~ $ sudo pacman -Syu rofi-greenclip
:: Synchronising package databases...
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 1731.7 KiB 1339 KiB/s 00:01 [---------------------------------------] 100%
error: target not found: rofi-greenclip
As you can see, chaotic-aur is enabled (this pacman/arch wise a standard Garuda install, I haven't tweaked the pacman conf):
$ grep -A 2 chaotic-aur /etc/pacman.conf
[chaotic-aur]
Include = /etc/pacman.d/chaotic-mirrorlist
Do I need to do something to get chatotic-aur to build/add rofi-greenclip, or have I don't something wrong here?
Hi there, welcome. rofi-greenclip is at the moment not available in the chaotic-aur, but only in the AUR repository.
To install from AUR you’ll need to compile it or most likely use an AUR helper, with e.g.:
paru rofi-greenclip
It is possible anyway to ask new packages to be added to the chaotic-aur here:
thank you for your kind and prompt response. I'll check out paru and the packages thread.
Since Garuda and Arch are so awesome, I guess I thought it would either have everything from AUR or queue new packages and respond with something like:
target not found: rofi-greenclip, added to chaotic package queue: https://status.example.com/foo. Check back later, typical ETA is <n>
