Refresh mirrorlist
There’s your problem Domain Name resolution.
Try changing your name server to 1.1.1.1
Garuda assistant has an easy way to alter your DNS server (select Cloudflare).
Reboot comp & router afterwards.
done, now what?
redo pings
kit@sussy in ~
λ ping -c5 google.com; ping -c5 8.8.8.8
PING google.com (66.102.1.138) 56(84) bytes of data.
--- google.com ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4097ms
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=110 time=106 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=110 time=96.3 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=110 time=109 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=110 time=86.0 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=110 time=81.8 ms
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4004ms
rtt min/avg/max/mdev = 81.780/95.821/109.065/10.705 ms
also i couldnt restart my router since my dad is uh sleeping next to it and i do not want to wake him up so :sweat_smile:
You usually can also reboot the router through the router configuration interface. The IP address you need to access it is brand/manufacturer specific. You will also need to know the access password, however most people simply/foolishly leave it at the router manufacturers default.
Post:
cat /etc/resolv.conf
kit@sussy in ~
λ cat /etc/resolv.conf
File: /etc/resolv.conf
# Generated by NetworkManager
nameserver 1.1.1.1
Try this:
bash -c "sudo dhclient -v -r $(hwinfo --netcard | grep "Device File" | cut -d " " -f5) && sudo dhclient -v $(hwinfo --netcard | grep "Device File" | cut -d " " -f5) && sleep 5 && sudo dhclient -v"
kit@sussy in ~
λ bash -c "sudo dhclient -v -r $(hwinfo --netcard | grep "Device File" | cut -d " " -f5) && sudo dhclient -v $(hwinfo --netcard | grep "Device File" | cut -d " " -f5) && sleep 5 && sudo dhclient -v"
fish: $(...) is not supported. In fish, please use '(hwinfo)'.
Sorry I'm old school I stick to bash, not fish. It leads to incompatibilities between the two.
oh i thought fish was basically bash with a different gui how do i switch to bash
Type bash
Or, stick with fish and try this instead:
Do not post the personal info such as MAC address returned from this command:
bash -c "sudo dhclient -v -r $(hwinfo --netcard | grep "Device File" | cut -d " " -f5)"
Then:
bash -c "sudo dhclient -v $(hwinfo --netcard | grep "Device File" | cut -d " " -f5)"
Then:
bash -c "sudo dhclient -v"
Sorry my editing got messed up try that again.
λ bash -c "sudo dhclient -v -r $(hwinfo --netcard | grep "Device File" | cut -d " " -f5)"
[sudo] password for kit:
Internet Systems Consortium DHCP Client 4.4.2-P1
Copyright 2004-2021 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/enp3s0/00:d8:61:05:d4:1f
Sending on   LPF/enp3s0/00:d8:61:05:d4:1f
Sending on   Socket/fallback
bash: line 2: wlo1: command not found
kit@sussy in ~ as 🧙 took 3s
[🔍] × bash -c "sudo dhclient -v $(hwinfo --netcard | grep "Device File" | cut -d " " -f5)"
DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 15
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
kit@sussy in ~ as 🧙 took 1m1s
[🔍] × bash -c "sudo dhclient -v"
Listening on LPF/wlo1/
Sending on   LPF/wlo1/
DHCPDISCOVER on wlo1 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 6
DHCPOFFER of  from
DHCPREQUEST for  on wlo1 to 255.255.255.255 port 67
DHCPACK of  from
RTNETLINK answers: File exists
mv: cannot move '/etc/resolv.conf.dhclient-new' to '/etc/resolv.conf': Operation not permitted
bound to  -- renewal in 2917 seconds.
Let's try this one more time:
Then:
Then:
ping -c5 cloudflare.com; ping -c5 1.1.1.1
kit@sussy in ~
λ bash
kit@sussy in ~ took 10ms
Killed old client process
kit@sussy in ~ as 🧙 took 5s
DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 3
DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 16
DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 11
[🔍] × ping -c5 cloudflare.com; ping -c5 1.1.1.1
PING cloudflare.com (104.16.133.229) 56(84) bytes of data.
--- cloudflare.com ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4127ms
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
--- 1.1.1.1 ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4134ms
Are you dual booting with windows?
yes i am dual booting windows
Uhhh crap.
Shut down your computer completely and then unplug the power supply for a couple of minutes, then restart your computer,
im kinda using a laptop do i just turn it off?
You need to remove the battery and the power supply after a full power down.
i need a screwdriver to access the battery and i dont even know where the power supply is and its like 1 am does it matter if i do this tomorrow
