Is there any chance to modify the panel corner radius?
My bottom panel basically have the edges and its visible especially on white areas.(its ugly)
Kernel: 6.8.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=388dc746-30e9-40a7-b712-8351dae7ad87 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE
Megatrends LLC. v: F65a date: 02/09/2023
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1762 high: 3891 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1373 2: 1375
3: 1359 4: 1550 5: 1550 6: 1550 7: 1375 8: 2351 9: 1550 10: 1681 11: 1550
12: 3891 bogomips: 81435
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
bus-ID: 06:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 49.0 C
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
polaris10 LLVM 17.0.6 DRM 3.57 6.8.4-zen1-1-zen) device-ID: 1002:67df
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv v: 24.0.4-arch1.2
device-ID: 1002:67df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.4-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:aaf0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.3
API: ALSA v: k6.8.4-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
Local Storage: total: 698.65 GiB used: 171.93 GiB (24.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB
used: 128.13 GiB (27.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.54 GiB used: 118.8 MiB (0.7%)
System Temperatures: cpu: 33.2 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1169
Memory: total: 16 GiB available: 15.54 GiB used: 2.57 GiB (16.5%)
Processes: 326 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1432 libs: 413 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.33
Garuda (2.6.25-1):
System install date: 2024-04-07
Last full system update: 2024-04-10
Relevant software: NetworkManager dracut
Appreciate for your help!
