Realtek RTL8822CE - Wifi not working after update
Hello Garuda users.
i am unable to connect to any wireless network (it not working , i believe)
my
  Kernel: 5.19.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    root=UUID=3e1893cc-57b6-4afa-8b11-9de1b18374cf rw rootflags=subvol=@
    resume=UUID=7ce6a9df-91f6-4306-9558-41c17928fff4 loglevel=3
    wm: kwin_x11 vt: 1 dm: 1: LightDM v: 1.32.0 note: stopped 2: SDDM
    note: stopped Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506II_FA506II
  Mobo: ASUSTeK model: FA506II v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: FA506II.316 date: 03/12/2021
  ID-1: BAT1 charge: 35.9 Wh (100.0%) condition: 35.9/48.1 Wh (74.6%)
    volts: 12.6 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: full
  Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x60 (96) stepping: 1 microcode: 0x8600104
    L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1397 high: 1400 min/max: 1400/2900 boost: enabled
    scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1399 2: 1397
    3: 1397 4: 1397 5: 1397 6: 1400 7: 1397 8: 1400 9: 1397 10: 1397 11: 1397
    12: 1399 13: 1399 14: 1400 15: 1397 16: 1397 bogomips: 92627
    protection
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
    driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-07) arch: Turing code: TUxxx
    process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none empty: DP-1
    bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
  Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
    arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-4:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
    compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia gpu: amdgpu
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1521 built: 2020
    res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.2-zen1-1-zen)
    v: 4.6 Mesa 22.1.6 direct render: Yes
    gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
    snd_acp_pci, snd_sof_amd_renoir pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Sound Server-1: ALSA v: k5.19.2-zen1-1-zen running: yes
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
  IF-ID-1: enp5s0f3u2 state: unknown speed: -1 duplex: half mac: <filter>
  Device-1: Xiaomi Mi/Redmi series (RNDIS) type: USB driver: rndis_host
    v: kernel bus-ID: 1-2:6 chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
  Device-2: Lite-On Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 3-1:2 chip-ID: 04ca:4005 class-ID: e001 serial: <filter>
  Report: ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter>
  Local Storage: total: 700.51 GiB used: 345.55 GiB (49.3%)
    model: 2210 MTFDHBA512QFD size: 476.94 GiB block-size: physical: 512 B
    rev: P6MA001 temp: 39.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 model: HAZE 2.5 SSD 240GB size: 223.57 GiB
    serial: <filter> rev: 1A0 scheme: GPT
  ID-1: / raw-size: 401.01 GiB size: 401.01 GiB (100.00%) used: 345.52 GiB
    (86.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 25.9 MiB
    (8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 401.01 GiB size: 401.01 GiB (100.00%) used: 345.52
    GiB (86.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-4: /var/log raw-size: 401.01 GiB size: 401.01 GiB (100.00%) used: 345.52
  ID-5: /var/tmp raw-size: 401.01 GiB size: 401.01 GiB (100.00%) used: 345.52
  ID-1: swap-1 type: zram size: 7.19 GiB used: 592.2 MiB (8.0%)
  System Temperatures: cpu: 60.8 C mobo: N/A gpu: amdgpu temp: 62.0 C
  Processes: 400 Uptime: 11m wakeups: 1 Memory: 7.19 GiB used: 4.47 GiB
  (62.2%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.1.1 alt: 11 clang: 14.0.6 Packages: pacman: 1814
  lib: 406 Shell: Bash v: 5.1.16 running-in: kitty inxi: 3.3.20
Garuda (2.6.6-1):
  System install date:     2022-08-14
  Last full system update: 2022-08-20
  Failed units:            systemd-vconsole-setup.service
i also tried to look for
lshw -class network
*-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 15
       serial: 3c:7c:3f:eb:56:3d
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.19.2-zen1-1-zen firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:73 ioport:e000(size=256) memory:fc904000-fc904fff memory:fc900000-fc903fff
  *-network DISABLED
       description: Wireless interface
       product: RTL8822CE 802.11ac PCIe Wireless Network Adapter
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0
       version: 00
       serial: 94:08:53:53:ab:4b
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=rtw_8822ce driverversion=5.19.2-zen1-1-zen firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11
       resources: irq:82 ioport:d000(size=256) memory:fc800000-fc80ffff
  *-network
       physical id: 1
       bus info: usb@1:2
       logical name: enp5s0f3u2
       serial: 06:d5:7e:94:18:c9
       capabilities: ethernet physical
       configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=5.19.2-zen1-1-zen duplex=half firmware=RNDIS device ip=192.168.218.211 link=yes multicast=yes port=twisted pair
and i tried
sudo ifconfig wlp3s0 up
but i saw no result
but i believe this will be helpful
lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
	Subsystem: ASUSTeK Computer Inc. Device 1e21
	Kernel driver in use: pcieport
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1)
	Subsystem: ASUSTeK Computer Inc. Device 16df
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Subsystem: ASUSTeK Computer Inc. Device 208f
	Kernel driver in use: r8169
	Kernel modules: r8169
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
	Subsystem: Lite-On Communications Inc Device 0810
	Kernel driver in use: rtw_8822ce
	Kernel modules: rtw88_8822ce
04:00.0 Non-Volatile memory controller: Micron Technology Inc Device 5404 (rev 03)
	Subsystem: Micron Technology Inc Device 1100
	Kernel driver in use: nvme
	Kernel modules: nvme
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c6)
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
	Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
	Kernel driver in use: ccp
	Kernel modules: ccp
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
	Subsystem: ASUSTeK Computer Inc. Device 201f
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
	Subsystem: Device 1e21:1043
	Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
	DeviceName: HD Audio Controller
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
	Kernel driver in use: ahci
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
please help and thanks in advance
Which driver package are you using for this driver?
Have you rebuilt/reinstalled it since updating to kernel 5.19?
no i didnot , i only updated
That was not really what @jonathon was asking you. He was asking if you had installed any other proprietary Realtek driver. If so, what exactly was the source of any wifi driver you installed? The AUR or the Chaotic AUR is the best choice for most Realtek driver installations.
Have you searched the forum for how to install the proprietary Realtek driver? If you are still using the in - kernel driver module I would suggest testing other kernels. In order, the best alternate kernels to test are:
linux-lts
linux
linux-mainline
It would be a good idea to test alternate kernels, whether you are using one of the proprietary Realtek drivers or the in-kernel module.
Your Realtek Wifi adapter usually requires special steps to get it working. There are already extensive troubleshooting threads on the forum dealing with the rtl8822ce adapter if you search our forum.
Read this forum thread:
There are also many other threads in the “Networking Support” sub-forum relating to your adapter pre-existing on our forum. My search of the rtl8822ce adapter returns 19 hits from the Networking category on the forum:
https://forum.garudalinux.org/search?context=category&context_id=37&q=Rtl8822ce&skip_context=false
Hi
i’ll try this bur i’ve got exactly the same problem…just an update…it ask the password each time this morning (but keep it) and now i can’t connect at all to the wifi…same chip rtw_8822ce :wink:
19:07:43 kernel: audit: type=1131 audit(1661188063.983:330): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=geoclue comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
19:07:21 kernel: wlp3s0: disassociated from 8a:d0:67:18:f2:82 (Reason: 15=4WAY_HANDSHAKE_TIMEOUT)
19:07:20 kernel: audit: type=1131 audit(1661188040.465:320): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=user-runtime-dir@120 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
19:07:17 kernel: wlp3s0: associated
19:07:15 kernel: audit: type=1334 audit(1661188035.986:318): prog-id=0 op=UNLOAD
19:07:12 kernel: wlp3s0: aborting authentication with 8a:d0:67:18:f2:82 by local choice (Reason: 3=DEAUTH_LEAVING)
19:07:12 kernel: wlp3s0: send auth to 8a:d0:67:18:f2:82 (try 1/3)
19:07:11 kernel: wlp3s0: authenticate with 8a:d0:67:18:f2:82
sorry but i was using in kernel module i didn't install any driver and i searched the forum but nothing seems to match the problem i have and i also tried linux-lts ,linux, linux-hardened , but nothing seens to work
You'll need to install the proprietary driver given in my first hyperlink, and then create the required configuration files to get your wifi working.
this morning, it was working, and now not anymore (none changes !!)
i wonder why my wifi adapter is renamed wlp3s0…this morning, no…
Things don’t just break unless it’s a hardware failure - something must have changed.
ben si, apparently...and it's ok this afternoon !....and NOTHING changes except IP address perhaps :wink:
new info if somebody can help me :blush:
in fact, with a "normal" wifi and a box, everything is ok
but with my phone in 4g, with share connexion (tethering), doesn't work anymore...
no it didnot work
This thread is getting a little too confusing and vague.
I would suggest the OP to:
  • list the suggestions tried after the initial post.
  • provide any details, where applicable ("it did not work" means little: what did you try? did you get error messages? etc...)
  • provide the new/current state of the system or confirm that everything has been returned to the initial state (kernel, uninstalled proprietary drivers and blacklists removed, etc.).
I would ask @pommede to open a separate topic, because we are creating confusion about the problem, tests performed, etc. (hijacking? :wink: )
The above as moderator... Beyond that I only feel like adding a silly suggestion, but you never know. Verify:
rfkill list
As @filo already pointed out this is nearly meaningless as far as helping others troubleshoot your issue. Without terminal outputs of any driver installations and any config files that were created it is nigh on impossible to render assistance. Without full information on every step you have performed, assistance is futile.
i can do that but it's exactly the same problem and the same chip..after the same update..it was ok before :wink:
Okay. If you are sure the problem is the same let's continue here.
The fact that WiFi occasionally worked and the previous post that shifted the problem to tethering (which is another story) made me think otherwise. No prob.
infos.rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
and the journal
11:19:37 kernel: audit: type=1131 audit(1661505577.984:163): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
11:19:34 kernel: wlp3s0: disassociated from 8a:d0:67:18:f2:82 (Reason: 15=4WAY_HANDSHAKE_TIMEOUT)
11:19:30 kernel: wlp3s0: associated
11:19:30 kernel: wlp3s0: RX AssocResp from 8a:d0:67:18:f2:82 (capab=0x1431 status=0 aid=5)
11:19:30 kernel: wlp3s0: associate with 8a:d0:67:18:f2:82 (try 1/3)
11:19:30 kernel: wlp3s0: authenticated
11:19:30 kernel: wlp3s0: send auth to 8a:d0:67:18:f2:82 (try 1/3)
11:19:29 kernel: wlp3s0: authenticate with 8a:d0:67:18:f2:82
11:19:23 kernel: BTRFS info: devid 1 device path /dev/sdb5 changed to /dev/disk/by-uuid/d2382d1d-bc6d-4f40-b8be-c8f5a14023f3 scanned by Thread (pooled) (2911)
11:19:23 kernel: audit: type=1105 audit(1661505563.714:161): pid=2905 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
11:19:14 kernel: wlp3s0: disassociated from 8a:d0:67:18:f2:82 (Reason: 15=4WAY_HANDSHAKE_TIMEOUT)
11:19:06 kernel: audit: type=1131 audit(1661505546.286:150): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
11:19:01 kernel: wlp3s0: disassociated from 8a:d0:67:18:f2:82 (Reason: 15=4WAY_HANDSHAKE_TIMEOUT)
11:18:55 kernel: audit: type=1104 audit(1661505535.735:148): pid=533 uid=0 auid=120 ses=1 msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=garude-x405ua addr=? terminal=/dev/tty1 res=success'
11:18:51 kernel: rfkill: input handler disabled
11:18:50 kernel: audit: type=1130 audit(1661505530.490:145): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
11:18:50 kernel: kauditd_printk_skb: 7 callbacks suppressed
11:18:48 kernel: rfkill: input handler enabled
11:18:48 kernel: audit: type=1101 audit(1661505528.128:139): pid=1470 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="garude" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
11:18:41 kernel: wlp3s0: associated
11:18:40 kernel: audit: type=1131 audit(1661505520.356:131): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
11:18:38 kernel: Bluetooth: RFCOMM ver 1.11
11:18:38 kernel: audit: type=1130 audit(1661505518.180:128): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
11:18:38 kernel: kauditd_printk_skb: 169 callbacks suppressed
11:18:38 kernel: rfkill: input handler disabled
11:18:35 kernel: NET: Registered PF_ALG protocol family
11:18:35 kernel: Bluetooth: hci0: RTL: fw version 0xab6b705c
11:18:35 kernel: intel_tcc_cooling: Programmable TCC Offset detected
11:18:35 kernel: rtw_8822be 0000:03:00.0 wlp3s0: renamed from wlan0
11:18:35 kernel: input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card1/input19
11:18:35 kernel: r8169 0000:02:00.0 enp2s0: Link is Down
in case it helps.. :frowning:
this line is bothering me ?
Exactly. Those renamings are normal, but why rtw_8822be instead of rtw_8822ce???
In my opinion the way to go is really in the installation and proper configuration of the proprietary drivers, which worked for many forum users with your WiFi chipset, including blacklist, kernel boot parameters, etc. suggested earlier.
I suggest you try again and provide details.
ok i'll try again (but only my phone today :-()..
but like i said, the wifi with a box is ok...with my phone no (result up with my phone)
my bad i've got the rtw_8822be chip not the rtw_8822ce..but the pb is the same i think :thinking:
hi @tbg i tried the driver reinstallation as suggested by you but no success i can only connect to internet by ethernet/usb theatering and i belive @filo also suggested the same as you but no success my laptop still cannot detect wifi signals(i mean it is not showing any wifi network)
