Had to edit as it was a different issue.
Preferably i want to installl RPCS3 through garuda assistant but it returns "target not found". Trying with pamac but it instead just hangs. I did attempt to build but ran into another error.
:: jack2 and pipewire-jack are in conflict (jack). Remove pipewire-jack? [y/N] y
:: removing pipewire-jack breaks dependency 'pipewire-jack' required by lib32-pipewire-jack
:: removing pipewire-jack breaks dependency 'pipewire-jack' required by pipewire-support
Kernel: 5.16.11-zen1-2-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=74168034-3331-4447-b79f-cfe584359abd rw rootflags=subvol=@
cryptdevice=UUID=5b832090-a2c7-482f-bd8d-c98baf90653c:luks-5b832090-a2c7-482f-bd8d-c98baf90653c
root=/dev/mapper/luks-5b832090-a2c7-482f-bd8d-c98baf90653c quiet splash
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.31 wm: muffin vt: 7
dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 7559 v: 1.2.0
Mobo: Dell model: 0H0CC0 v: A00 serial: <superuser required> UEFI: Dell
v: 1.2.0 date: 09/22/2016
ID-1: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
model: Logitech Gaming Mouse G900 type: N/A serial: <filter> status: Full
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3500 scaling: driver: intel_pstate
8: 800 bogomips: 41599
Type: l1tf
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 960M] driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.0
chip-ID: 10de:139b class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-4:6 chip-ID: 1bcf:28b0 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 driver: X:
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2816x864 s-dpi: 85 s-size: 838x257mm (33.0x10.1")
s-diag: 877mm (34.5")
Monitor-1: HDMI-1 mapped: HDMI-A-1 pos: primary,right
model: HDMI1-2714UDH serial: <filter> built: 2016 res: 1536x864 hz: 60
dpi: 65 gamma: 1.2 size: 596x335mm (23.5x13.2") diag: 685mm (27")
ratio: 16:9 modes: max: 4096x2160 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: Chi Mei Innolux built: 2013
res: 1280x720 hz: 60 dpi: 95 gamma: 1.2 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-2: BEHRINGER GmbH UMC204HD 192k type: USB driver: snd-usb-audio
bus-ID: 1-1:2 chip-ID: 1397:0508 class-ID: fe01
Sound Server-1: ALSA v: k5.16.11-zen1-2-zen running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:3165 class-ID: 0280
IF-ID-1: wgivpn state: unknown speed: N/A duplex: N/A mac: N/A
bus-ID: 1-5:8 chip-ID: 8087:0a2a class-ID: e001
address: <filter>
Local Storage: total: 698.65 GiB used: 12.97 GiB (1.9%)
model: WDS250G1B0B-00AS40 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST9500420AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SDM1 scheme: MBR
used: 12.97 GiB (5.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5b832090-a2c7-482f-bd8d-c98baf90653c
used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.0 C pch: 53.5 C mobo: 27.8 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 308 Uptime: 21m wakeups: 3 Memory: 15.5 GiB
used: 3.72 GiB (24.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1371 lib: 339 Shell: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-03
Last full system update: 2022-03-03
