Hello.. I recently (last night) got fed up with Windows and decided to switch to Linux.. Garuda Linux looks and sounds amazing so I switch and installed it last night. My Netgear A6100 is not working and I can't find any Garuda Linux support or tips regarding this. I found a guide to getting it to work with Ubuntu but I really don't want Ubuntu. I downloaded Windows drivers and tried using the Windows Drivers options through Garuda Assitant but to no avail.. I get a NDISWrappper not installed which I found I probably shouldn't need anyway. I also found I may need AUR (en) - rtl88x2bu-dkms-git but not sure if this will help me or how to actually install the driver. Sorry but I am complete noob to Linux... literally first day with it. I appreciate any help, I really love the look and feel of Garuda Linux so far and don't want to switch ESPECIALLY back to Windows >.<
Welcome to the forum.
Please read the Garuda Wiki article regarding "Reporting bugs". Specifically read the section on posting your system specs using the inxi command.
Gotchya... Thank you for the guidance. Here is the result of the inxi -Fxxxa command... I'm unsure if I should create a new post so I did that plus responding here for good measure. Apologies if this is wrong.
Kernel: 5.10.4-107-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq
root=UUID=11171806-a474-47f8-a9c3-5880c3dba1da rw rootflags=subvol=@
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Garuda Linux
Type: Desktop Mobo: Intel model: S3000AHLX v: D40858-208
serial: <filter> BIOS: Intel v: S3000.86B.02.00.0054.061120091710
date: 06/11/2009
Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
Info: Dual Core model: Intel Core2 6700 bits: 64 type: MCP
arch: Core Merom family: 6 model-id: F (15) stepping: 6 microcode: D0
L2 cache: 4 MiB
flags: lm nx pae sse sse2 sse3 ssse3 vmx bogomips: 10676
Speed: 2667 MHz min/max: 1596/2660 MHz Core speeds (MHz): 1: 2667
2: 2667
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: nvidia
v: 460.27.04 alternate: nouveau,nvidia_drm bus ID: 03:00.0
chip ID: 10de:13c2
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 650x366mm (25.6x14.4")
s-diag: 746mm (29.4")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60
OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 460.27.04
direct render: Yes
Device-1: NVIDIA GM204 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 10de:0fbb
Sound Server: ALSA v: k5.10.4-107-tkg-bmq
Device-1: Intel 82573E Gigabit Ethernet driver: e1000e v: kernel
port: 2000 bus ID: 04:00.0 chip ID: 8086:108c
IF: enp4s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel 82541GI Gigabit Ethernet driver: e1000 v: kernel
port: 1100 bus ID: 05:05.0 chip ID: 8086:1076
IF: enp5s5 state: down mac: <filter>
Local Storage: total: 931.52 GiB used: 14.88 GiB (1.6%)
model: WDS100T2G0A-00JH30 size: 931.52 GiB block size: physical: 512 B
logical: 512 B speed: <unknown> serial: <filter> rev: 0000
ID-1: / raw size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 14.88 GiB (1.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw size: 931.51 GiB size: 931.51 GiB (100.00%)
ID-3: /var/log raw size: 931.51 GiB size: 931.51 GiB (100.00%)
ID-4: /var/tmp raw size: 931.51 GiB size: 931.51 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.39 GiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 3.39 GiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram1
System Temperatures: cpu: 79.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 43%
Processes: 195 Uptime: 27m wakeups: 2 Memory: 6.78 GiB
used: 3.27 GiB (48.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1563 lib: 483 Shell: fish v: 3.1.2 running in: konsole
inxi: 3.2.01
Hello. I explained my situation a bit in previous post but now I have the information needed. (Sorry if I should not create a new post) I am having difficulty getting my NetGear A6100 wireless usb adapter working with Linux.. I just switched to Garuda Linux last night so very noob to Linux.. VERY. Here is the output of inxi -Fxxxa Any help is MUCH appreciated and please speak to me as if I'm a child as I'm totally noob to all things Linux. Thank you all SO much!!
date: 06/11/2009
L2 cache: 4 MiB
2: 2667
SMT disabled
chip ID: 10de:13c2
direct render: Yes
inxi: 3.2.01
There is no "Netgear" in your network devices which means it is not being detected or it is not connected.
Does this actually have Linux support?
Really? Well... OK then: Get an adult (or an older sibling) to administer your PC.
Just a guess without any WiFi chip info, but I'd try installing this driver from the Chaotic AUR repo:
rtl88xxau-aircrack-dkms-git
If it doesn't work on your current kernel search for how to install the linux-lts
kernel.
Oi... Terribly sorry, I unplugged it before doing that.. Here is the output again >.< Ok maybe laymen terms.. not like a child oh and no official support from Netgear but I read people got it working with Ubuntu and Mint so am hoping Garuda will work too
date: 06/11/2009
L2 cache: 4 MiB
2: 2667
SMT disabled
chip ID: 10de:13c2
direct render: Yes
Device-3: NetGear A6100 AC600 DB Wireless Adapter [Realtek RTL8811AU]
type: USB driver: usb-network bus ID: 1-2:2 chip ID: 0846:9052
Local Storage: total: 931.52 GiB used: 19.99 GiB (2.1%)
used: 19.99 GiB (2.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 80.0 C mobo: N/A gpu: nvidia temp: 35 C
Processes: 187 Uptime: 10m wakeups: 4 Memory: 6.78 GiB
used: 2.76 GiB (40.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0
inxi: 3.2.01
Sorry about that here is the info.. I unplugged before running the inxi -Fxxxza
Ok I will try out that driver, thank you
Welcome CTooze003.
Glad you've decided to take a dive into the world of Linux. Unless you find a specific reason to continue with Win, I think if you search for the right distro (and there are ALOT of them) that you will be glad you went full-time with whatever distro you chose.
The problem you're having with your wifi dongle is not a Linux problem per-se, it's the fact that Realtek isn't very supportive with offering their software drivers (for free) to the Linux community. On a certain level, you can understand that.
Try the driver from the chaotic-aur that was mentioned above. If that doesn't work, it could be a crap shoot from distro to distro at the OOTB level. Maybe Ubuntu if any would.
However ... there is a silver lining! If you can find a wifi stick with a Ralink chip, you could find eternal happiness.
Here's a brand notorius for their general Linux support. Works OOTB with no need to install any additional drivers.
I'm typing this from one now ...
https://www.pandawireless.com/
GM
Perhaps I'll order a Panda if that driver doesn't work. But.... uh.... well this is embarrassing but how do I install the driver with Linux? I downloaded the .zip put it on a flash drive. Told ya I'm a total Linux noob
Not a problem ... remember, we all started in your shoes at one point.
With Arch-based derivatives, and all Linux distros in general, you have built-in "software centers (repos)" where you can search and install software.
In Garuda, open the "Add/remove software" center and search/select/apply the package that was suggested above by tbg. First, access the preferences section of the software center & enable AUR before you search for that package. The software center will install automatically. Reboot &/or remove/replug your USB dongle.
If the driver works with your USB chipset, you'll obviously see your wifi network listed in the network manager.
Easy peasy.
GM
Hi!
During installation Garuda Linux deactivates all networks except for wired ones.
In order to use a wireless connection with Garuda Linux you have to go to CONNMAN SETTINGS in your applications menu and toggle the WiFi switch to ON.
Maybe that helps.
KDE editions use Network Manager, not ConnMan.
Be sure to install the driver version from the Chaotic AUR, (not the AUR).
There are three related drivers in the AUR (and prebuilt in ChaoticAUR):
$ yay -Ss 8811
aur/rtl8812au422-dkms-git 4.2.2.r7502.gc20130507aur2-1 (+1 0.00)
rtl8821AU/rtl8812AU/rtl8811AU driver with firmware version 4.2.2 (7502.20130507) (Tested and working as of Linux kernel 5.3.8-arch1-1)
aur/rtl88xxau-aircrack-dkms-git r1123.e9fbf5c-1 (+38 1.60)
Aircrack-ng kernel module for Realtek 88XXau (USB adapters only) network cards (8811au, 8812au and 8821au chipsets) with monitor mode and injection support
aur/rtl8821au-dkms-git 5.1.5.r59.gaf07b27-1 (+45 0.00)
rtl8821AU, rtl8812AU and rtl8811AU chipset driver with firmware v5.1.5
I am using rtl88xxau-aircrack-dkms-git
successfully with one of my USB wifi adapters, so try that one.
Gotcha. So it goes through and downloads but then I get a bunch of errors signature from X is unknown trust. I have AUR support enabled. Is there something further I have to tweak?
If you are using the Chaotic AUR version and receiving this error then test the version in the AUR, (and vice versa). The Chaotic version is the same, but it saves the build time of the AUR version.
In the future do not give your Readers Digest condensed version of any error message. Always post the exact errors received as text (no editing).
