Sys Info
Kernel: 5.17.9-258-tkg-pds arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds-generic_v3
root=UUID=ef15347e-a4da-4628-afc3-2bff20cbb710 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 libahci.ignore_sss=1
resume=UUID=e7745511-30a0-4b3d-93c1-4bc3daa8b2b8 loglevel=3
amdgpu.ppfeaturemask=0xffffffff sysrq_always_enabled=1 nowatchdog
iommu=pt
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.86 date: 01/27/2022
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 4144 high: 4171 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4134 2: 4129
3: 4159 4: 4120 5: 4164 6: 4122 7: 4152 8: 4111 9: 4171 10: 4146 11: 4165
12: 4157 bogomips: 86492
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,HDMI-A-2
bus-ID: 0f:00.0 chip-ID: 1002:73df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
d-rect: 3968x1944 display-ID: 0
Monitor-1: DP-1 pos: bottom-l res: 2048x864 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 13.0.1 DRM
3.44 5.17.9-258-tkg-pds)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0f:00.1 chip-ID: 1002:ab28
Sound Server-1: ALSA v: k5.17.9-258-tkg-pds running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Edimax type: USB driver: btusb v: 0.8 bus-ID: 1-8:4
chip-ID: 7392:c611 class-ID: e001 serial: <filter>
Local Storage: total: 2.96 TiB used: 3.17 TiB (107.3%)
model: SSD 970 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 2B2QEXE7 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
ID-1: / raw-size: 914.08 GiB size: 914.08 GiB (100.00%)
used: 773.06 GiB (84.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
used: 29.4 MiB (11.5%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-3: /home raw-size: 914.08 GiB size: 914.08 GiB (100.00%)
ID-4: /var/log raw-size: 914.08 GiB size: 914.08 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.08 GiB size: 914.08 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.18 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8
ID-2: swap-2 type: zram size: 31.27 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.4 C mobo: 35.0 C gpu: amdgpu temp: 54.0 C
mem: 56.0 C
Fan Speeds (RPM): cpu: 1888 fan-1: 0 fan-3: 1309 fan-4: 1514 fan-5: 1236
gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.26 vbat: 3.28 gpu: amdgpu watts: 30.00
Processes: 488 Uptime: 13m wakeups: 2 Memory: 31.27 GiB
used: 15.82 GiB (50.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 2326 pacman: 2314 lib: 583 flatpak: 12
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2021-10-17
Last full system update: 2022-05-22
I recently switched from a gtx 1080(fans broke) to a rx6700xt and have been having worse performance in games since.
Acording to mangohud it is not even fully using my GPU and is power throttling as you can see in these two images
Garuda
also tried in ubuntu and got better performance but still not as good as windows
What I have tried
I have tried using gamemode to force the 6700xt to max performance mode and still get the same issue. I also tried the ppfeaturemask kernel parameter and no change.
