Hello all, I've been using Garuda Dr46onized for around 1-2 months now, and I absolutely love it. I alternate between Parrot Security OS, Garuda Dr46onized, and (Very rarely,) Windows 11 Pro as my daily driving systems, And honestly this issue affects every single one of them except for good old proprietary Windows 11 Pro.
I'm essentially looking for assistance regarding an NIC WLAN Adapter 802.11AC - And with the RTL8812BU chipset, and just below is the driver I currently use (which only has managed and very barebones monitor modes supported.) Virtual AP, AP mode, etc- Not at all functional but should theoretically work considering the adapter itself is capable of it.
My current RTL88x2BU Driver:
I would appreciate any possibility of assistance or maybe I simply missed a golden post or documentation that may have what I seek;
Here is the (relevant) output of garuda-inxi:
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=f1a6f334-6749-48b3-87f2-d2425043d995 rw [email protected]
quiet
cryptdevice=UUID=332ae97a-3c61-406d-863d-e019db85cbcd:luks-332ae97a-3c61-406d-863d-e019db85cbcd
root=/dev/mapper/luks-332ae97a-3c61-406d-863d-e019db85cbcd quiet
resume=/dev/mapper/luks-213f8566-6734-41c5-b94b-dc39c6ce18d7
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
The Device in question[[Network]]
Device-3: Realtek RTL88x2bu [AC1200 Techkey] type: USB
driver: rtl88x2bu bus-ID: 1-1:7 chip-ID: 0bda:b812 class-ID: 0000
IF: wlp0s20f0u1 state: down mac: <filter>
Sensor(s):
System Temperatures: cpu: 69.0 C pch: 77.0 C mobo: N/A gpu: nvidia
temp: 74 C
Processes: 343 Uptime: 22h 25m wakeups: 1 Memory: 15.52 GiB
used: 5.6 GiB (36.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1853 lib: 487 Shell: fish v: 3.4.1
default: Zsh v: 5.8.1 running-in: alacritty inxi: 3.3.15
e[1;34mGaruda (2.6.2-1):e[0m
e[1;34m System install date:e[0m 2022-04-03
e[1;34m Last full system update:e[0m 2022-05-10 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m systemd-networkd-wait-online.service
All relevant information should* be found above. If I am missing anything crucial for the topic of assistance, please inform me so I can modify this post. Thank you in advance for the help to anyone who can.
