Hello everybody
I have Garuda Linux(KDE env) which I want to connect to the internet with USB wifi, the first problem is it doesn't connect to hidden wifi, and second is when it connects to unhidden wifi sometimes take a few minutes to connect it, and sometimes it's not connecting at all, I don't know why that happens, when I had windows 10 these problems weren't there but in Linux I have.
Read
please
and post
inxi -Fxxxza
as text! Even if you personally think it is unnecessary.
and
Use forum search function first, maybe you
is listed in solutions.
It's not helpful. For help, we need more details about your hard- and software.
System: Kernel: 5.11.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=dcff8c34-fec2-463c-9581-ea0f69c95476
systemd.unified_cgroup_hierarchy=1 resume=UUID=0606a149-9f5b-47bc-b116-22c67112ba69 loglevel=3
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM
Machine: Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: PRO H410M-C v: Rev 1.xx serial: <filter> UEFI: American Megatrends v: 0602
date: 04/15/2020
CPU: Info: 8-Core model: Intel Core i7-10700 bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 5 microcode: E0 cache: L2: 16 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 92796
Speed: 4702 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 4702 2: 4699 3: 4701 4: 4697
5: 4696 6: 4698 7: 4693 8: 4699 9: 4698 10: 4711 11: 4708 12: 4694 13: 4699 14: 4705 15: 4711
16: 4698
Graphics: Device-1: Intel vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc5
Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nvidia v: 465.27
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d01 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: DP1 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CML GT2) v: 4.6 Mesa 21.0.3 direct render: Yes
Audio: Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel alternate: snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a3f0 class-ID: 0403
Sound Server-1: ALSA v: k5.11.16-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Network: Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: efa0
bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
Device-2: D-Link DWA-123 Wireless N 150 Adapter (rev.D1) type: USB driver: r8188eu
bus-ID: 1-4:5 chip-ID: 2001:3310 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u4 state: up mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives: Local Storage: total: 1.14 TiB used: 439.71 GiB (37.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-00WN4A0 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: 1A01 scheme: GPT
Partition: ID-1: / raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 9.37 GiB (12.0%) fs: btrfs
ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%) used: 572 KiB (0.0%) fs: vfat
dev: /dev/nvme0n1p8 maj-min: 259:8
ID-3: /home raw-size: 9.77 GiB size: 9.77 GiB (100.00%) used: 1.56 GiB (16.0%) fs: btrfs
dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /var/log raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 9.37 GiB (12.0%) fs: btrfs
ID-5: /var/tmp raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 9.37 GiB (12.0%) fs: btrfs
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p6
maj-min: 259:6
ID-2: swap-2 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-10: swap-10 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-11: swap-11 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-12: swap-12 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-13: swap-13 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
ID-14: swap-14 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram12
ID-15: swap-15 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram13
ID-16: swap-16 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram14
ID-17: swap-17 type: zram size: 990.1 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram15
Sensors: System Temperatures: cpu: 27.8 C mobo: N/A
Info: Processes: 394 Uptime: 31m wakeups: 0 Memory: 15.47 GiB used: 3.92 GiB (25.4%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1300 lib: 340
Shell: Bash v: 5.1.4 running-in: konsole inxi: 3.3.04
You didn't read "Reporting bugs"
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
Search for
sorry, and thanks for editing
There are three drivers available for this adapter:
8188eu-aircrack-dkms-git
8188eu-dkms-git
8188eu-dkms
Have you tested any of these drivers yet?
If so, which one(s) ?
If not, that would be the place to start.
Many Realtek adapters require installing the drivers separately as the in kernel drivers aren't well developed yet.
Be sure to reboot after any driver installation.
Please post lsmod | sort
before you install an alternate driver, and then post it again after installing any driver package (reboot first) .
Hi there.
I made several suggestions and requested you post further outputs when you opened your help request. It appears you have not been online since opening your request some days ago.
When suggestions are given and outputs are requested it is incumbent upon the OP to provide this information in a timely manner or your thread will be deemed abandoned.
I like to keep the networking section clear of abandoned posts that are left dangling. Otherwise, we simply get a bunch of new users tacking on "me too" to old stale posts that likely aren't even a related issue.
As such I am putting a one week countdown lock on your thread for you to respond and provide the requested outputs. A week and a half should be more than sufficient time to reply to any request for outputs for most anyone requesting assistance.
If your thread has been locked and you wish it reopened then please PM another moderator to reopen this thread. I am no longer accepting PM's from users as some users have abused this system and I no longer accept PM's from members.
If your issue has already been resolved, please revisit your thread and provide an update so that other users know how to fix a related problem in the future. Please do not open help requests only to abandon them and not provide some form of closure to your thread. Even if you simply gave up on your issue you should do the courteous thing by replying to your own help request and let others know that you no longer require assistance.
It's just the courteous thing to do, and helps keep our forum neat, tidy, and organized for users to find solutions easier.
This topic was automatically closed after 6 days. New replies are no longer allowed.
