Hi everyone, resume from hibernation stopped working again. Previously I had a similar problem that was fixed y adding a new service module to the dracut configuration file (this post).
I haven’t changed any configurations since then.
My garuda-inxi
Kernel: 6.6.11-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=cf1a950a-21a0-473c-ac72-bb7719092eb3 rw rootflags=subvol=@
resume=UUID=a97f3b45-3de3-4fee-bb58-2bb325bfbcaf ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Laptop System: HP product: HP ZBook Firefly 14 inch G8 Mobile
Workstation PC v: N/A serial: <superuser required> Chassis: type: 10
Mobo: HP model: 880D v: KBC Version 30.37.00 serial: <superuser required>
UEFI: HP v: T76 Ver. 01.08.00 date: 01/11/2022
ID-1: BAT0 charge: 39.8 Wh (100.0%) condition: 39.8/53.2 Wh (74.7%)
volts: 12.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full cycles: 179
Device-1: hid-34:88:5d:86:61:2a-battery model: Bluetooth Mouse
M336/M337/M535 serial: N/A charge: N/A status: discharging
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
microcode: 0xB4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3163 high: 3600 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 3195 2: 2700 3: 3600
4: 3542 5: 2871 6: 2689 7: 3600 8: 3114 bogomips: 44864
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117GLM [Quadro T500 Mobile] vendor: Hewlett-Packard
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 4 speed: 16 GT/s
lanes: 4 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1fbb
class-ID: 0302
Device-3: Chicony HP HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 04f2:b6bf
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
Monitor-1: eDP-1 model: AU Optronics 0x559c built: 2021 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.95 GiB unified: yes
API: Vulkan v: 1.3.274 layers: 4 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 23.3.3-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA T500 driver: nvidia v: 545.29.06 device-ID: 10de:1fbb
surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM 16.0.6)
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.6.11-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 297.52 GiB (62.4%)
model: MZVL2512HCJQ-00BH1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS2NGXH temp: 47.9 C scheme: MBR
ID-1: / raw-size: 62.7 GiB size: 62.7 GiB (100.00%) used: 26.67 GiB (42.5%)
ID-3: /home raw-size: 398.32 GiB size: 391 GiB (98.16%)
used: 270.85 GiB (69.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 62.7 GiB size: 62.7 GiB (100.00%)
used: 26.67 GiB (42.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 62.7 GiB size: 62.7 GiB (100.00%)
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: swap-2 type: zram size: 15.31 GiB used: 1.35 GiB (8.8%)
System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 304 Uptime: 26m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.31 GiB used: 6.5 GiB (42.5%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1879 libs: 451 tools: octopi,pamac,paru,yay
Shell: fish v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-07-09
Last full system update: 2024-01-03
Is partially upgraded: Yes
Here’s my grub config:
# GRUB boot loader configuration
GRUB_DEFAULT="1>3"
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Garuda"
GRUB_CMDLINE_LINUX_DEFAULT='quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 resume=UUID=a97f3b45-3de3-4fee-bb58-2bb325bfbcaf' # Modified by garuda-migrations: splash
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT=5
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME="/usr/share/grub/themes/garuda-dr460nized/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
GRUB_DISABLE_OS_PROBER=false
# This config file imports drop-in files from /etc/default/grub.d/.
for garuda_grub_d in ${sysconfdir}/default/grub.d/*.cfg ; do if [ -e "${garuda_grub_d}" ]; then source "${garuda_grub_d}"; fi; done
Here’s my fstab file:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=006C-30E2 /boot/efi vfat defaults,noatime 0 2
UUID=cf1a950a-21a0-473c-ac72-bb7719092eb3 / btrfs subvol=/@,defaults,noatime,compress=zstd 0 0
UUID=cf1a950a-21a0-473c-ac72-bb7719092eb3 /root btrfs subvol=/@root,defaults,noatime,compress=zstd 0 0
UUID=cf1a950a-21a0-473c-ac72-bb7719092eb3 /srv btrfs subvol=/@srv,defaults,noatime,compress=zstd 0 0
UUID=cf1a950a-21a0-473c-ac72-bb7719092eb3 /var/cache btrfs subvol=/@cache,defaults,noatime,compress=zstd 0 0
UUID=cf1a950a-21a0-473c-ac72-bb7719092eb3 /var/log btrfs subvol=/@log,defaults,noatime,compress=zstd 0 0
UUID=cf1a950a-21a0-473c-ac72-bb7719092eb3 /var/tmp btrfs subvol=/@tmp,defaults,noatime,compress=zstd 0 0
UUID=a4298782-ad2e-435d-834c-0105edffe861 /home ext4 defaults,noatime 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=a97f3b45-3de3-4fee-bb58-2bb325bfbcaf none swap defaults 0 0
Here’s my dracut config (/etc/dracut.conf.d/resume-from-hibernate.conf
add_dracutmodules+=" resume "
install_items+=" /usr/lib/systemd/system/systemd-hibernate-resume.service "
The last time I had this problem I added the last line to the previous file and ran sudo dracut-rebuild
. After that hibernation returned to work.
Any help is highly appreciated.
Thanks
