Had some screen flickering issues but i was able to fix it using Screen Flickering in Screen Recording - #3 by professor
but i'm unable to find this to fix bad video quality
You can select FFMPEG recording method in OBS Advanced settings for Output.
Google searches didn't give anything useful
Can some explain how i can set it?
And why i'm i getting these issues although i didnt get them in manjaro ? does garuda use something different for recording?
Kernel: 5.16.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2f2ec219-da15-430d-bc14-a3d8bec36cb5 rw [email protected]
Type: Laptop System: LENOVO product: 2324FV6 v: ThinkPad X230
Mobo: LENOVO model: 2324FV6 serial: <superuser required>
UEFI-[Legacy]: LENOVO v: G2ETB7WW (2.77 ) date: 09/24/2019
ID-1: BAT0 charge: 35.2 Wh (92.6%) condition: 38.0/57.7 Wh (65.8%)
volts: 11.6 min: 11.1 model: SANYO 45N1031 type: Li-ion serial: <filter>
status: Discharging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3058 high: 3065 min/max: 1200/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3062 2: 3059 3: 3049
4: 3065 bogomips: 20751
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-1.6:4 chip-ID: 04f2:b2eb class-ID: 0e02
loaded: modesetting alternate: fbdev,intel,vesa display-ID: :0 screens: 1
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 125
size: 277x156mm (10.9x6.1") diag: 318mm (12.5")
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
Sound Server-1: ALSA v: k5.16.1-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel bus-ID: 03:00.0 chip-ID: 8086:0085 class-ID: 0280
Device-3: Sierra Wireless Sierra Wireless Gobi 3000 Modem device (MC8355)
type: USB driver: qcserial,qmi_wwan bus-ID: 3-4:3 chip-ID: 1199:9013
class-ID: 0000
IF: wwp0s20u4 state: down mac: <filter>
Local Storage: total: 119.25 GiB used: 12.11 GiB (10.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Morebeck model: V602 120GB
type: SSD serial: <filter> rev: 1A0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk
model: Cruzer Blade size: 7.45 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.27 scheme: MBR
ID-1: / raw-size: 35.08 GiB size: 35.08 GiB (100.00%)
used: 12.11 GiB (34.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /home raw-size: 35.08 GiB size: 35.08 GiB (100.00%)
ID-3: /var/log raw-size: 35.08 GiB size: 35.08 GiB (100.00%)
ID-4: /var/tmp raw-size: 35.08 GiB size: 35.08 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.43 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 68.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 4225
Processes: 250 Uptime: 18m wakeups: 3 Memory: 7.43 GiB
used: 3.11 GiB (41.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1404 lib: 327 Shell: fish
v: 3.3.1 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.11
