my network speed is unstable and keeps dropping to zero.
I tried lts and zen kernels. rebooted the computer and router, hardwired with an ethernet cable. even the ethernet cable keeps dropping speed not just the wifi,
I ran all the commands in this post
λ garuda-inxi
Kernel: 6.12.30-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=aed9da9f-5ce9-4e9e-8dbb-f066d90ce36e rw rootflags=subvol=@
resume=UUID=fd3dc478-5aa0-4469-883a-bdbfde213bad loglevel=3 quiet ibt=off
Type: Desktop System: ASRock product: Z690M-ITX/ax v: N/A
Mobo: ASRock model: Z690M-ITX/ax serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 20.01
date: 10/04/2024
Device-1: hid-04:4b:ed:eb:cc:93-battery model: Claudia's Trackpad
serial: N/A charge: N/A status: discharging
Info: model: 12th Gen Intel Core i5-12600KF bits: 64 type: MST AMCP
microcode: 0x36
Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB
desc: 1x20 MiB
Speed (MHz): avg: 800 min/max: 800/4900:3600 scaling: driver: intel_pstate
bogomips: 118000
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] vendor: XFX Pine driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1
empty: DP-2,DP-3,DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 32.0 C
Device-2: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3
chip-ID: 046d:085e class-ID: 0102 serial: <filter>
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
model: Acer EB321HQ A serial: <filter> built: 2021 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 70 gamma: 1.2 size: 698x393mm (27.48x15.47")
diag: 801mm (31.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: left model: Samsung C27F390
serial: <filter> built: 2021 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
polaris10 ACO DRM 3.61 6.12.30-1-lts) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.4.313 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv v: 25.1.1-arch1.2
device-ID: 1002:67df surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.1.1-arch1.2 (LLVM
Device-1: Intel Alder Lake-S HD Audio vendor: ASRock driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon
RX 470/480 / 570/580/590] vendor: XFX Pine driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
Device-3: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
Device-4: Sitronix Kawaii driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5
chip-ID: 1403:3333 class-ID: 0300 serial: <filter>
API: ALSA v: k6.12.30-1-lts status: kernel-api with: aoss
Device-2: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1d class-ID: 0200
Device-3: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0033
Local Storage: total: 2.76 TiB used: 592.35 GiB (21.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 48.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Walgreen model: Infinitive
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 592.35 GiB (32.4%)
used: 592.35 GiB (32.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.17 GiB used: 7.8 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.29 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.5 C mobo: N/A gpu: amdgpu temp: 32.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 672
Memory: total: 32 GiB available: 31.18 GiB used: 3.1 GiB (9.9%)
Processes: 408 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2038 libs: 583 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date: 2025-03-07
Last full system update: 2025-05-30
Relevant software: snapper NetworkManager dracut(custom) mkinitcpio
appreciate the help guys
