[Realtek rtl8723be] - Fix dropped Wifi connections
I switched to Iwd as a backend for Network manager , Somehow Iwd gives me much better wifi speed than wpa supplicant , But the wifi disconnects and reconnects .
I see this error once that happens
Nov 23 15:47:27 Garuda kernel: rtlwifi: AP off, try to reconnect now
  Kernel: 6.11.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    root=UUID=e0869f39-b7a0-4c19-8e3f-ce38d8d65169 rw rootflags=subvol=@ loglevel=3
    sysrq_always_enabled=1 systemd.unified_cgroup_hierarchy=1 ibt=off
  Desktop: GNOME v: 47.1 tk: GTK v: 3.24.43 wm: gnome-shell tools: gsd-screensaver-proxy dm: GDM
    v: 47.0 Distro: Garuda base: Arch Linux
  Type: Laptop System: ASUSTeK product: X540LA v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X540LA v: 1.0 serial: <superuser required> part-nu: ASUS-NotebookSKU
    uuid: <superuser required> UEFI: American Megatrends v: X540LA.303 date: 08/31/2018
  ID-1: BAT0 charge: 25.8 Wh (97.7%) condition: 26.4/33.2 Wh (79.6%) volts: 10.8 min: 10.8
    model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: not charging cycles: 862
  Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell gen: core 5 level: v3
    note: check built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
    microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2 smt: enabled cache:
    L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1995 min/max: 500/1900 scaling: driver: intel_cpufreq governor: performance
    cores: 1: 1995 2: 1995 3: 1995 4: 1995 bogomips: 15962
  Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel arch: Gen-8
    process: Intel 14nm built: 2014-15 ports: active: DP-1 off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:1616 class-ID: 0300
  Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 13d3:5a11 class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4 compositor: gnome-shell
    driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: DP-1 model: Samsung SyncMaster serial: <filter> built: 2009 res: 1600x900 dpi: 92
    gamma: 1.2 size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes: max: 1600x900
    min: 720x400
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x15dc built: 2015 res: 1366x768 dpi: 101 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
  API: Vulkan v: 1.3.295 layers: 3 device: 0 type: integrated-gpu name: Intel HD Graphics 5500
    (BDW GT2) driver: mesa intel v: 24.2.7-arch1.1 device-ID: 8086:1616 surfaces: xcb,xlib,wayland
  Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
  API: ALSA v: k6.11.9-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.2 chip-ID: 10ec:8136
  IF: enp2s0f2 state: down mac: <filter>
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On driver: rtl8723be
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b723
  IF: wlan0 state: up mac: <filter>
  Info: services: iwd, NetworkManager, systemd-timesyncd
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-4:3 chip-ID:
0bda:b721 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 8 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
    discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 704.24 GiB used: 666.75 GiB (94.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253256GB size: 238.47 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 227N
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD5000LPCX-80VHAT1 size: 465.76 GiB
    fw-rev: 1A02 scheme: GPT
  ID-1: / raw-size: 15.18 GiB size: 15.18 GiB (100.00%) used: 10.35 GiB (68.2%) fs: btrfs
    dev: /dev/sda2 maj-min: 8:2
  ID-2: /home raw-size: 19.53 GiB size: 19.53 GiB (100.00%) used: 17.88 GiB (91.5%) fs: btrfs
    dev: /dev/sda4 maj-min: 8:4
  ID-3: /var/log raw-size: 15.18 GiB size: 15.18 GiB (100.00%) used: 10.35 GiB (68.2%) fs: btrfs
  ID-4: /var/tmp raw-size: 15.18 GiB size: 15.18 GiB (100.00%) used: 10.35 GiB (68.2%) fs: btrfs
  ID-1: swap-1 type: zram size: 7.43 GiB used: 1.12 GiB (15.1%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
  System Temperatures: cpu: 58.0 C pch: 52.0 C mobo: N/A
  Memory: total: 8 GiB note: est. available: 7.43 GiB used: 4.14 GiB (55.7%)
  Processes: 274 Power: uptime: 2d 10h 7m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 7 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 2.96 GiB
    services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
  Packages: 1107 pm: pacman pkgs: 1062 libs: 272 tools: gnome-software,paru pm: flatpak pkgs: 45
    Compilers: gcc: 14.2.1 Client: shell wrapper v: 5.2.37-release inxi: 3.3.36
  System install date:     2024-09-21
  Last full system update: 2024-11-23 ↻
As always the first source to check should be the ArchWiki:
https://wiki.archlinux.org/title/Network_configuration/Wireless
Pertinent ArchWiki section:
The rtl8723ae and rtl8723be modules are included in the mainline Linux kernel.
Some users may encounter errors with powersave on this card. This is shown with occasional disconnects that are not recognized by high level network managers (netctl, NetworkManager). This error can be confirmed by running dmesg -w as root or journalctl -f as root and looking for output related to powersave and the rtl8723ae/rtl8723be module. If you have this issue, use the fwlps=0 kernel module parameter which should prevent the WiFi card from automatically sleeping and halting connection.
If you have poor signal, perhaps your device has only one physical antenna connected, and antenna autoselection is broken. You can force the choice of antenna with ant_sel=1 or ant_sel=2 kernel option.
I can’t use this option because it breaks the bluetooth
if you have poor signal, perhaps your device has only one physical antenna connected, and antenna autoselection is broken. You can force the choice of antenna with ant_sel=1 or ant_sel=2 kernel option.
and this use the fwlps=0 kernel module parameter didn’t help either
Below are numerous general tips that can help remedy dropped WiFi connections:
Disable MAC Address Randomization with the following command:
echo -e "[device]\nwifi.scan-rand-mac-address=no" | sudo tee /etc/NetworkManager/conf.d/disable-random-mac.conf
After modifying Network Manager’s configuration in any way, reboot both your router and your computer.
Disable Network Manager’s WiFi power saving features with the following command:
echo -e "[connection]\nwifi.powersave = 0" | sudo tee /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
A setting of “0” will totally disable power saving features in the WiFi adapter.
A setting of “2” or “1” will be less aggressive, but still leave power saving enabled.
Add the following kernel boot parameters to grub:
ipv6.disable=1 pcie_aspm=off
The following command will automatically add the above kernel boot parameter to /etc/default/grub:
sudo cp /etc/default/grub /etc/default/grub.bak && sudo sed '/^GRUB_CMDLINE_LINUX_DEFAULT=/s/"$/ ipv6.disable=1 pcie_aspm=off"/g' -i /etc/default/grub
After adding the boot parameters, run:
sudo update-grub
Then reboot
Try locking your Wifi connection to your AP’s SSID in network manager.
You can do this in Network Manager’s “Wi-Fi” tab in your WiFi connection’s properties settings.
There is a “BSSID” drop down field where you can select and lock your home Wi-Fi to a single BSSID.
Try assigning your computer a static IP address via MAC address association through your router configuration settings.
Set a fixed wifi channel that is the least congested in your router configuration utility.
There are utilities you can install on your cel phone to diagnose the wifi traffic in your area and help identify the best channel to select.
Test your wifi on the 2.4 GHz band, and be sure you have separate BSSID’s for the 2.4 and 5 GHz bands set in your router.
I hope some of those tips help.
I will add more Realtek specific tips on another post.
Thank you , I think that fixed the issue .
Please let others know if you can identify which suggestion(s) helped fix your issues.
Glad that helped.
I applied them all , I can’t tell which one helped exactly .
Continuing the discussion from [Realtek rtl8723be] - Fix dropped Wifi connections:
The issue still occurs , but less often .
  Kernel: 6.12.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    sysrq_always_enabled=1 systemd.unified_cgroup_hierarchy=1 ipv6.disable=1 pcie_aspm=off ibt=off
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell tools: gsd-screensaver-proxy dm: GDM
  ID-1: BAT0 charge: 25.4 Wh (97.7%) condition: 26.0/33.2 Wh (78.3%) volts: 10.8 min: 10.8
    model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: not charging cycles: 869
    microcode: 0x2F
  Speed (MHz): avg: 1996 min/max: 500/1900 scaling: driver: intel_cpufreq governor: performance
    cores: 1: 1996 2: 1996 3: 1996 4: 1996 bogomips: 15962
  Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4 compositor: gnome-shell
    min: 720x400
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
    drv: iris surfaceless: drv: iris wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2) device-ID: 8086:1616
    memory: 3.63 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: Intel HD Graphics 5500
    (BDW GT2) driver: N/A device-ID: 8086:1616 surfaces: xcb,xlib,wayland
  API: ALSA v: k6.12.7-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse status: active
    mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b721 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 12 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
  Local Storage: total: 704.24 GiB used: 662.76 GiB (94.1%)
  ID-1: / raw-size: 15.18 GiB size: 15.18 GiB (100.00%) used: 9.79 GiB (64.5%) fs: btrfs
  ID-2: /home raw-size: 19.53 GiB size: 19.53 GiB (100.00%) used: 14.69 GiB (75.2%) fs: btrfs
  ID-3: /var/log raw-size: 15.18 GiB size: 15.18 GiB (100.00%) used: 9.79 GiB (64.5%) fs: btrfs
  ID-4: /var/tmp raw-size: 15.18 GiB size: 15.18 GiB (100.00%) used: 9.79 GiB (64.5%) fs: btrfs
  ID-1: swap-1 type: zram size: 7.43 GiB used: 1.67 GiB (22.5%) priority: 100 comp: zstd
    avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4 dev: /dev/zram0
  System Temperatures: cpu: 51.0 C pch: 46.5 C mobo: N/A
  Memory: total: 8 GiB note: est. available: 7.43 GiB used: 4.23 GiB (57.0%)
  Processes: 283 Power: uptime: 5d 4h 40m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 11 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 2.96 GiB
    services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 257 default: graphical
  Packages: 1133 pm: pacman pkgs: 1092 libs: 296 tools: gnome-software,paru pm: flatpak pkgs: 41
  Last full system update: 2025-01-02 ↻
  Failed units:            archlinux-keyring-wkd-sync.service
Is your router in a congested area with a lot of other networks in the vicinity?
Run a Network Manager live journal log session:
Enable Network Manager’s debugging mode with the following command:
echo -e "[logging]\nlevel=DEBUG" | sudo tee /etc/NetworkManager/conf.d/00-defaults.conf
The above command will enable more in depth logging of any problems encountered by Network Manager.
To begin logging, open a new window or tab in your terminal emulator and run the following command:
journalctl -fu NetworkManager
Let the command run in the terminal, logging all current network activities.
To put a little stress on your internet connection, perform a series of activities such as:
Repeatedly connect and disconnect your WiFi using Network Manager’s tray applet.
Download a variety of files, some small and also some very large size files.
In a separate terminal window from the one recording the log, ping Google’s IP address (8.8.8.8) and also its domain name as well as the localhost. Post your ping results from before and after a disconnection occurs. Please search online if you are unfamiliar with how to use the ping command.
Please post as much useful information from the NM log as will provide a reasonable overview of what is occurring with your network connection. You do not need to post the entire log, but post the events leading up to and after any disruption in connectivity.
this is the log when I issue occurred
Jan 03 14:30:35 Garuda NetworkManager[650]: <info>  [1735911035.1074] device (wlan0): new IWD device state is disconnected
Jan 03 14:30:35 Garuda NetworkManager[650]: <info>  [1735911035.1076] device (wlan0): state change: activated -> failed (reason 'supplicant-disconnect', managed-type: 'full')
Jan 03 14:30:35 Garuda NetworkManager[650]: <info>  [1735911035.1082] manager: NetworkManager state is now DISCONNECTED
Jan 03 14:30:35 Garuda NetworkManager[650]: <warn>  [1735911035.1086] device (wlan0): Activation: failed for connection 'Airbox-EBE3'
Jan 03 14:30:35 Garuda NetworkManager[650]: <info>  [1735911035.1104] device (wlan0): state change: failed -> disconnected (reason 'none', managed-type: 'full')
Jan 03 14:30:35 Garuda NetworkManager[650]: <info>  [1735911035.1180] dhcp4 (wlan0): canceled DHCP transaction
Jan 03 14:30:35 Garuda NetworkManager[650]: <info>  [1735911035.1200] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jan 03 14:30:35 Garuda NetworkManager[650]: <info>  [1735911035.1210] dhcp4 (wlan0): state changed no lease
Jan 03 14:30:37 Garuda NetworkManager[650]: <info>  [1735911037.0825] device (wlan0): new IWD device state is connecting
Jan 03 14:30:37 Garuda NetworkManager[650]: <info>  [1735911037.0833] device (wlan0): Activation: starting connection 'Airbox-EBE3' (06d30d95-2820-482d-8d71-cbe49abfc81a)
Jan 03 14:30:37 Garuda NetworkManager[650]: <info>  [1735911037.0836] device (wlan0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
Jan 03 14:30:37 Garuda NetworkManager[650]: <info>  [1735911037.0853] manager: NetworkManager state is now CONNECTING
Jan 03 14:30:37 Garuda NetworkManager[650]: <info>  [1735911037.0873] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full')
Jan 03 14:30:37 Garuda NetworkManager[650]: <info>  [1735911037.2478] device (wlan0): new IWD device state is connected
Jan 03 14:30:37 Garuda NetworkManager[650]: <info>  [1735911037.2481] device (wlan0): state change: config -> ip-config (reason 'none', managed-type: 'full')
Jan 03 14:30:37 Garuda NetworkManager[650]: <info>  [1735911037.2489] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jan 03 14:30:39 Garuda NetworkManager[650]: <info>  [1735911039.2952] dhcp4 (wlan0): state changed new lease, address=192.168.1.193, acd pending
Jan 03 14:30:39 Garuda NetworkManager[650]: <info>  [1735911039.4250] dhcp4 (wlan0): state changed new lease, address=192.168.1.193
Jan 03 14:30:39 Garuda NetworkManager[650]: <info>  [1735911039.4255] policy: set 'Airbox-EBE3' (wlan0) as default for IPv4 routing and DNS
Jan 03 14:30:39 Garuda NetworkManager[650]: <info>  [1735911039.4603] device (wlan0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
Jan 03 14:30:39 Garuda NetworkManager[650]: <info>  [1735911039.4966] device (wlan0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
Jan 03 14:30:39 Garuda NetworkManager[650]: <info>  [1735911039.4969] device (wlan0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
Jan 03 14:30:39 Garuda NetworkManager[650]: <info>  [1735911039.4975] manager: NetworkManager state is now CONNECTED_SITE
Jan 03 14:30:39 Garuda NetworkManager[650]: <info>  [1735911039.4979] device (wlan0): Activation: successful, device activated.
Jan 03 14:30:39 Garuda NetworkManager[650]: <info>  [1735911039.7685] manager: NetworkManager state is now CONNECTED_GLOBAL
