Rounded corners on dock and global menu have extra light colored rounded corners underneath
I am not sure if it looked alright on the first boot.
After fresh install, applying all updates and restart, rounded corners on my desktop look like on picture below:
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c17c6067-4589-42c7-8a38-17b8dc4523a1 rw rootflags=subvol=@
quiet rd.luks.uuid=5803f3bc-a82d-4509-862a-38b38f45ade8
rd.luks.uuid=f7e8111b-885e-43b9-b3e0-ce114a23f4c2
resume=/dev/mapper/luks-f7e8111b-885e-43b9-b3e0-ce114a23f4c2 loglevel=3
Type: Laptop System: LENOVO product: 21K7CTO1WW v: ThinkPad T16 Gen 2
Mobo: LENOVO model: 21K7CTO1WW serial: <superuser required>
part-nu: LENOVO_MT_21K7_BU_Think_FM_ThinkPad T16 Gen 2
uuid: <superuser required> UEFI: LENOVO v: R2FET38W (1.18 )
date: 01/15/2024
ID-1: BAT0 charge: 65.6 Wh (74.2%) condition: 88.4/86.0 Wh (102.8%)
power: 9.8 W volts: 16.0 min: 15.4 model: SMP 5B10W51871 type: Li-poly
serial: <filter> status: discharging cycles: 7
Info: model: AMD Ryzen 7 PRO 7840U w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check built: 2022+
microcode: 0xA704103
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 654 high: 1459
min/max: 400/5289:5132:5605:6076:5760:5918:5447 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 1423 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 1459
13: 1397 14: 400 15: 400 16: 1397 bogomips: 105401
Device-1: AMD Phoenix1 vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-3
code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
DP-4, DP-5, DP-6, HDMI-A-1, Writeback-1 bus-ID: 64:00.0 chip-ID: 1002:15bf
class-ID: 0300 temp: 29.0 C
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 174f:1812
Monitor-1: eDP-1 res: 1920x1200 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
gfx1103_r1 LLVM 17.0.6 DRM 3.57 6.8.7-zen1-1-zen) device-ID: 1002:15bf
memory: 1000 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV GFX1103_R1) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:15bf surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 64:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 64:00.5
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 64:00.6
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api with: aoss
port: 6000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f0 state: down mac: <filter>
Device-2: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
driver: ath11k_pci v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 17cb:1103 class-ID: 0280
Device-1: USI driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3.1:4 chip-ID: 10ab:9309 class-ID: e001
Local Storage: total: 953.87 GiB used: 14.42 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM790 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 11296 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 920.5 GiB size: 920.5 GiB (100.00%) used: 14.42 GiB (1.6%)
fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-5803f3bc-a82d-4509-862a-38b38f45ade8
used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 920.5 GiB size: 920.5 GiB (100.00%)
used: 14.42 GiB (1.6%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
ID-4: /var/log raw-size: 920.5 GiB size: 920.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 920.5 GiB size: 920.5 GiB (100.00%)
ID-1: swap-1 type: partition size: 33.07 GiB used: 0 KiB (0.0%)
mapped: luks-f7e8111b-885e-43b9-b3e0-ce114a23f4c2
ID-2: swap-2 type: zram size: 30.06 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 30.0 C mobo: N/A gpu: amdgpu temp: 29.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 32 GiB note: est. available: 30.06 GiB used: 2.4 GiB (8.0%)
Processes: 431 Power: uptime: 37m states: freeze,mem,disk suspend: s2idle
wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 12.01 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1981 libs: 550 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-04-18
Last full system update: 2024-04-19 ↻
Take a look at this topic:
