Pretty certain this is not a Garuda issue as much as it's a Linux Kernel/AMD Driver issue but figured I might ask if anyone had any ideas here.
So simply put I have a AMD Ryzen 9 5900 and a Radeon 6800XT in my system.
Games and Vulkan/Mesa Drivers seem to work fine as I am able to play games with no issues thus far at least.
However hashcat doesn't recognize the GPU and also has issues with the cpu saying it's identified as Generic.
Figured I would ask here see if any ideas. Thanks and appreciate devs work on this as I am enjoying Garuda quite a bit.
KK
Maybe kernel change got better results.
Read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It’s especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy your …
please
and post
inxi -Fxxxza
as text! Even if you personally think it is unnecessary.
and
System: Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=086c2445-862d-4d7c-a1f6-13a321a6dea4
Console: tty pts/1 wm: kwin_x11 DM: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Desktop System: Alienware product: Alienware Aurora Ryzen Edition v: 2.1.2
serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: Alienware model: 0TYR0X v: A00 serial: <filter> UEFI: Alienware v: 2.1.2 date: 02/25/2021
CPU: Info: 12-Core model: AMD Ryzen 9 5900 socket: AM4 bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache: L1: 768 KiB L2: 6 MiB
L3: 64 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 143730
Speed: 4033 MHz min/max: 2200/3000 MHz base/boost: 3000/4750 boost: enabled volts: 1.1 V
ext-clock: 100 MHz Core speeds (MHz): 1: 4033 2: 4198 3: 3782 4: 3976 5: 3685 6: 3672 7: 3826
8: 4214 9: 4554 10: 3787 11: 4248 12: 4108 13: 4089 14: 4394 15: 4053 16: 4219 17: 4039
18: 3911 19: 3905 20: 3667 21: 3957 22: 3949 23: 4419 24: 4301
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics: Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Dell driver: amdgpu v: kernel
bus-ID: 0d:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 10040x2160 s-dpi: 96 s-size: 2654x571mm (104.5x22.5")
s-diag: 2715mm (106.9")
Monitor-1: DisplayPort-0 res: 5120x1440 hz: 60 dpi: 108 size: 1200x340mm (47.2x13.4")
diag: 1247mm (49.1")
Monitor-2: DisplayPort-1 res: 1080x1920
Monitor-3: DisplayPort-2 res: 3840x2160 hz: 60 dpi: 157 size: 621x341mm (24.4x13.4")
diag: 708mm (27.9")
OpenGL:
renderer: AMD Radeon RX 6800 XT (SIENNA_CICHLID DRM 3.40.0 5.12.1-zen2-1-zen LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 0d:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sennheiser GSP 670 type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4.2:3
chip-ID: 1395:008a class-ID: 0300
Sound Server-1: ALSA v: k5.12.1-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network: Device-1: Realtek driver: r8169 v: kernel port: f000 bus-ID: 04:00.0 chip-ID: 10ec:2600
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks driver: iwlwifi v: kernel port: f000
bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:3 chip-ID: 8087:0029
Drives: Local Storage: total: 1.82 TiB used: 165.62 GiB (8.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS100T1X0E-00AFY0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: 613000WD temp: 35 Celsius C scheme: GPT
SMART: yes health: PASSED on: 23 hrs cycles: 5 read-units: 191,670 [98.1 GB]
written-units: 1,407,761 [720 GB]
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
family: 3.5" DT01ACA... Desktop HDD size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A810
temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 38 hrs cycles: 61 read: 183.05 GiB
written: 276.02 GiB
Partition: ID-1: / raw-size: 931.48 GiB size: 931.48 GiB (100.00%) used: 161.79 GiB (17.4%) fs: btrfs
block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 33 MiB size: 32.5 MiB (98.41%) used: 546 KiB (1.6%) fs: vfat
block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.48 GiB size: 931.48 GiB (100.00%) used: 161.79 GiB (17.4%) fs: btrfs
ID-4: /opt raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 3.83 GiB (0.4%) fs: btrfs
block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
ID-5: /var/log raw-size: 931.48 GiB size: 931.48 GiB (100.00%) used: 161.79 GiB (17.4%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-6: /var/tmp raw-size: 931.48 GiB size: 931.48 GiB (100.00%) used: 161.79 GiB (17.4%)
ID-1: swap-1 type: zram size: 1.31 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.31 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.31 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.31 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.31 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.31 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.31 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.31 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.31 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.31 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
ID-13: swap-13 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram12
ID-14: swap-14 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram13
ID-15: swap-15 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram14
ID-16: swap-16 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram15
ID-17: swap-17 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram16
ID-18: swap-18 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram17
ID-19: swap-19 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram18
ID-20: swap-20 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram19
ID-21: swap-21 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram20
ID-22: swap-22 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram21
ID-23: swap-23 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram22
ID-24: swap-24 type: zram size: 1.31 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram23
Sensors: System Temperatures: cpu: 64.2 C mobo: 0 C gpu: amdgpu temp: 65.0 C mem: 66.0 C
Info: Processes: 553 Uptime: 1h 32m wakeups: 0 Memory: 31.34 GiB used: 6.96 GiB (22.2%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 2150 pacman: 2144
lib: 488 snap: 6 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.4 running-in: konsole
inxi: 3.3.04
KoiaKoia:
As said, possibly helps another kernel or even BIOS update if there should be newer.
Similar hardware I also wanted to put me but I should still wait until all drivers work.
It works well enough for a daily driver just can't use as a pen-testing platform yet, which is okay I suppose. Support will come eventually.
If I understand you correctly it is not loading the modesetting, and radeon drivers/device and an updated bios or kernel should resolve this when it becomes available?
Thanks for your response it's much appreciated.
So, what is this hashcat thing that make you think your GPU is not working as it should?
If you have a real issue, please, describe it.
Else, I don’t find anything behaving wrong.
Compare your GPU performance characteristics with what is advertised.
The following is a list that contains general information about GPUs and video cards by AMD, including those by ATI Technologies before 2006, based on official specifications in table-form.
The headers in the table listed below describe the following:
Due to conventions changing over time, some numerical definitions such as core config, core clock, performance and memory should not be compared one-to-one across generations. The following tables are for reference use only, and do not reflect ...
AMD Navi 21, 2250 MHz, 4608 Cores, 288 TMUs, 128 ROPs, 16384 MB GDDR6, 2000 MHz, 256 bit
Your response was extremely helpful in spurring me to give this a second look. I was able to install the opencl-amd package from the aur and hashcat is not functioning.
I appreciate you requesting further info as in my attempt to get further description I solved my own problem.
Loving Garuda!!
KK
system
Closed
11 May 2021 16:29
8
