I have been using Garuda for a while , everything is nice .
but Sometimes applications isnt opening and network isnt working well
i tried to change kernel too it didnt work
can someone help me with or assist me , how to resolve this problem
Kernel: 6.6.13-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc available: hpet,acpi_pm parameters: pti=on
root=UUID=5adf89ea-e8cc-4094-86e1-ce55aec14c06 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A
Mobo: HP model: 86D4 v: 96.45 serial: <filter> UEFI: AMI v: F.17
date: 03/16/2023
ID-1: BAT0 charge: 38.1 Wh (100.0%) condition: 38.1/38.1 Wh (100.0%)
volts: 12.7 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: full cycles: 342
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx socket: FP5
bits: 64 type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3
note: check built: 2019 process: GF 12nm family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2100 min/max: 1400/2100 boost: enabled
base/boost: 2100/3700 scaling: driver: acpi-cpufreq governor: performance
volts: 1.2 V ext-clock: 100 MHz cores: 1: 2100 2: 2100 3: 2100 4: 2100
5: 2100 6: 2100 7: 2100 8: 2100 bogomips: 33551
Device-1: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q]
vendor: Hewlett-Packard driver: N/A alternate: nouveau non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c91 class-ID: 0300
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 61.0 C
Device-3: IMC Networks HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:56c9
Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0040 built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven LLVM 16.0.6 DRM 3.54 6.6.13-hardened1-1-hardened)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.274 layers: 10 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.3.3-arch1.1
device-ID: 1002:15d8 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM
Device-1: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
API: ALSA v: k6.6.13-hardened1-1-hardened status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: n/a (root, process) with:
1: wireplumber status: active 2: pw-jack type: plugin
tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 17.0 status: active (root, process) with:
1: pulseaudio-alsa type: plugin 2: pulseaudio-jack type: module
tools: pacat,pactl
vendor: Hewlett-Packard driver: rtw_8822ce v: kernel modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
vendor: Hewlett-Packard Pavilion Laptop 15-ec0xxx driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0bda:b00c
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
Local Storage: total: 931.51 GiB used: 134.59 GiB (14.4%)
model: WD10SPZX-60Z10T0 family: Blue Mobile (SMR) size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A04 temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 110d 23h cycles: 5748
Old-Age: g-sense error rate: 194677
used: 134.59 GiB (14.5%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
ID-1: swap-1 type: zram size: 13.53 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 60.5 C mobo: N/A gpu: amdgpu temp: 60.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Processes: 284 Uptime: 5m wakeups: 0 Memory: total: 16 GiB note: est.
available: 13.53 GiB used: 3.28 GiB (24.2%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1909
pm: dpkg pkgs: 1 pm: pacman pkgs: 1908 libs: 545 tools: octopi,pamac,paru
Shell: garuda-inxi (sudo) default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2024-01-09
Last full system update: 2024-01-23
Failed units: ```
