I installed Garuda Qtile to my laptop a couple days ago because I've wanted to try out a tiling window manager. I daily drove KDE Plasma on my desktop for most of 2021, but swapped back to using Windows because of school and some certain games, as well as having to unplug and replug my mic on every boot to get it to work. So I'm somewhat familiar with linux and using the terminal, but I would no way say I'm an advance user or even an intermediate user. I typically save modifying config files as a last resort, but I have had to do so in the past.
My issue is that when I close my lid to my laptop while it is on, it goes to sleep no problem, but when I open it back up it goes back to sleep within 30 seconds. it doesn't matter if I'm in the middle of typing, moving my mouse, having a video play, or anything. It's working fine, then my mouse disappears, shortly followed by the screen going black and the computer going to sleep. It will only wake up if I press a key, but then 30 seconds later the same thing happens. The only way to stop it is by completely restarting it.
I've slightly configured Qtile, but it's only been changing keybinds and customizing the color of the bar. Other than that it should be stock.
Kernel: 5.16.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=7904edb5-ff2e-4dfb-b6bc-3b55c6c6fa69 rw [email protected]
Desktop: Qtile 0.20.0 wm: LG3D vt: 1 dm: SDDM Distro: Garuda Linux
Type: Laptop System: Razer product: Blade 15 Mid 2019-Base v: 3.04
serial: <superuser required> Chassis: type: 10
Mobo: Razer model: DA530 serial: <superuser required> UEFI: Razer
v: 1.02 date: 05/16/2019
ID-1: BAT0 charge: 57.6 Wh (88.3%) condition: 65.2/65.0 Wh (100.3%)
volts: 16.4 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: Discharging
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 869 high: 1636 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 1636 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 62399
Type: l1tf
Type: spectre_v2 mitigation: Full generic retpoline, IBPB:
conditional, IBRS_FW, STIBP: conditional, RSB filling
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Razer USA
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Razer USA
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: none empty: DP-3, DP-4, DP-5, HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: IMC Networks USB Camera type: USB driver: uvcvideo
bus-ID: 1-7:2 chip-ID: 13d3:56bd class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: Picom v: git-c4107
driver: X: loaded: modesetting,nvidia gpu: i915 display-ID: :0
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: BOE Display built: 2019 res: 1920x1080 hz: 144
dpi: 142 gamma: 1.2 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
Device-1: Intel Cannon Lake PCH cAVS vendor: Razer USA
Device-2: NVIDIA TU106 High Definition Audio vendor: Razer USA
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
Sound Server-1: ALSA v: k5.16.12-zen1-1-zen running: yes
vendor: Razer USA driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 476.94 GiB used: 10.7 GiB (2.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: LITE-ON model: CA3-8D512
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: C490903
temp: 37.9 C scheme: GPT
used: 10.7 GiB (2.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 27.8 C pch: 55.0 C mobo: N/A
Processes: 328 Uptime: 4m wakeups: 1 Memory: 15.52 GiB
used: 2.49 GiB (16.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1156 lib: 298 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-07
Last full system update: 2022-03-08
