Hi!
Something strange happened when I upgraded Garuda. I should have device2 in the networking part of the inxi with TP-Link TL-WN823N and rtl8192eu-dkms as a driver for it, but instead there’s nothing. I checked that my blacklist for rtl8xxxu (if I remember this right as I’m writing this on another computer) is still in place and the aforementioned driver installed and they seem to be there, but not in use and no network connection either.
Here’s the inxi and after it, an exerpt from pacman.log where the error occurred and after that, an another exerpt from the file mentioned after the error line in the log.
Kernel: 6.13.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=069e92bc-7096-454e-acbc-99c4eff50739 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: H510M K V2 v: -CF
Mobo: Gigabyte model: H510M K V2 v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F2 date: 06/07/2023
Info: model: Intel Core i3-10105F bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 3 microcode: 0xFC
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/4400 scaling: driver: intel_pstate
8: 800 bogomips: 59197
Device-1: Intel DG2 [Arc A310] vendor: ASRock driver: i915 v: kernel
alternate: xe arch: Xe-HPG code: Alchemist process: TSMC n6 (7nm)
built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: HDMI-A-1
empty: DP-1,HDMI-A-2 bus-ID: 03:00.0 chip-ID: 8086:56a6 class-ID: 0300
Monitor-1: HDMI-A-1 model: HP 24y serial: <filter> built: 2019 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
size: 528x297mm (20.79x11.69") diag: 606mm (23.9") ratio: 16:9 modes:
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A310 Graphics (DG2)
device-ID: 8086:56a6 memory: 3.86 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.304 layers: 10 device: 0 type: discrete-gpu name: Intel
Arc A310 Graphics (DG2) driver: N/A device-ID: 8086:56a6
Device-1: Intel Comet Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
Device-2: Intel DG2 Audio vendor: ASRock driver: snd_hda_intel v: kernel
pcie: speed: Unknown lanes: 63 link-max: gen: 1 speed: 2.5 GT/s
bus-ID: 04:00.0 chip-ID: 8086:4f92 class-ID: 0403
API: ALSA v: k6.13.7-zen1-1-zen status: kernel-api with: aoss
lanes: 1 port: 3000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 129.9 GiB used: 92.57 GiB (71.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU650 size: 111.79 GiB
serial: <filter> fw-rev: 831a scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: Multi Flash Reader size: 3.69 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 1.00 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler 2.0
size: 14.42 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00
ID-1: / raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
used: 82.94 GiB (74.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 19.3 MiB (6.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
ID-4: /var/log raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
System Temperatures: cpu: 57.0 C pch: 50.0 C mobo: 42.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB available: 15.53 GiB used: 2.3 GiB (14.8%)
Processes: 272 Power: uptime: 1h 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2013 libs: 576 tools: octopi,pacseek,paru
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date: 2024-12-08
Last full system update: 2025-03-21
Failed units: nmb.service
THE MOMENT OF UPGRADE FAILURE FROM THE PACMAN.LOG:
[2025-03-21T13:39:16+0200] [ALPM] running '70-dkms-install.hook'...
[2025-03-21T13:39:16+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod digimend-kernel-drivers/11.r42.gf3c7c7f -k 6.13.7-zen1-1-zen
[2025-03-21T13:39:19+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.14.0 -k 6.13.7-zen1-1-zen
[2025-03-21T13:39:22+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.14.0 -k 6.12.9-zen1-1-zen
[2025-03-21T13:39:25+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod rtl8192eu/5.6.4.r302.g2fddecc -k 6.13.7-zen1-1-zen
[2025-03-21T13:40:08+0200] [ALPM-SCRIPTLET]
[2025-03-21T13:40:08+0200] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.13.7-zen1-1-zen (x86_64)
[2025-03-21T13:40:08+0200] [ALPM-SCRIPTLET] Consult /var/lib/dkms/rtl8192eu/5.6.4.r302.g2fddecc/build/make.log for more information.
[2025-03-21T13:40:08+0200] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod rtl8192eu/5.6.4.r302.g2fddecc -k 6.13.7-zen1-1-zen' exited 10
[2025-03-21T13:40:08+0200] [ALPM-SCRIPTLET] ==> depmod 6.13.7-zen1-1-zen
[2025-03-21T13:40:10+0200] [ALPM-SCRIPTLET] ==> depmod 6.12.9-zen1-1-zen
[2025-03-21T13:40:11+0200] [ALPM] running '80-check-broken-packages.hook'...
AN EXERPT FROM THE END OF THE FILE ASKED TO BE CONSULTED:
os_dep/linux/ioctl_cfg80211.c:674:5: warning: no previous prototype for 'nl80211_iftype_to_rtw_mlme_state' [>
674 | u32 nl80211_iftype_to_rtw_mlme_state(enum nl80211_iftype type)
os_dep/linux/ioctl_cfg80211.c:2090:5: warning: no previous prototype for 'cfg80211_rtw_set_default_mgmt_key'>
2090 | int cfg80211_rtw_set_default_mgmt_key(struct wiphy *wiphy,
os_dep/linux/ioctl_cfg80211.c:2614:5: warning: no previous prototype for 'rtw_cfg80211_is_target_wps_scan' [>
2614 | int rtw_cfg80211_is_target_wps_scan(struct cfg80211_scan_request *scan_req, struct cfg80211_ssid *ta>
os_dep/linux/ioctl_cfg80211.c: In function 'cfg80211_rtw_connect':
os_dep/linux/ioctl_cfg80211.c:3899:32: warning: implicit conversion from 'enum mlme_auth_type' to 'enum nl80>
3899 | sme->auth_type = MLME_AUTHTYPE_SAE;
os_dep/linux/ioctl_cfg80211.c: At top level:
os_dep/linux/ioctl_cfg80211.c:5227:6: warning: no previous prototype for 'dump_station_parameters' [-Wmissin>
5227 | void dump_station_parameters(void *sel, struct wiphy *wiphy, const struct station_parameters *params)
os_dep/linux/ioctl_cfg80211.c:5756:18: warning: no previous prototype for 'rtw_sta_info_get_by_idx' [-Wmissi>
5756 | struct sta_info *rtw_sta_info_get_by_idx(struct sta_priv *pstapriv, const int idx, u8 *asoc_list_num)
os_dep/linux/ioctl_cfg80211.c:9792:5: warning: no previous prototype for 'cfg80211_rtw_external_auth' [-Wmis>
9792 | int cfg80211_rtw_external_auth(struct wiphy *wiphy, struct net_device *dev,
os_dep/linux/ioctl_cfg80211.c:9953:32: error: initialization of 'int (*)(struct wiphy *, struct net_device *>
9953 | .set_monitor_channel = cfg80211_rtw_set_monitor_channel,
os_dep/linux/ioctl_cfg80211.c:9953:32: note: (near initialization for 'rtw_cfg80211_ops.set_monitor_channel')
make[4]: *** [/usr/lib/modules/6.13.7-zen1-1-zen/build/scripts/Makefile.build:196: os_dep/linux/ioctl_cfg802>
make[3]: *** [/usr/lib/modules/6.13.7-zen1-1-zen/build/Makefile:1987: .] Error 2
make[2]: *** [/usr/lib/modules/6.13.7-zen1-1-zen/build/Makefile:251: __sub-make] Error 2
make[2]: Leaving directory '/var/lib/dkms/rtl8192eu/5.6.4.r302.g2fddecc/build'
make[1]: *** [Makefile:251: __sub-make] Error 2
make[1]: Leaving directory '/usr/lib/modules/6.13.7-zen1-1-zen/build'
make: *** [Makefile:2287: modules] Error 2
# exit code: 2
# elapsed time: 00:00:43
Can I somehow revert the part of upgrade which led to this or what? The correct driver is still at least locally available as I can uninstall it if I want. The device2 is still connected and worked perfectly up to the end of the upgrade, but disappeared right after that when I restarted the system.
