I've searched everywhere for this and couldn't find anything. I've refreshed my mirrors and keyrings a few times as well. Everytime I run garuda-update I get this message:
warning: reflector-simple: local (2.0-1.1) is newer than garuda (2.0-1).
Should I ignore this and will I still receive updates? Or is there a fix for this?
Garuda-Inxi:
Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b0ba58ad-9009-4c7b-a39f-629a9e8d7df5 rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X512DAP_F512DA
Mobo: ASUSTeK model: X512DAP v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X512DAP.304 date: 02/02/2021
ID-1: BAT0 charge: 30.4 Wh (98.1%) condition: 31.0/37.1 Wh (83.6%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 261
Info: model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2019 high: 2600 min/max: 1400/2600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2600 2: 1425
3: 1454 4: 2600 bogomips: 20760
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 59.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.2:6
chip-ID: 13d3:56dd class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0903 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Vega 3 Graphics
(raven2 LLVM 15.0.7 DRM 3.52 6.3.2-zen1-1-zen) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5
API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.1:5
chip-ID: 13d3:3530 class-ID: e001 serial: <filter>
Local Storage: total: 238.72 GiB used: 40.61 GiB (17.0%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SD128 size: 119.48 GiB
block-size: physical: 512 B logical: 512 B type: USB tech: SSD
serial: <filter> scheme: GPT
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3128GJ3 size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: E8FK11.T temp: 37.9 C scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 15.31 GiB (12.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 9.66 GiB used: 1024 KiB (0.0%) priority: 100
System Temperatures: cpu: 59.5 C mobo: N/A gpu: amdgpu temp: 59.0 C
Fan Speeds (RPM): cpu: 2700
Processes: 239 Uptime: 3h 55m wakeups: 1 Memory: available: 9.66 GiB
used: 3.98 GiB (41.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1420
libs: 473 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date: 2023-05-19
Last full system update: 2023-05-19
