All issues related to Garuda Linux and its assistance.
I have installed Garuda and trying to install Richo SP100 Printer but it fails.
Please suggest.
Please suggest.
As always, first stop is the Archwiki...(this forum for Garuda, not peripherals)
https://wiki.archlinux.org/index.php/CUPS/Printer-specific_problems#Ricoh
can you give me step by step installation steps.
Thanks in advance.
pamac build ricoh-sp100-git
I guess reboot ?
fatal: remote error:
Repository not found.
==> ERROR: Failure while downloading ricoh-sp100 git repo
Aborting...
Error: Failed to build ricoh-sp100-git
getting this error
Same when I'm trying to install it From Add/Remove Software
is pamac.
check in pamac if AUR support is “on” set.
Or use paru.
LANG=C pamac build ricoh-sp100-git
Preparing...
Cloning ricoh-sp100-git build files...
Checking ricoh-sp100-git dependencies...
Resolving dependencies...
Checking inter-conflicts...
To install (4):
qpdf 10.3.1-1 (Required By: ricoh-sp100-git) extra 1,2 MB
cups-filters 1.28.7-1 (Required By: ricoh-sp100-git) extra 902,9 kB
cups 1:2.3.3op2-1 (Required By: ricoh-sp100-git) extra 5,4 MB
jbigkit 2.1-5 (Required By: ricoh-sp100-git) community 50,2 kB
To build (1):
ricoh-sp100-git v0.3.r22.gef4c12d-1 AUR
Total download size: 7,5 MB
Total installed size: 19,9 MB
Edit build files : [e]
Apply transaction ? [e/y/N]
I would suggest that if you can’t follow the prior great suggestions to get your printer driver and related packages installed you need to do some research on how to use the OS you are intending to use.
Search the Archwiki for instructions on how to use an AUR helper. Pamac has this ability built in, but you must enable it yourself.
More research is required on your part if you are unable to grasp what people are suggesting to you here
Thank for your steps.
I have installed the printer it shows in printer connected.
But when I print something it doesn't work. In printer queue i can see the job and it vanish in sometime but printer doesn't print anything.
Please advise.
