Lack of updates issue
I've had no updates for a couple of days now and I'm finding it a bit odd since I have always had some minor updates whenever I check, and I know there are numerous updates in the pipeline after taking a look at the Distrowatch Latest packages list.
The terminal shows this when I try and update...
:: Synchronising package databases...
 garuda downloading...
 core downloading...
 extra downloading...
 community downloading...
 multilib downloading...
 chaotic-aur downloading...
warning: reflector-simple: local (2.0-1.1) is newer than garuda (2.0-1)
 there is nothing to do
System updated! 🐧
...is the reflector-simple: local issue the reason for the lack of updates?
Here's my current system info:
  Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e0aa6bf1-e32d-48b2-a659-01e4322f83f8
    rw [email protected] quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
    resume=UUID=31f5f81c-4fb3-4a39-893a-3e7c25a0feb6 loglevel=3 ibt=off
  Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1 Distro: Garuda Linux
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA v: 1.0
  Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
    v: X513UA.312 date: 04/26/2022
  ID-1: BAT0 charge: 9.9 Wh (24.4%) condition: 40.5/42.1 Wh (96.4%) volts: 11.8 min: 11.8
    model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: discharging cycles: 320
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
    desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1863 high: 4041 min/max: 1400/4056 boost: enabled scaling:
    driver: acpi-cpufreq governor: ondemand cores: 1: 4028 2: 4041 3: 1400 4: 1400 5: 1400 6: 1698
    7: 1400 8: 1400 9: 1400 10: 1400 11: 1397 12: 1400 bogomips: 50307
  Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
    class-ID: 0300 temp: 41.0 C
  Device-2: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1 compositor: gnome-shell
    gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 dpi: 142 gamma: 1.2
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
  API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725 class-ID: 0280
  IF: wlp1s0 state: down mac: <filter>
  IF-ID-1: enp3s0f3u3 state: up speed: 150 Mbps duplex: half mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
 lanes: 1
    mode: 1.1 bus-ID: 3-2:2 chip-ID: 8087:0032 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
  Local Storage: total: 476.94 GiB used: 146.21 GiB (30.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-00000 size: 476.94 GiB
    fw-rev: FXV7101Q temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 6.29 GiB (4.3%) fs: btrfs
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
  ID-3: /home raw-size: 321.45 GiB size: 321.45 GiB (100.00%) used: 139.92 GiB (43.5%) fs: btrfs
  ID-4: /var/log raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 6.29 GiB (4.3%) fs: btrfs
  ID-5: /var/tmp raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 6.29 GiB (4.3%) fs: btrfs
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
    maj-min: 259:3
  ID-2: swap-2 type: zram size: 7.15 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
  System Temperatures: cpu: 47.8 C mobo: N/A gpu: amdgpu temp: 41.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 364 Uptime: 4h 50m wakeups: 1 Memory: available: 7.15 GiB used: 3.7 GiB (51.8%)
  Init: systemd v: 253 default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
  pm: pacman pkgs: 1342 libs: 371 tools: pamac,paru Client: shell wrapper v: 5.1.16-release
  inxi: 3.3.27
  System install date:     2022-12-05
  Last full system update: 2023-05-19
https://archlinux.org/news/git-migration-announcement/
And as always, the terminal output is incomplete.
It should always include the input command.
Precludes queries and is very helpful for beginners.
Solved by the God of Search yet again :grin:
I always update via the setup assistant, but I'll put the full command next time.
Yeeeach! I was gonna do a customized testing Archinstall from GitHub today--until I read the News. I would have made a mess of it for sure.
:wink:
See Here: Arch Linux - News: Git migration completed
soo... what is to do?
$ sudo pacman -Syu "pacman>=6.0.2-7"
[sudo] Passwort für leonavis:
:: Paketdatenbanken werden synchronisiert …
 garuda ist aktuell
 core ist aktuell
 extra ist aktuell
 community                               7,4 MiB  4,55 MiB/s 00:02 [------------------------------------] 100%
 multilib ist aktuell
 chaotic-aur                             2,4 MiB  3,27 MiB/s 00:01 [------------------------------------] 100%
Fehler: Ziel nicht gefunden: pacman>=6.0.2-7
Will garuda-update solve that in time or is there some manual labor to be done?
I think latest is
pacman -Qi pacman
Version                  : 6.0.2-6
Where is the problem? :slight_smile:
Update work fine here.
well I got it from the link from arch:
Mirrors are syncing again, but it may take a bit of time until your mirror of choice has caught up.
For users
Update your system and merge the pacman pacnew /etc/pacman.conf.pacnew file. This is required as we have moved the [community] repository into [extra].
$ pacman -Syu "pacman>=6.0.2-7"
sudo pacman -Syu pacman>=6.0.2-7
Warnung: pacman-6.0.2-6 ist aktuell -- Reinstalliere
Warnung: reflector-simple: Lokale Version (2.0-1.1) ist neuer als garuda (2.0-1)
:: Installation fortsetzen? [J/n] n
or
Within " "
Just wait :wink:
thought so. ^^
A very relevant video from a few days ago about the current situation...
"It's easy to forget just how old Arch Linux really is..."
Christ-on-a-crutch, I've got a loaf of bread older than Arch. :frowning:
