Realtek RTL8822BE - wifi unable to connect
Kernel: 5.16.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=44a8aedb-d4a2-4821-a318-8639db755bfe rw rootflags=subvol=@
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
Mobo: HP model: 8477 v: 69.49 serial: <superuser required> UEFI: Insyde
v: F.18 date: 01/21/2019
ID-1: BAT1 charge: 24.0 Wh (57.6%) condition: 41.7/52.8 Wh (78.9%)
volts: 11.0 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3394 high: 3402 min/max: 400/3400 scaling:
driver: intel_pstate governor: performance cores: 1: 3401 2: 3400 3: 3401
4: 3400 5: 3401 6: 3402 7: 3349 8: 3401 bogomips: 28800
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0300
Device-3: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04ca:707f class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-zen1-1-zen running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b822 class-ID: 0280
IF: wlan0 state: up mac: <filter>
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-6:3 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 18.28 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3T0
ID-1: / raw-size: 487.78 GiB size: 487.78 GiB (100.00%)
used: 18.24 GiB (3.7%) fs: btrfs dev: /dev/sda8 maj-min: 8:8
used: 36.9 MiB (38.5%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 487.78 GiB size: 487.78 GiB (100.00%)
ID-4: /var/log raw-size: 487.78 GiB size: 487.78 GiB (100.00%)
ID-5: /var/tmp raw-size: 487.78 GiB size: 487.78 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 256 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 3.78 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 29.8 C pch: 29.5 C mobo: 27.8 C
Processes: 263 Uptime: 1h 15m wakeups: 2 Memory: 7.68 GiB
used: 3.52 GiB (45.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1859 lib: 548 Shell: fish
Garuda (2.5.4-2):
head: cannot open '/var/log/pacman.log' for reading: No such file or directory
System install date:
Last full system update: 2022-02-03
Failed units:            nmb.service
I've installed Garuda Linux on my machine and upgraded the system. However, after I reboot, I face a wifi connection problem : the network manager cannot detect my wifi router but only detects my phone if I set it as a mobile hotspot. I've been searching a lot for a fix to this issue and I even reinstalled Garuda so many times but after I reboot I come to face that annoying problem again.
I've tried many solutions provided for such a problem in various websites and forums and none of them did work :
restarting the network manager with sudo systemctl restart NetworkManager
disabling wifi powersave
adding 2 lines as following to /etc/NetworkManager/NetworkManager.conf:
[device]
wifi.scan-rand-mac-address=no
adding 2 lines as following to /etc/NetworkManager/conf.d/nm.conf :
[device]
wifi.backend=iwd
and I runned these commands :
sudo pacman -S iwd
sudo systemctl stop wpa_supplicant
sudo systemctl mask wpa_supplicant
sudo systemctl enable --now iwd.service
sudo systemctl daemon-reload
sudo systemctl start iwd.service
I also restarted my wifi router in vain
So what shall I do now ?
NOTE :
Sometimes when trying some of the mentionned fixes, the network manager detects my wifi router but it cannot connect to it and shows : Authorization supplicant failed
Hi there, welcome.
This is not enough information.
Let’s start providing your garuda-inxi as per the new topic template. :wink:
@filo Done
Mmm, nasty device I guess. I normally start searching for the device inside the Networking Support category, but haven-t found real solutions.
You may want to start reading these:
https://forum.garudalinux.org/search?q=%23issues-assistance%3Awifi-ethernet-bt%20RTL8822BE%20order%3Alatest
I hope someone will have other advices…
Install:
Then reboot and post:
grep -r "blacklist\|install\|options"  /etc/modprobe.d/ /etc/modules-load.d/ /usr/lib/modprobe.d/
could you guide me how to install it, as I'm an absolute Arch Linux beginner.
Have you tried booting into windows, then reboot (warm boot) into linux.
paru rtw88-dkms-git
I deleted WIndows, I'm managing to get used to Linux
# Maintainer: PRESFIL <echo cHJlc2ZpbEBwcm90b25tYWlsLmNvbQo= | base64 -d>
# Contributor: librewish <librewish@gmail.com
# Contributor:  Bjoern Franke <bjo+aur@schafweide.org>
# Contributor: feanor1397 <feanor1397@gmail.com>
pkgname=rtw88-dkms-git
_pkgname=rtw88
pkgver=r1.029812e
pkgrel=2
pkgdesc='Newest Realtek rtlwifi codes'
arch=('any')
url='https://github.com/lwfinger/rtw88'
depends=('dkms')
makedepends=('git' 'gcc' 'make')
provides=('rtlwifi_new-dkms')
conflicts=('rtlwifi_new-dkms')
provides=('rtlwifi_new-dkms' 'rtlwifi_new-extended-dkms-git' 'rtlwifi_new-rtw88-dkms')
conflicts=('rtlwifi_new-dkms' 'rtlwifi_new-extended-dkms-git' 'rtlwifi_new-rtw88-dkms')
replaces=('rtlwifi_new-extended-dkms-git' 'rtlwifi_new-rtw88-dkms-git')
install=${pkgname}.install
source=("git+https://github.com/lwfinger/rtw88.git")
sha256sums=('SKIP')
pkgver() {
cd "${_pkgname}"
printf "r%s.%s" "$(git rev-list --count HEAD)" "$(git rev-parse --short HEAD)"
What am I supposed to do now
press Q to quit the PKGBUILD review and then confirm to proceed with installation
/usr/lib/modprobe.d/amdgpu.conf:options amdgpu ppfeaturemask=0xffffffff
/usr/lib/modprobe.d/optimus-manager.conf:blacklist nouveau
/usr/lib/modprobe.d/optimus-manager.conf:blacklist nvidia_drm
/usr/lib/modprobe.d/optimus-manager.conf:blacklist nvidia_uvm
/usr/lib/modprobe.d/optimus-manager.conf:blacklist nvidia_modeset
/usr/lib/modprobe.d/systemd.conf:options bonding max_bonds=0
/usr/lib/modprobe.d/systemd.conf:options dummy numdummies=0
/usr/lib/modprobe.d/nvidia-utils.conf:blacklist nouveau
/usr/lib/modprobe.d/nvdimm-security.conf:install libnvdimm /usr/bin/ndctl load-keys ; /sbin/modprobe --ignore-
install libnvdimm $CMDLINE_OPTS
/usr/lib/modprobe.d/bluetooth-usb.conf:options btusb reset=1
/usr/lib/modprobe.d/nobeep.conf:blacklist pcspkr
/usr/lib/modprobe.d/noime.conf:blacklist mei
/usr/lib/modprobe.d/noime.conf:blacklist mei_me
Was this output above run after installing the driver?
yes, I installed that driver, executed that code with grep that resulted in that output
With a text editor create /etc/modprobe.d/rtl8822be.conf with the following contents:
blacklist rtw88
blacklist rtw_pci
Reboot.
If no love, try changing blacklist rtw_pci to blacklist rtwpci
I tried that in vain
Please help @tbg
Please do not beg for help nor ping team members with @.
It sounds rude, nobody is paid here, and last but not least, consider the time zones...
Sorry but I didn't mean to bother anyone
Ya, sorry buddy, but people got to sleep. I'm on the other side of the world from you.
I would suggest installing the linux-lts kernel, and then reinstall the driver on the LTS kernel.
Edit:
Also, you will need to check if a bios update is available from your laptop manufacturer. If their is a newer bios, you would be well advised to install it. Having removed Windows this would likely need to be done from a boot disk supporting Windows.
I would advise testing all of the following kernels. You can install kernels through the Garuda GUI for managing your hardware. Also be sure to install the corresponding headers.
This can be done in the terminal:
sudo pacman -Syu linux linux-headers
or:
sudo pacman -Syu linux-mainline linux-mainline-headers
or:
sudo pacman -Syu linux-lts linux-lts-headers
You switch kernels at the advanced grub menu when you reboot. Multiple kernels can be installed at the same time with Garuda.
Also, please post:
cat /etc/modprobe.d/rtl8822be.conf
You can also try revising the /etc/modprobe.d/rtl8822be.conf file. Remove any blacklist reference to rtw_pci or rtwpci and instead add:
options rtw_pci disable_aspm=Y
After revising the file again post:
I hope this is not backpedaling, but have you booted into your BIOS menu to ensure secure boot is disabled? It can interfere with the performance of wifi cards, especially new ones.
@BluishHumility That would more likely be fastboot you're thinking of. If secure boot was enabled Garuda would not boot.
This is unfortunately a wifi adapter with a long history of issues.
