Hello.
I have a problem with my wifi adaptor.
The problem is this : when I boot my pc ( from shutdown mode) all thing ok and my wifi adaptor finds the modems and It connect automatically to my network but when I restart from windows or linux to boot to the linux , then my wifi adaptor light is turned on after booting to linux but not finding the modems to connect.
I should say that I dont have any problem with this wifi adaptor on my windows 10 and 11.
And I should add this : I test other wifi adaptor and it works with no problems but this adaptor have problem after restart to boot to linux !
I should say that I had this problem in other distros too and in garuda I have problem in connecting to network( because the driver not installed on garuda like other distros) and one of the admins says to install rtw88-dkms-git and that problem fixed that it reconnect to net randomly).
but as I said I have problem after restart that my adaptor not find the modems and I should always replug my wifi adaptor to find my modems after restart mode.
Running Windows in a dual boot can often cause wifi problems. You will need to ensure all wifi powersaving in Windows and fastboot are disabled. Search the forum for directions if you are unsure how to do that. Post your exact steps you took to do this.
Do you use bluetooth, because you have a failed bluetooth service listed in your inxi output.
Also be sure to test the LTS and mainline kernels and possibly others.
yes before I test other wifi adaptor Bus 001 Device 005: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter I thought like you that dual boot can cause problem.
in MT7601U adaptor I dont see problem after restart on linux and it is ok all the time I can say.
But with rt2870/rt3070 wifi adaptor I have problem after restart on linux.
I test lts kernel but nothing happen and not help me.
about linux kernel and mainline kernel , I want to test them but when I choose them on grub panel after boot my machine , they can’t load the garuda linux and stuck at loading linux kernel black page.
power saving for wifi was turned off at windows device manager settings and fastboot is disabled from uefi settings.
Are you sure you give me a correct driver for my wifi adaptor?
before I install it I have problem in connecting to internet but after it was fixed but the main problem not fixed( I mean the problem that wifi not find net after restart).
I ask are you sure , because the driver likely for the 8822ce, de ,… models.
because in the below topic the who has the problem with his adaptor is other model : Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
And I should say that I dont have any bluetooth device at all and that problem because maybe I dont have bluetooth device.
This doesn’t make much sense, Realtek drivers cannot be used for Railink/Mediatek wifi adapter’s.
I have absolutely no idea what you are talking about. I did not recommend the rtl8822ce driver for your Ralink wifi adapter. You are confusing apples with oranges. Again, Realtek drivers will not work for Ralinink wifi adapter’s. Just because the adapter models both start with the letters rt does not mean they are from the same company. An RTL adapter is Realtek, an adapter beginning with RT is from Ralink. They are completely different manufacturers using completely different drivers.
Do not install Realtek drivers for Ralink adapters, (and vice versa).
yes I knew what you have said there.
but I thought you said that I should do the way you say in this topic
because you say there that you already posted this once yesterday here:
then you mean what when you said to me ,I already posted this once yesterday?
and what driver I should install for my wifi adaptor?
because in the below link its link for similar drivers not worked.( the link not shows any package on arch aur website) https://bbs.archlinux.org/viewtopic.php?id=164042
ok but now I am on garuda linux !
and because of that I make this topic.
the thing that was confusing me is that when I didnt install rtw88-dkms-git , my wifi adaptor connecting to internet but I think it was disconnecting and again connecting and connection not stable and disconnecting much and after I install that driver and then my wifi working well and it has just not working after reboots to garuda linux like that I see this behaviour on ubuntu too( I didnt install driver at ubuntu for wifi ) .
some mins ago I uninstalled rtw88-dkms-git and then reboot , then I see that my wifi adaptor not working at all !
even when I replug it.
what is the problem here ?
and what driver would you suggest?
I would advise to use the adapter that works with Linux and discuss everything else with the manufacturer that does not.
We have no influence on driver software.
Read the manual for rt... , search in web, contact the manufacturer.
Garuda do not support dual boot with M$, but sometimes we can help, but sometimes not.
Are we mixing different wifi adapter's into the conversation here, because the likelihood of a Realtek driver making any difference with a ralink adapter is slim and none.
I think you mean that rtw88-dkms-git cant make the ralink rt2870/rt3070 working?
but if you want I reinstall it again and say it is working or not after installation of that driver?
for me this is a question how my adapter working with driver ?!
after I uninstalled that , then my wifi not working with rt2870/rt3070 adapter!
is rtw88-dkms-git installed by default on garuda linux?
for now , this is the question.
why my ralink adapter working when I install rtw88-dkms-git ( realtek driver) but not working at all when I uninstalled that ?!
on ubuntu I see this behavior that my wifi adapter working but after restart that was not working and I need to replug that.
when I installed rtw88-dkms-git my wifi act like how in ubuntu.
and when I uninstalled it dont act like ubuntu and other distros.
because that it was question for me and I dont know what happend?!
This could be because the realtek driver blacklisted the kernel module bt2800usb.
In-fact in the initial inxi the module was loaded and the interface up.
Remember also to remove in Windows, not only BIOS, the fastboot, i.e. fast start or whatever the windows name
Your bios appears to be outdated, be sure your bios is the newest version available.
Do not keep referring to any other adapter on this thread anymore. I do not want to hear about this other adapter model again. We are only dealing with the adapter you were running when you ran the garuda-inxi command. Do not bring up any adapter other than the rt2870/rt3070 adapter listed in your inxi as this only muddies the water. Do not connect any other wifi device while troubleshooting is in progress.
Be sure that MAC address randomization has been disabled. Search the forum for instructions on how to do that. Reboot after disabling randomization. Report on exactly how you did that.
bash -c "nmcli networking off; sudo systemctl stop NetworkManager; sudo ip link set wlp1s0f0u5 down; sleep 1; sudo modprobe -r rt2800usb; sleep 3; sudo modprobe rt2800usb; sleep 1; sudo ip link set wlp1s0f0u5 up; sleep 1; sudo systemctl start NetworkManager; nmcli networking on; sleep 1; nmcli r wifi off; sleep 1; nmcli r wifi on"
These commands are to be run after a warm reboot when the wifi is not working. Be sure only the rt2870/rt3070 wifi adapter is connected to the computer.
Thanks.I wil do this codes and tricks and say the results.
but my bios version is the latest stable version.
I check now the asus website and it gives just a new beta bios version and I think we should wait until it gives the stable version.
